* libnetworking/Makefile.am: Don't include subdirs.am.
* configure.ac: Add score/cpu/avr/Makefile.am.
* score/cpu/Makefile.am: Add avr.
* aclocal/rtems-cpu-subdirs.m4: Add avr.
* aclocal/rtems-cpu-subdirs.m4: Remove (unused).
* * configure.ac: Remove RTEMS_CPU_SUBDIRS.
* librpc/src/xdr/xdr_float.c: Add __AVR__.
* binutils/binutils.add: Rename package from binutils-collection to
binutils. Cleanups.
* binutils/target-binutils.add: Reflect changes above.
* binutils/Makefile.am: Add avr. Reflect changes above.
* autotools/autoconf-rtems.spec.in: Cleanup for chroot'ed builds.
* autotools/automake-rtems.spec.in: automake-1.9.2.
* gcc3newlib/Makefile.am: Add avr-rtems*gcc.
* gcc3newlib/gccnewlib.add: Disable c++ for avr.
* aclocal/gcc-weak.m4: New (Extracted from cpukit/configure.ac).
* configure.ac: Add RTEMS_CHECK_GCC_WEAK.
PR 677/misc
* libmisc/dumpbuf/dumpbuf.h, libmisc/fsmount/fsmount.h,
libmisc/rtmonuse/rtmonuse.h, libmisc/serdbg/serdbg.h,
libmisc/serdbg/serdbgcnf.h, libmisc/serdbg/termios_printk.h,
libmisc/serdbg/termios_printk_cnf.h, libmisc/untar/untar.h: Add
extern C wrappers.
PR 676/networking
* libnetworking/nfs/bootp_subr.c: /etc/resolv.conf contains NTP instead
of DNS servers.
* README, times, network/network.c, start/start.S, startup/bspclean.c,
startup/bspstart.c, startup/init5272.c, startup/linkcmds: Use CVS Id.
* FAQ/build45.t: Misc. corrections.
PR 671/bsps
* rtems/score/cpu.h: Fixed bug in _CPU_ISR_Set_level, where input param
was always ignored.
PR 673/make_build
* config-ml.in: Quote 'cd "${ml_origdir}"'.
Quote 'cd "${ML_POPDIR}"'.
PR 673/make_build
* aclocal/rtems-top.m4 (RTEMS_TOP): Add further quotes.
* aclocal/ppc.m4 (RTEMS_PPC_EXCEPTIONS): Quote ac_popdir uses.
* aclocal/target.m4 (_RTEMS_POP_BUILDDIR): Ditto.
* acinclude.m4 (_RTEMS_CONFIG_SUBDIR): Quote ac_popdir uses.
* custom/csb360.cfg: New file.
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac,
times, console/.cvsignore, console/console-io.c, include/.cvsignore,
include/bsp.h, include/coverhd.h, include/tm27.h, network/network.c,
start/.cvsignore, start/start.S, startup/.cvsignore,
startup/bspclean.c, startup/bspstart.c, startup/init5272.c,
startup/linkcmds: New files.
* Makefile.am, configure.ac: Added CSB360 BSP
* mcf5272/.cvsignore, mcf5272/ChangeLog, mcf5272/Makefile.am,
mcf5272/clock/.cvsignore, mcf5272/clock/ckinit.c,
mcf5272/include/.cvsignore, mcf5272/include/mcf5272.h,
mcf5272/timer/.cvsignore, mcf5272/timer/timer.c,
mcf5272/timer/timerisr.S: New files.
* rgdb_specs/layers.txt, rgdb_specs/process.txt,
rgdb_specs/seqbreak.txt, rgdb_specs/seqdetach.txt,
rgdb_specs/seqinit.txt: New.
* rgdb_specs/comm.t, rgdb_specs/conclusion.t,
rgdb_specs/gdbinternals.t: Use @image for
ASCII figures (Reflect changes above).
* common/rtems.texi.in, FAQ/basic.t: Remove RTEMSSNAPSHOTS,
RTEMSSNAPSHOTSSUBSCRIBE.
* FAQ/basic.texi, FAQ/bsp.texi, FAQ/build45.texi, FAQ/concepts.texi,
FAQ/debug.texi, FAQ/endoftime.texi, FAQ/freesw.texi,
FAQ/hwdebugaids.texi, FAQ/projects.texi, FAQ/tools.texi,
FAQ/version.texi, FAQ/stamp-vti: New.
FAQ/version.texi: New.
* networking/networkflow.txt, networking/PCIreg.txt,
networking/recvbd.txt: New.
* networking/decdriver.t, networking/networktasks.t: Use @image for
* network/network.c: Changes to network driver to get it to compile
again.
* autotools/automake.spec.in: automake-1.9.
* VERSION: Updated to rtems-4.6.99.1.
* aclocal/version.m4: Updated to rtems-4.6.99.1.
* release_support: Have a user name.
* startup/linkcmds: Add gnu.linkonce.d and gcc_except_table sections.
PR 620/networking
* libnetworking/lib/rtems_bsdnet_ntp.c,
libnetworking/rtems/rtems_bsdnet.h: Enhance NTP API.
PR 609/rtems
* score/src/threaddispatch.c: Close race condition between
_Thread_Dispatch and _Thread_Tickle_timeslice.
PR 654/rtems
* score/src/threadinitialize.c: Initialize the per thread watchdog
timer. When the thread control block is reused, we cannot depend on
it being zeroed.
