* | Corrected spacing. | Joel Sherrill | 1999-10-11 | 1 | -1/+0 |
* | Added support for @appendix and @preface. | Joel Sherrill | 1999-10-11 | 1 | -0/+12 |
* | Corrected bullet with @bullet. | Joel Sherrill | 1999-10-11 | 1 | -1/+1 |
* | Generated concept and function index entries. | Joel Sherrill | 1999-10-11 | 19 | -1171/+2626 |
* | Added descriptions. | Joel Sherrill | 1999-10-11 | 2 | -61/+88 |
* | Updated to incldue descriptions and reformatted to wrap lines better. | Joel Sherrill | 1999-10-11 | 1 | -93/+396 |
* | Added descriptions of routines to section headings. | Joel Sherrill | 1999-10-11 | 3 | -80/+80 |
* | Added descriptions. | Joel Sherrill | 1999-10-11 | 3 | -38/+66 |
* | More cleanup. | Joel Sherrill | 1999-10-11 | 8 | -63/+65 |
* | Enabled index generation. | Joel Sherrill | 1999-10-11 | 1 | -4/+4 |
* | Cleaned up to install dvi, use native texi2dvi, etc.. | Joel Sherrill | 1999-10-11 | 24 | -107/+117 |
* | Added filesystem design guide and scaling directives for the images. | Joel Sherrill | 1999-10-11 | 1 | -72/+144 |
* | Added filesystem design guide. | Joel Sherrill | 1999-10-11 | 1 | -1/+1 |
* | Install all of the gif's in the common directory. | Joel Sherrill | 1999-10-11 | 1 | -0/+1 |
* | Changed install point and cleaned up. | Joel Sherrill | 1999-10-11 | 1 | -11/+2 |
* | Now build. | Joel Sherrill | 1999-10-11 | 3 | -175/+489 |
* | Added enough to let script find that this does not have descriptions. | Joel Sherrill | 1999-10-11 | 1 | -10/+10 |
* | changed version to 19991011 | Joel Sherrill | 1999-10-11 | 0 | -0/+0 |
* | Make sure directories are made before installing and install html, | Joel Sherrill | 1999-10-11 | 1 | -3/+4 |
| | | | | pdf, ps, and dvi into the html directory so they all can be browsed. | ||||
* | changed version to 19991011 | Joel Sherrill | 1999-10-11 | 1 | -1/+1 |
* | Turned on concept and function name indexing. | Joel Sherrill | 1999-10-11 | 23 | -154/+771 |
* | Fixed variable reference for RTEMS-RELEASE. | Joel Sherrill | 1999-10-11 | 1 | -1/+1 |
* | Moved RTEMS error and association from libmisc to libc support to | Joel Sherrill | 1999-10-11 | 8 | -14/+14 |
| | | | | | avoid cyclic dependencies generated when moving packages to the top level. | ||||
* | Removed targets and configurations that are no longer functional | Joel Sherrill | 1999-10-11 | 14 | -1428/+0 |
| | | | | | | | | | | | | | | and not likely to become so. Comments on each configuration are below. + Force CPU386 - This BSP was developed as part of the initial port of RTEMS to the i386. This board has been unavailable for a long time now. + GO32 - This BSP and some CPU code supported djgpp v1.x. This version is now quite old. No one has stepped forward to update the code to v2.x which may be technically impossible anyway. More importantly, go32 has been superceded by the pc386 BSP. | ||||
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-10-11 | 6 | -34/+18 |
| | | | | | | | | Removed all go32 configuration tests. This patch also comments out some special treatment for Cygwin from *.m4 macros. According to reports from David Fiddes. these should not be necessary anymore. | ||||
* | Added as part of moving librdbg to its own top level package. This was | Joel Sherrill | 1999-10-11 | 6 | -0/+141 |
| | | | | done as part of a patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | ||||
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to move librdbg | Joel Sherrill | 1999-10-11 | 14 | -137/+1083 |
| | | | | to its own top level package. | ||||
* | Switched to the C++ front end to gcc to link. This still did not | Joel Sherrill | 1999-10-11 | 1 | -1/+1 |
| | | | | work. | ||||
* | Now compiles for coff and elf. | Joel Sherrill | 1999-10-11 | 1 | -65/+185 |
* | Added file system guide. | Joel Sherrill | 1999-10-11 | 1 | -45/+163 |
| | | | | Corrected link to supplements. | ||||
* | Cleanup. | Joel Sherrill | 1999-10-11 | 4 | -109/+140 |
* | First cut at complete document under CVS and texinfo. | Joel Sherrill | 1999-10-11 | 2 | -1/+9 |
* | New files. | Joel Sherrill | 1999-10-11 | 2 | -0/+2968 |
* | Added filesystem implementation notes chapter. | Joel Sherrill | 1999-10-08 | 2 | -1/+8 |
* | Added lifecycle chapter. | Joel Sherrill | 1999-10-08 | 3 | -3/+45 |
* | First cut at merging. | Joel Sherrill | 1999-10-08 | 1 | -26/+42 |
* | Another couple of chapters formatting under texinfo. | Joel Sherrill | 1999-10-08 | 2 | -31/+65 |
* | Added initial version of 3 other chapters. | Joel Sherrill | 1999-10-08 | 4 | -32/+49 |
* | Renamed path_eval to patheval | Joel Sherrill | 1999-10-08 | 1 | -2/+11 |
* | Base versions cut from old document. | Joel Sherrill | 1999-10-08 | 3 | -0/+108 |
* | Finished initial conversion to texinfo. | Joel Sherrill | 1999-10-08 | 1 | -171/+214 |
* | Added applayering but did not finish it. | Joel Sherrill | 1999-10-07 | 3 | -1/+288 |
* | Filled in descriptions for required fields in CPU Configuration Table. | Joel Sherrill | 1999-10-07 | 1 | -1/+58 |
* | Added Base File System chapter. Builds completely. | Joel Sherrill | 1999-10-07 | 4 | -39/+325 |
* | Built with preface for info. | Joel Sherrill | 1999-10-07 | 3 | -0/+279 |
* | Remove $(PROJECT).pdf not *.pdf. We were accidentally removing the | Joel Sherrill | 1999-10-07 | 1 | -1/+2 |
| | | | | | | pdf version of figures. Added convert stanza to generate pdf's from eps of figures. | ||||
* | Enhanced to support @email{} as supported in texi2html in texinfo 4.0. | Joel Sherrill | 1999-10-07 | 1 | -0/+5 |
| | | | | | This way we maintain compatibility but continue to use the better, more flexible tool. | ||||
* | Remove $(PROJECT).pdf not *.pdf. We were accidentally removing the | Joel Sherrill | 1999-10-07 | 17 | -17/+17 |
| | | | | pdf version of figures. | ||||
* | Remove $(PROJECT).pdf not *.pdf. We were accidentally removing the | Joel Sherrill | 1999-10-07 | 2 | -6/+6 |
| | | | | | | | | | | | | pdf version of figures. Disabled building of pdf for both the C and Ada Getting Started manuals because texi2pdf can not handle the construct: @set URL http://www.rtems.com @uref{@value{URL},@value{URL}} It will be reenabled as soon as this problem is fixed. | ||||
* | Switched back to jpg for networkflow because netscape 4.71 for linux | Joel Sherrill | 1999-10-07 | 1 | -1/+1 |
| | | | | did not display the png properly. |
