* aclocal/version.m4: Bump RTEMS_API to 4.9.
Bump RTEMS_VERSION to 4.8.99.0.
* libcsupport/src/read.c, libcsupport/src/write.c: Fix spacing.
* preinstall.am: Add cplb.h.
* startup/bspstart.c: Add cast of constant.
* network/if_100MHz/GT64260eth.c: Add else.
* shared/can/occan.c: Fix Reenable command and fix typo.
* README: Update.
* shared/1553/b1553brm.c, shared/can/grcan.c: Remove include of sched.h
* Makefile.inc.in: Add CXX and CXX_FOR_TARGET.
* Makefile.am: Rename bin2c to rtems-bin2c.
* posix/src/semaphorecreatesupp.c: Fixed warning.
* libmisc/dumpbuf/dumpbuf.c: Use printk.
* console/console.c, irq/irq_init.c: Eliminate warnings.
* libchip/network/smc91111.h: Eliminate DEBUG_puts.
* PCI_bus/universe.c, console/console.c, include/bsp.h, irq/FPGA.c,
startup/bspstart.c, startup/genpvec.c, startup/spurious.c: Eliminate
DEBUG_puts.
* console/console.c: Eliminate DEBUG_puts.
* libnetworking/net/ppp_defs.h: Include rtems/stdint.h.
Use uint32_t for ext_accm.
* configure.ac: Remove AC_PROG_AWK (Unused).
* pppd/auth.c, pppd/demand.c, pppd/ipcp.c, pppd/ipcp.h,
pppd/lcp.c, pppd/lcp.h, pppd/magic.c, pppd/magic.h, pppd/options.c,
pppd/pppd.h, pppd/sys-rtems.c, pppd/utils.c: Convert to using C99
fixed-size types instead of BSD fixed-size types.
* libmisc/stackchk/check.c: Fix alignment of output.
* libmisc/monitor/monitor.h: Add network commands that were in the
network supplement but not in the code.
* libmisc/monitor/mon-network.c: New file.
* network/GT64260eth.c, network/GT64260eth.h, network/GT64260ethreg.h: Removed.
* network/if_1GHz/if_wm.c, network/if_1GHz/pci_map.c: Remove a few
warnings.
* libchip/network/if_dc.c: Changed type of ISR argument to void* from
rtems_interrupt_vector, to permit passing arbitrary arguments to the
ISR. Clean up of variables to silence compiler warnings.
PR 1261/cpukit
* posix/src/semaphorecreatesupp.c: Initialize all fields during
semaphore creation.
PR 1260/cpukit
* posix/src/pthread.c: Get initial signals blocked from creating
thread not from ourselves.
* score/src/watchdogtickle.c: Remove tabs.
PR 1259/rtems
* rtems/src/taskcreate.c: Initialize is_global in all cases since
memory is not guaranteed to be zero.
* libchip/network/smc91111.c: Eliminate a stray DEBUG_puts().
* Makefile.am: Add smc91111.rel to libbsp.a
* configure.ac, startup/bspstart.c: Add BSP_DIRTY_MEMORY option.
* ChangeLog, Makefile.am, README, README.booting, README.irq,
preinstall.am, GT64260/MVME5500I2C.c, include/bsp.h, irq/irq.c,
irq/irq.h, irq/irq_init.c, pci/detect_host_bridge.c, pci/pci.c,
pci/pci_interface.c, pci/pcifinddevice.c, start/preload.S,
startup/bspclean.c, startup/bspstart.c, startup/pgtbl_activate.c,
startup/reboot.c, vectors/bspException.h, vectors/exceptionhandler.c:
Merge my improvements in this BSP including a new network
driver for the 1GHz NIC.
* network/if_100MHz/GT64260eth.c, network/if_100MHz/GT64260eth.h,
network/if_100MHz/GT64260ethreg.h, network/if_100MHz/Makefile.am,
network/if_1GHz/Makefile.am, network/if_1GHz/POSSIBLEBUG,
network/if_1GHz/if_wm.c, network/if_1GHz/if_wmreg.h,
network/if_1GHz/pci_map.c, network/if_1GHz/pcireg.h: New files.
* shared/spw/grspw.c: Remove include of sched.h. It does not appear to
be needed and is unavailable when POSIX is disabled.
PR 1258/rtems
* cpukit/score/src/heapallocatealigned.c (block_allocate): New routine.
* cpukit/score/src/heapallocatealigned.c (_Heap_Allocate_aligned):
Use block_allocate() instead of _Heap_Block_allocate(). Replace
_Heap_Head(the_heap)->next with equivalent _Heap_First(the_heap).
* cpukit/score/src/heap.c (_Heap_Allocate): fix comments according
to changed block split strategy in _Heap_Allocate_aligned().
* libchip/network/smc91111.c, libchip/network/smc91111.h: Multiple fixes.
- Odd bit bug in some chips taken care of.
- Buggy ASSERT removed, it seem to be inserted to detect if MBUF data
alignment but failing to do so must have made the driver writer to make
some incorrect assumptions about MBUFs.
- Fixed MBUF handling to handle mbuf chains better. The Data length of
MBUFs in middle of the mbuf chain are now checked for odd number of bytes.
- Made while loop responsible for copying data to fifo port copy 16 shorts
per loop instead of 1 short, increasing the copying process.
* leon_smc91111/leon_smc91111.c: LEON2 SMC91111 initialization: PIO
Interrupt initialization fix and speed rate defaulted to 100Mbit/s
for boards with 50MHz system clock or greater now all defaults to
100Mbit/s
* shared/can/grcan.c, shared/include/debug_defs.h, shared/spw/grspw.c:
Remove use of DEBUG_printf.
PR 1257/bsps
* sh7032/score/cpu_asm.c, sh7032/timer/timer.c, sh7045/score/cpu_asm.c,
sh7045/timer/timer.c, sh7750/score/cpu_asm.c, sh7750/timer/timer.c:
Code outside of cpukit should use the public API for
rtems_interrupt_disable/rtems_interrupt_enable. By bypassing the
public API and directly accessing _CPU_ISR_Disable and
_CPU_ISR_Enable, they were bypassing the compiler memory barrier
directive which could lead to problems. This patch also changes the
type of the variable passed into these routines and addresses minor
style issues.
PR 1257/bsps
* mpc5xx/exceptions/raw_exception.c, mpc5xx/irq/irq.c,
mpc6xx/exceptions/raw_exception.c,
mpc8260/exceptions/raw_exception.c,
mpc8xx/exceptions/raw_exception.c, new-exceptions/raw_exception.c,
ppc403/ictrl/ictrl.c, ppc403/irq/ictrl.c: Code outside of cpukit
style issues.
PR 1257/bsps
* at91rm9200/irq/irq.c, lpc22xx/irq/irq.c, mc9328mxl/irq/irq.c,
s3c2400/irq/irq.c: Code outside of cpukit should use the public API
for rtems_interrupt_disable/rtems_interrupt_enable. By bypassing the
style issues.
PR 1257/bsps
* shared/irq/i8259.c, shared/irq/irq.c: Code outside of cpukit should
style issues.
PR 1257/bsps
* irq/irq_init.c: Code outside of cpukit should use the public API for
style issues.
PR 1257/bsps
* irq/irq.c: Code outside of cpukit should use the public API for
style issues.
PR 1257/bsps
* irq/GT64260Int.c, irq/irq.c: Code outside of cpukit should use the
public API for rtems_interrupt_disable/rtems_interrupt_enable. By
bypassing the public API and directly accessing _CPU_ISR_Disable and
style issues.
