* | atsamv-testsuite.tcfg: Add linpack | Joel Sherrill | 2017-04-04 | 1 | -0/+1 |
* | rtl22xx/../*-testsuite.tcfg: Add linpack | Joel Sherrill | 2017-04-04 | 2 | -0/+2 |
* | stm32f4/../*-testsuite.tcfg: Add linpack | Joel Sherrill | 2017-04-04 | 2 | -0/+2 |
* | tms570/../*-testsuite.tcfg: Add linpack | Joel Sherrill | 2017-04-04 | 3 | -0/+9 |
* | mpc55xxevb/.../*-testsuite.tcfg: Add linpack | Joel Sherrill | 2017-04-04 | 11 | -0/+17 |
* | mrm332-testsuite.tcfg: Add linpack | Joel Sherrill | 2017-04-04 | 1 | -0/+1 |
* | mcf5225x-testsuite.tcfg: Add linpack | Joel Sherrill | 2017-04-04 | 1 | -0/+1 |
* | mcf52235-testsuite.tcfg: Add linpack | Joel Sherrill | 2017-04-04 | 1 | -0/+1 |
* | gensh1-testsuite.tcfg: Add linpack | Joel Sherrill | 2017-04-04 | 1 | -0/+1 |
* | simsh*-testsuite.tcfg: Add linpack | Joel Sherrill | 2017-04-04 | 4 | -0/+4 |
* | gensh2-testsuite.tcfg: Add linpack | Joel Sherrill | 2017-04-04 | 1 | -0/+1 |
* | sys/event.h: Update to FreeBSD head 2017-02-13 | Sebastian Huber | 2017-04-04 | 1 | -7/+9 |
* | testsuite: Add a common test configuration. Fix configure.ac and Makefile.am ↵ | Chris Johns | 2017-04-04 | 30 | -363/+746 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | errors. - Add a top level test configuration file for test states that are common to all BSPs. This saves adding a test configuration (tcfg) file for every BSP. - Add the test states 'user-input' and 'benchmark'. This lets 'rtems-test' stop the test rather than waiting for a timeout or letting a benchmark run without the user asking for it to run. - Implement rtems-test-check in Python to make it faster. The shell script had grown to a point it was noticably slowing the build down. - Fix the configure.ac and Makefile.am files for a number of the test directories. The files are difficiult to keep in sync with the number of tests and mistakes can happen such as tests being left out of the build. The test fsrofs01 is an example. Also a there was a mix of SUBDIRS and _SUBDIRS being used and only _SUBDIRS should be used. - Fix the test fsrofs01 so it compiles. Closes #2963. | ||||
* | bsp/qoriq: Fix L1 cache flush | Sebastian Huber | 2017-04-03 | 1 | -6/+13 |
* | bsp/qoriq: Adjust MMU config only once | Sebastian Huber | 2017-04-03 | 3 | -5/+10 |
* | bsp/qoriq: Add post-link hook | Sebastian Huber | 2017-04-03 | 1 | -0/+7 |
* | bsps: Fix baud settings | Sebastian Huber | 2017-04-03 | 8 | -12/+10 |
| | | | | Update #2897. | ||||
* | configure: Remove defunct configure stuff | Sebastian Huber | 2017-04-03 | 1 | -2/+0 |
* | libdl: Support link ordered loading of ELF sections. | Chris Johns | 2017-03-31 | 6 | -1341/+1523 |
| | | | | | | | | | | | | | The ARM C++ exception ABI uses an address ordered index table to locate the correct frame data and this requires the EXIDX sections are loaded in the order the order the matching text is loaded. The EXIDX sections set the SHF_LINK_ORDER flag and link field. This patch adds support to load those flagged sections in the linked-to section order. Updates #2955. Closes #2959 | ||||
* | benchmarks/whetstone: Port to RTEMS | Sebastian Huber | 2017-03-29 | 5 | -15/+39 |
| | | | | Update #2958. | ||||
* | benchmarks/whetstone: Import | Sebastian Huber | 2017-03-29 | 1 | -0/+433 |
| | | | | | | | | Import whetstone sources from: http://www.netlib.org/benchmark/whetstone.c Update #2958. | ||||
* | benchmarks/linpack: Port to RTEMS | Sebastian Huber | 2017-03-29 | 5 | -180/+109 |
| | | | | Close #2958. | ||||
* | benchmarks/linpack: Import | Sebastian Huber | 2017-03-29 | 1 | -0/+1333 |
| | | | | | | | | Import linpack sources from: http://www.netlib.org/benchmark/linpack-pc.c Update #2958. | ||||
* | benchmarks/dhrystone: Port to RTEMS | Sebastian Huber | 2017-03-29 | 7 | -33/+128 |
* | benchmarks/dhrystone: Import | Sebastian Huber | 2017-03-29 | 6 | -0/+1596 |
| | | | | | | | | Import dhrystone sources from: http://www.netlib.org/benchmark/dhry-c Update #2958. | ||||
* | benchmarks: Add benchmark templates | Sebastian Huber | 2017-03-29 | 15 | -1/+273 |
* | arm: Optimize context switch | Sebastian Huber | 2017-03-28 | 4 | -90/+55 |
| | | | | | | | | | Set CPU_ENABLE_ROBUST_THREAD_DISPATCH to TRUE. In this case the interrupts are always enabled during a context switch even after interrupt processing (see #2751). Remove the CPSR from the context control since it contains only volatile bits. Close #2954. | ||||
* | posix: Fix pthread_detach() internal lock acquire | Sebastian Huber | 2017-03-28 | 1 | -1/+1 |
* | rtems: Fix error return path | Sebastian Huber | 2017-03-28 | 1 | -0/+1 |
* | cpukit: Fix Makefile.am and update preinstall.am | Sebastian Huber | 2017-03-27 | 2 | -18/+20 |
* | bsp/qoriq: Regenerate preinstall.am | Sebastian Huber | 2017-03-27 | 1 | -4/+0 |
* | bsp/tms570: Use shared benchmark timer | Sebastian Huber | 2017-03-27 | 2 | -62/+1 |
* | bsps: Add simple CPU counter benchmark timer | Sebastian Huber | 2017-03-27 | 1 | -0/+35 |
* | bsp/tms570: Simplify CPU counter support | Sebastian Huber | 2017-03-27 | 1 | -63/+13 |
| | | | | Only touch the cycle counter settings. Do not enable user mode access. | ||||
* | bsps/arm: Add Performance Monitors Extension | Sebastian Huber | 2017-03-27 | 1 | -1/+446 |
* | bsp/tms570: Simplify <bsp.h> | Sebastian Huber | 2017-03-27 | 1 | -12/+0 |
* | bsp/tms570: Remove OPERATION_COUNT define | Sebastian Huber | 2017-03-27 | 1 | -3/+0 |
| | | | | This is the wrong place to define it. | ||||
* | termios: Avoid invalid memory access | Sebastian Huber | 2017-03-27 | 1 | -1/+3 |
* | termios: Synchronize with latest FreeBSD headers | Kevin Kirspel | 2017-03-22 | 77 | -658/+1393 |
| | | | | | | | | | | | Adding modified FreeBSD headers to synchronize RTEMS termios with FreeBSD. Modify termios to support dedicated input and output baud for termios structure. Updated BSPs to use dedicated input and output baud in termios structure. Updated tools to use dedicated input and output baud in termios structure. Updated termios testsuites to use dedicated input and output baud in termios structure. Close #2897. | ||||
* | bsp/atsam: Fix DMA support of some drivers | Sebastian Huber | 2017-03-22 | 3 | -0/+3 |
* | dosfs: Fix file name search | Sebastian Huber | 2017-03-16 | 2 | -18/+17 |
| | | | | | | | Do not use our long file name entry count to optimize the file name search. The Unicode comparison must be taken into account. Update #2939. | ||||
* | dosfs: Fix race condition msdos_dir_read() | Sebastian Huber | 2017-03-16 | 1 | -5/+5 |
| | | | | | | Obtain file system instance lock before member access. Update #2937. | ||||
* | dosfs: Rename fat_entries to lfn_entries | Sebastian Huber | 2017-03-16 | 1 | -20/+20 |
| | | | | | The name "fat_entries" for long file name directory entries is quite misleading. | ||||
* | dosfs: Fix long file name padding | Sebastian Huber | 2017-03-16 | 1 | -3/+3 |
| | | | | Update #2934. | ||||
* | dosfs: msdos_filename_utf8_to_short_name_for_save | Sebastian Huber | 2017-03-16 | 1 | -15/+10 |
| | | | | Simplify. | ||||
* | dosfs: Fix msdos_add_file() | Sebastian Huber | 2017-03-16 | 1 | -245/+155 |
| | | | | | | Make sure that long file names work accross cluster boundaries. Update #2929. | ||||
* | dosfs: Simplify msdos_add_file() | Sebastian Huber | 2017-03-16 | 1 | -4/+2 |
* | dosfs: Add and use msdos_lfn_checksum() | Sebastian Huber | 2017-03-16 | 3 | -22/+25 |
* | dosfs: Simplify fat_file_open() | Sebastian Huber | 2017-03-16 | 1 | -3/+1 |
* | dosfs: Simplify msdos_creat_node() | Sebastian Huber | 2017-03-16 | 1 | -21/+14 |
| | | | | Update #2929. |
