* configure.ac: Fix bug in librpc activation, having introduced by
yesterday's patch.
* custom/vegaplus.cfg: Fix bogus and corrupted make-exe.
* acinclude.m4, configure.ac: Go back to name bender for
the or32/or1200 BSP.
* configure.ac: GO back to name bender for the or32/or1200 BSP.
* acinclude.m4, configure.ac: Update and fix minor things so this
BSP compiles and almost completely links.
* bsp_specs, configure.ac, startup/bspstart.c: Update and fix
minor things so this BSP compiles and almost completely links.
* startup/Makefile.am: New file.
* configure.ac: Be more specific about looking at CPU32 and CPU32+
CPU model names so we can turn on the best compile of memcpy.c.
* configure.ac: or32 does not currently support librpc.
* asm.h, rtems/score/cpu.h: Correct items that have changed since
RTEMS version or32 port was based upon.
* custom/efi332.cfg, custom/gen68340.cfg, custom/gen68360.cfg,
custom/mrm332.cfg: Use more proper CPU models so libcpu knows more.
* setup.def: Updating gcc3/newlib patches and tool versions. The
focus of this round of patches was ot eliminate header file name
conflicts between RTEMS and newlib.
* configure.ac: Replace mcpu32 by mcpu32p conditional.
* share/misc/Makefile.am: Fix AM_CPPFLAGS bug.
* include/.cvsignore: Updated to account for more files.
* .cvsignore: New file.
* Makefile.am: New file.
* custom/or32sim.cfg: New file added as part of merge from
OpenCores repository.
* ChangeLog, acinclude.m4, configure.ac: New files added as part
of merge from OpenCores repository.
* .cvsignore, Makefile.am, README, bsp_specs, configure.ac, times,
clock/.cvsignore, clock/Makefile.am, clock/clockdrv.c,
console/.cvsignore, console/Makefile.am, console/console.c,
console/console.h, include/.cvsignore, include/Makefile.am,
include/bsp.h, start/.cvsignore, start/Makefile.am, start/start.S,
startup/.cvsignore, startup/bspclean.c, startup/bspstart.c,
startup/linkcmds, startup/main.c, startup/setvec.c, timer/.cvsignore,
timer/Makefile.am, timer/timer.c, timer/timerisr.c,
wrapup/.cvsignore, wrapup/Makefile.am, ChangeLog: New files added
as part of merge from OpenCores repository.
* aclocal/env-rtemsbsp.m4: Remove RTEMS_CONFIG_PER_BSP.
* aclocal/env-rtemscpu.m4: Remove RTEMS_CONFIG_PER_BSP.
Use AS_IF instead of if/then/else/fi.
* pci/pcibios.c: Per PR262, removed all asserts so probes for
devices that are not present will work. This lets you have
multiple PCI Ethernet drivers in an application and dynamically
use the one for the card othat is present.
* rtems/score/cpu.h, rtems/score/types.h: Updated to fix some typos.
* asm.h, cpu.c, cpu_asm.c, rtems/score/cpu.h, rtems/score/or32.h,
rtems/score/types.h: Merged from OpenCores CVS repository.
* Per PR260 eliminate use of make-target-options. This impacted
RTEMS allowing a distinction between the CPU32 and CPU32+ in the
SuperCore and required that the m68k optimized memcpy be moved
to libcpu.
* custom/gen68360.cfg: Remove make-target-options.
to libcpu.
* memcpy.c: Moved to libcpu.
* Makefile.am: Modified to reflect above.
to libcpu.
* shared/misc/memcpy.c: Moved from score/cpu/m68k.
* configure.ac, shared/Makefile.am: Modified to reflect new directory.
* shared/misc/.cvsignore, shared/misc/Makefile.am: New file.
to libcpu.
* wrapup/Makefile.am: Pick up memcpy.o from libcpu.
* startup/bspstart.c, startup/linkcmds: Per PR247 , fix the linkcmds
to avoid overlapping sections and reworked the way the heap and
workspace are calculated.
enable this support.
* cdtest/init.c: Modified.
* cpuuse/task2.c, malloctest/task1.c, putenvtest/init.c,
rtmonuse/task1.c, termios/init.c: Modified.
* tmitronsem01/init.c: Modified.
* itronhello/init.c, itronmbf01/init.c, itronmbox01/init.c,
itronsem01/init.c, itrontask01/task1.c, itrontask02/init.c,
itrontask03/task1.c, itrontask04/task3.c, itrontime01/init.c: Modified.
* include/pmacros.h, psx01/task.c, psx02/init.c, psx02/task.c,
psx03/init.c, psx04/init.c, psx05/init.c, psx06/init.c, psx07/init.c,
psx08/task3.c, psx09/init.c, psx10/init.c, psx11/init.c,
psx12/init.c, psx13/Makefile.am, psx13/main.c, psx13/test.c,
psxcancel/init.c, psxchroot01/Makefile.am, psxchroot01/main.c,
psxchroot01/test.c, psxfile01/Makefile.am, psxfile01/main.c,
psxfile01/test.c, psxfile01/test_cat.c, psxfile01/test_extend.c,
psxfile01/test_write.c, psxmount/Makefile.am, psxmount/main.c,
psxmount/test.c, psxmsgq01/init.c, psxreaddir/Makefile.am,
psxreaddir/main.c, psxreaddir/test.c, psxsem01/init.c,
psxstat/Makefile.am, psxstat/main.c, psxstat/test.c, psxtime/main.c,
psxtime/test.c, psxtimer/psxtimer.c: Modified.
* mp01/task1.c, mp02/task1.c, mp03/task1.c, mp04/task1.c, mp05/task1.c,
mp06/task1.c, mp07/task1.c, mp08/task1.c, mp09/task1.c, mp10/init.c,
mp11/init.c, mp12/init.c, mp13/init.c, mp13/task2.c: Modified.
* include/timesys.h, tm01/task1.c, tm02/task1.c, tm03/task1.c,
tm04/task1.c, tm05/task1.c, tm06/task1.c, tm07/task1.c, tm08/task1.c,
tm09/task1.c, tm10/task1.c, tm11/task1.c, tm12/task1.c, tm13/task1.c,
tm14/task1.c, tm15/task1.c, tm16/task1.c, tm17/task1.c, tm18/task1.c,
tm19/task1.c, tm20/task1.c, tm21/task1.c, tm22/task1.c, tm23/task1.c,
tm24/task1.c, tm25/task1.c, tm26/task1.c, tm27/task1.c, tm28/task1.c,
tm29/task1.c, tmck/task1.c, tmoverhd/testtask.c: Modified.
* sp01/task1.c, sp02/task1.c, sp03/task2.c, sp04/task1.c, sp05/task1.c,
sp06/task1.c, sp07/taskexit.c, sp08/task1.c, sp09/task1.c,
sp11/task1.c, sp12/pritask.c, sp12/task5.c, sp13/task1.c,
sp14/task2.c, sp15/task1.c, sp16/task1.c, sp17/task1.c,
sp19/fptask.c, sp20/task1.c, sp21/task1.c, sp22/task1.c,
sp23/task1.c, sp24/task1.c, sp25/task1.c, sp26/init.c, sp26/task1.c,
sp30/task1.c, sp31/task1.c, spsize/init.c, spsize/size.c: Modified.
* include/buffer_test_io.h: New file.
* machine/param.h, sys/syslimits.h: In the continued effort to
eliminate .h conflicts between newlib and RTEMS, these were moved to
newlib.
* machine/Makefile.am, sys/Makefile.am: Reflect above.
* BSP_TIMES, wksheets.texi: Updated to reflect ARM times
reported by Jay Monkman <jmonkman@adventnetworks.com>. These
times are subject to change as he tunes the ARM port and their BSP.
* cpuuse/cpuuse.c (CPU_usage_Dump) : Corrected so it honors when an
object name is raw versus being a string.
* include/coverhd.h: Per PR261 removed include of
<rtems/score/targopts.h> because the file is no longer being
generated and really wasn't being used anyway.
* eth_comm.cfg, mbx821_001.cfg, mbx860_002.cfg, mbx860_005b.cfg,
mbx8xx.cfg, mpc8260ads.cfg: Per PR260 removed make-target-options.
* custom/mvme136.cfg: Per PR260 removed make-target-options.
* wrapup/Makefile.am: Don't install.
* wrapup/Makefile.am: Use librtems.a.
* wrapup/Makefile.am: Use libsapi.a.
* src/Makefile.am: Add librtems.a.
* src/Makefile.am: Add libsrtems.a.
* Makefile.am: Clean $(PROJECT_RELEASE).
