* src/dosfs/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* src/imfs/Makefile.am: Include $(top_srcdir)/../automake/*.am.
Use ../aclocal.
* wrapup/Makefile.am: Include $(top_srcdir)/../automake/*.am.
Use ../aclocal.
Use ../aclocal.
* inline/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* macros/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* aclocal/bsp-alias.m4: Copied over from aclocal/.
* aclocal/canonical-host.m4: Ditto.
* aclocal/canonical-target-name.m4: Ditto.
* aclocal/canonicalize-tools.m4: Ditto.
* aclocal/check-bsp-cache.m4: Ditto.
* aclocal/check-bsps.m4: Ditto.
* aclocal/check-cpu.m4: Ditto.
* aclocal/check-itron.m4: Ditto.
* aclocal/check-multiprocessing.m4: Ditto.
* aclocal/check-networking.m4: Ditto.
* aclocal/check-newlib.m4: Ditto.
* aclocal/check-posix.m4: Ditto.
* aclocal/check-tool.m4: Ditto.
* aclocal/enable-bare.m4: Ditto.
* aclocal/enable-inlines.m4: Ditto.
* aclocal/enable-itron.m4: Ditto.
* aclocal/enable-multiprocessing.m4: Ditto.
* aclocal/enable-networking.m4: Ditto.
* aclocal/enable-posix.m4: Ditto.
* aclocal/enable-rtemsbsp.m4: Ditto.
* aclocal/env-rtemsbsp.m4: Ditto.
* aclocal/env-rtemscpu.m4: Ditto.
* aclocal/gcc-pipe.m4: Ditto.
* aclocal/gcc-specs.m4: Ditto.
* aclocal/multi.m4: Ditto.
* aclocal/multilib.m4: Ditto.
* aclocal/prog-cc.m4: Ditto.
* aclocal/project-root.m4: Ditto.
* aclocal/rtems-cpu-subdirs.m4: Ditto.
* aclocal/rtems-debug.m4: Ditto.
* aclocal/rtems-top.m4: Ditto.
* aclocal/subdirs.m4: Ditto.
* aclocal/sysv-ipc.m4: Ditto.
* aclocal/tool-paths.m4: Ditto.
* aclocal/version.m4: Ditto.
* copied over from aclocal/.
* Makefile.am: Remove multilib support.
* configure.ac: Ditto.
* sapi/Makefile.am: Ditto.
* rtems/Makefile.am: include multilib.am instead of RTEMS_BSP.cfg.
* automake/compile.am: Copied over from automake/.
* automake/lib.am: Copied over from automake/.
* automake/local.am: Copied over from automake/.
* automake/multilib.am: Copied over from automake/.
* automake/subdirs.am: Copied over from automake/.
* Makefile.am: Add automake/*.am.
* mkgdbspec.in, setup.def, gcc3newlib/gccnewlib.add, gdb/gdb.add:
Updated to gcc 3.1 and gdb 5.2.
* custom/jmr3904.cfg, custom/p4650.cfg, custom/p4600.cfg: Switch
to gcc 3.1 arguments.
* startup/linkcmds: Fixed typo and added gnu.linkonce.t and
gnu.linkonce.r sections.
* startup/linkcmds: Fixed typo.
* project.am: Use PATH_SEPARATOR to setup TEXINPUTS.
* configure.ac: Remove RTEMS_CHECK_POSIX_API.
Remove RTEMS_ENABLE_POSIX.
Remove RTEMS_CHECK_CUSTOM_BSP.
* Makefile.am: Remove headers. Remove CHANGELOG.
* configure.ac: Use AC_CONFIG_SRCDIR([pppd]).
* configure.ac: Add libnetworking.
* wrapup/Makefile.am: Ditto.
Relocate c/src/libnetworking.
* Makefile.am: Reflect moval.
* machine/Makefile.am: Ditto.
* net/Makefile.am: Ditto.
* lib/Makefile.am: Ditto.
* netinet/Makefile.am: Ditto.
* vm/Makefile.am: Ditto.
* libc/Makefile.am: Ditto.
* sys/Makefile.am: Ditto.
* arpa/Makefile.am: Ditto.
* nfs/Makefile.am: Ditto.
* kern/Makefile.am: Ditto.
* rtems/Makefile.am: Ditto.
* configure.ac: Dittp.
* wrapup/Makefile.am: Ditto. Remove references to networking apps.
* Makefile.am: Reflect moving libnetworking. Use libnetapps instead.
Move networking libraries to c/src/exec/libnetworking
* configure.ac: Reflect Moval.
* Makefile.am: Reflect Moval.
* wrapup/Makefile.am: Reflect Moval.
* setup.def: Updated to binutils 2.12.1.
* rtems/Makefile.am: Remove m68k-rtemself references.
* ChangeLog: Corrected spacing.
* Per PR31, moved mvme16x_hw.h to shared/mvme.
* include/Makefile.am: Modified to reflect movement.
* include/mvme16x_hw.h: Moved to shared/mvme.
* rtems/score/m68k.h: Per PR227, mc68060 does not require FPSP
since it is now multilib'ed.
* libblock, libfs moved to src/exec for multilib'ing.
* Makefile.am: Remove libblock, libfs.
* configure.ac: Remove CONFIG_SUBIDIRS libblock, libfs.
* configure.ac: Add libblock. Add libfs. Add AM_CONDITIONAL(UNIX).
* wrapup/Makefile.am: Add libblock, libfs/dosfs, libfs/imfs.
Move from c/src/libfs to c/src/exec/libfs
* configure.ac: Reflect move.
* Makefile.am: Ditto.
* src/Makefile.am: Ditto.
* src/dosfs/Makefile.am: Ditto.
* src/imfs/Makefile.am: Ditto.
Move from c/src/libblock to c/src/exec/libblock
* include/Makefile.am: Ditto.
* rtems_telnetd/pty.c: Remove bsp.h. Include <rtems/bspIo.h>.
* aclocal/version.m4: Updated to rtems-ss-20020528.
* src/.cvsignore: New file.
* coinfigure.ac, Makefile.am: Remove references to rootfs.
* configure.ac: Remove lib.
* Makefile.am: Remove libcsupport.
* configure.ac: Add libcsupport.
Relocate libcsupport from c/src/lib to c/src/exec/libcsupport.
* configure.ac: Use ENV_RTEMSCPU. Reflect changed paths.
* Makefile.am: Reflect changed paths.
* src/Makefile.am: Reflect changed paths.
* rootfs/.cvsignore: Remove.
* rootfs/Makefile.am: Remove.
* rootfs/mkrootfs.h: Remove.
* rootfs/mkrootfs.c: Remove.
* configure.ac: Remove rootfs and NETWORKING macros.
* wrapup/Makefile.am: Remove rootfs and HAS_NETWORKING.
* rtems/mkrootfs.c: Add (relocated from libmisc/rootfs).
* rtems/mkrootfs.h: Ditto.
* rtems/Makefile.am: Reflect changes above.
* sp21/task1.c (INVALID_DRIVER_MAJOR): Change definition to reflect
number of staticly configured device drivers.
* mpc6xx/exceptions/raw_exception.c, pc6xx/mmu/pte121.c: Modified
slightly to reflect recent PowerPC re-organization and avoid warnings.
* libc/envlock.c: Implemented code to let newlib's envlock share
the libio open/close mutex. Since both should be lightly used,
this should not lead to problems and saves resources.
* startup/linkcmds: Per PR224, added wild card math to .rodata.
* macros/rtems/score/thread..inl: Implemented missing routines
for new libc reentrancy support.
* macros/rtems/posix/mqueue.inl: Implemented missing routines
to support message queue FDs.
* mpc6xx/mmu/pte121.c, mpc6xx/mmu/pte121.h: New files. Missed in
merge of PR213.
