* custom/leon2.cfg: Removed defines that are now generated
in a non-BSP specific manner.
* Makefile.am: Cleanup.
* include/Makefile.am: Cleanup.
* shgen.c: Set default Phi to 20MHz (BUG-FIX).
* psxmount/psxmount.scn, psxmount/test.c: Correct spelling.
* Makefile.am, configure.in: Added support for instruction
cache enabling based on CPU model.
* cache/.cvsignore, cache/Makefile.am, cache/cache.c,
cache/cache_.h: New files.
* shared/src/cache_manager.c
(rtems_cache_invalidate_multiple_instruction_lines): If
CPU_INSTRUCTION_CACHE_ALIGNMENT is defined but 0, then there is
an instruction cache but no notion of line size.
* wrapup/Makefile.am: Pick up cache code from libcpu and pick
up .o's instead of .rel's from libcpu.
* cpu.c, rtems/cpu/sparc.h: Make floating point optional based
on gcc arguments. Do not initialize FP context if there is
no FPU. Flush instruction cache after installing RTEMS trap handler.
* startup/boardinit.S: St 32-bit ram width by default.
* ChangeLog, .cvsignore, Makefile.am, bspclean.c, bspstart.c,
gnatcommon.c, start.S: New files. Largely moved from ERC32
BSP to be able to be shared with LEON and other SPARC BSPs.
* network/sonic.c: Added ipalign() routine to align the
received packet so that the ip header is on a 32-bit boundary.
Necessary for cpu's that do not allow unaligned loads and stores
and when the 32-bit DMA mode is used.
* README.configure, aclocal/bsp-alias.m4, aclocal/check-bsps.m4:
Modified to reflect addition of LEON BSPs as well as the
no-FP ERC32 variant.
* custom/Makefile.am: Modified to reflect addition of files.
* custom/erc32.cfg: Modified to support addition of no-FP ERC32 variant.
* custom/erc32nfp.cfg, custom/leon1.cfg, custom/leon2.cfg: New file.
* Makefile.am, configure.in: Added shared directory as part
of enhancing ERC32 and adding LEON.
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs,
configure.in, times, clock/.cvsignore, clock/Makefile.am,
clock/ckinit.c, console/.cvsignore, console/Makefile.am,
console/console.c, console/consolereserveresources.c,
console/debugputs.c, gnatsupp/.cvsignore,
gnatsupp/Makefile.am, gnatsupp/gnatsupp.c,
include/coverhd.h, include/leon.h, start/.cvsignore,
start/Makefile.am, startup/.cvsignore, startup/Makefile.am,
startup/boardinit.S, startup/linkcmds, startup/setvec.c,
startup/spurious.c, timer/.cvsignore, timer/Makefile.am,
timer/timer.c, tools/.cvsignore, tools/Makefile.am,
tools/configure.in, tools/runtest.in, wrapup/.cvsignore,
wrapup/Makefile.am: New file.
* Makefile.am, configure.in, gnatsupp/Makefile.am,
gnatsupp/gnatsupp.c, include/Makefile.am, include/bsp.h,
start/Makefile.am, startup/Makefile.am, startup/setvec.c,
wrapup/Makefile.am:
* erc32sonic: New directory.
* erc32sonic/Makefile.am, erc32sonic/erc32sonic.c,
erc32sonic/.cvsignore: New files.
* include/erc32.h: New file.
* startup/boardinit.S: New file.
Big update of SPARC support for ERC32 and LEON.
Added support for ERC32 without floating point.
Added SONIC support as configured on Tharsys ERC32 board.
The bsp's share various code in the shared directory:
gnat-support, start-up code, etc.
To decrease the foot-print, I removed the 16 kbyte start-up
stack that was put in .bss and never reused once the system
was up. The stack is now put between the heap and the
workspace. To reclaim it, the user can do a rtems_region_extend
to merge the stack to the heap region once the system is up.
* clock_driver_stub.c: This is a stub of a clock driver that
is sufficient for linking the ticker application. Some
simulators do not have a soruce for a clock tick. Also
this can be used while constructing a BSP so everything links.
* Makefile.am, console/Makefile.am, include/Makefile.am,
start/Makefile.am: VPATH was not setup correctly
* ampolish: Generate ACLOCAL_AMFLAGS = -I .../aclocal.
* configure.in: catch -enable-rtemsbsp (Allowed by autoconf).
Autoconf allows one to pass -enable-*, but this file expected --enable*.
* custom/Cygwin-posix.cfg: Add -U__STRICT_ANSI__ to LIBC_DEFINES.
* libc/libio.c: Special treatment of O_NDELAY for Cygwin.
* configure.in: Remove trailing '/' from RPM_SPECSdir.
* aclocal/gcc-pipe.m4: Use $GCC instead of ac_cv_prog_gcc (autoconf
standard).
* aclocal/gcc-specs.m4: Use $GCC instead of ac_cv_prog_gcc (autoconf
standard).
* aclocal/multilib.m4: Fix m4-quoting (BUG-FIX).
* aclocal/check-bsp-cache.m4: Fix m4-quoting (autoconf-2.49b).
* aclocal/prog-cc.m4: Use $GCC instead of ac_cv_prog_gcc (autoconf
standard), replace CC_FOR_TARGET with CC (BUG-FIX).
* aclocal/enable-itron.m4: Remove changequotes (autoconf-2.49b).
* aclocal/enable-posix.m4: Remove changequotes (autoconf-2.49b), use
$host instead of $target (BUG-FIX).
* configure.in: Use $target and $host instead of $target_alias and
$host_alias (autoconf-2.49b).
* aclocal/check-newlib.m4: Remove CC_FOR_TARGET (BUG-FIX)
* aclocal/sysv-ipc.m4: Move AC_DEFINE outside of AC_CACHE (BUG-FIX)
NOTES:
* autoconf-2.49b depredicates using changequotes.
* The changes to configure.in are due to cleanups in
autoconf-2.49b's implemention of canonicalization. With
autoconf-2.1x it wasn't always clear, when to use $xxx or
$xxx_alias. Now this is clear.
* configure.in: Adapt m4-quoting to autoconf-2.49b, use $host
instead of $target to setup RPM_CPU, move chmod 755 buildall to
AC_OUTPUT's extra-cmds.
* Makefile.am, clock/Makefile.am, clock/.cvsignore, wrapup/Makefile.am:
Added include of stub clock driver so ticker would link.
* configure.in, Makefile.am, clock/Makefile.am, clock/.cvsignore,
wrapup/Makefile.am: Added include of stub clock driver so ticker
would link.
* include/rtems/system.h: Use proper conditional (RTEMS_POSIX_API)
so prototypes for POSIX_MP_NOT_IMPLEMENTED(), POSIX_NOT_IMPLEMENTED(),
POSIX_BOTTOM_REACHED() are actually included.
* network/README.cs8900, network/cs8900.c, network/cs8900.h: New files.
* network/Makefile.am: Modified to reflect above.
* aclocal/canonicalize-tools.m4, aclocal/check-tool.m4,
aclocal/prog-cc.m4, aclocal/prog-cxx.m4: Replace AC_CHECK_TOOL
with an RTEMS specific but more restrictive autoconf macro.
* automake/lib.am: Add LD.
* stubdr/Makefile.am: Replace leaf.cfg w/ automake/lib.am.
* bsp_specs: Remove -Tlinkcmds from *link rule.
* aclocal/canonicalize-tools.m4: Remove RTEMS_PATH_TOOL, use
AC_CHECK_TOOL instead of RTEMS_PATH_TOOL in RTEMS_CANONICALIZE_TOOLS.
* aclocal/*: Replace with contents of macros/*.m4
* macros/: Remove.
* aclocal/ar-s.m4 aclocal/tool-prefix.m4: Remove.
* Makefile.am: Reflect changes to aclocal/ and macros/.
* startup/bspstart.c: assoc.h, error.h, libio_.h, libio.h, and
libcsupport.h moved from libc to lib/include/rtems and
* startup/bspstart.c, startup/bspstart.c: assoc.h, error.h, libio_.h,
libio.h, and libcsupport.h moved from libc to lib/include/rtems and
Also removed obsolete references to STACK_CHECKER_ON.
* startup/bspstart.c, startup/bspstart.c.nocache: assoc.h, error.h,
libio_.h, libio.h, and libcsupport.h moved from libc to
lib/include/rtems and now must be referenced as <rtems/XXX.h>.
Header file order was cleaned up while doing this.
* bsplibc.c: assoc.h, error.h, libio_.h, libio.h, and
* startup/82378zb.c, startup/FPGA.c: assoc.h, error.h, libio_.h,
