commit them.
Thread_Close fixed to avoid returning FP context area when one was not
allocated at initialization time.
<jsg@coulomb.eng.ohio-state.edu> of the rest of the 68000-ish support
for interrupt handling and bfffo support, the two BSPs he submitted
(efi68k and efi332), and SGI Irix 5.3 host support.
Changed back to Newlib for Solaris UNIX simulator.
like signal dispatching.
correct Information block.
(andy@i-cubed.demon.co.uk). This initial submission is known
to work on the IBM 403. It is thought to work on the Motorola
601, 603, and 604 although this remains to be tested.
Another user -- Doug Currie (e@flavors.com) -- is interested in
this work and will be testing it on the 604 using the Metrowerks
C compiler and a different format assembly language.
incorporate variable length object names. Previously the algorithm
scanned an array of 4-byte names for a match. Now it scans the
object table, grabs a pointer to the name, and then compares it
if the object is active and has a name.
Added "0x" to printf of id
+ Added name pointer to Object_Control.
+ Modified Object Open and Close to address name field.
+ Removed name as separate element from Thread and Proxy Control.
+ Added parameter "object class" to calls to Initialize Information
+ variable length messages
+ named devices
+ debug monitor
newlib C library.
Fixed bug where length did not take into account amount added
for alignment requirements.
newlib C library.
resulted in no output when the output was redirected until this was done.
Redirection is important because runtest redirects test output.
Added support for numerous environment variables which make it easier
to run a multi-node system using a single executable and to tailor
the size of the workspace and heap.
the count to "1" to indicate availability.
Interrupt support was added.
Problem where newlib's errno "overrides" that set by system calls
was addressed.
Fixed bug which resulted in all nodes using the same semaphore although
an array of semaphores was allocated.
