* aclocal/rtems-flags.m4: New.
* bootstrap: Allow autoconf-2.57.
* stackchk/check.c: Better handling of task name.
* malloctest/init.c: Tasks should be floating point.
* setup.def, gcc3newlib/gccnewlib.add: Updated to gcc 3.2.1 RPM revision
2 which enabled the mips-rtems gnat using gcc 3.2.1 patch 20021129.
* include/rtems/score/object.h, include/rtems/score/tod.h:
Added casts to eliminate warnings on 16 bit targets like the h8300.
* include/rtems/rtems/support.h: Added casts to eliminate warnings
* include/rtems/posix/timer.h, src/keygetspecific.c,
src/posixtimespecsubtract.c, src/ptimer1.c, src/semunlink.c:
Added casts to eliminate warnings on 16-bit targets like the h8300.
* src/dosfs/fat.h, src/dosfs/msdos.h: Added casts to remove warnings
* configure.ac, network/Makefile.am: Don't build if networking disabled.
* startup/linkcmds: Add sections to remove warnings.
* include/rtems/libio.h: Internally use a union of an unsigned64
and major/minor device so we don't get into trouble shifting.
The h8300 seemed to be impossible to remove warnings otherwise.
Eventually the structure definition of a dev_t might be better anyway.
* include/sys/ioccom.h: Added casts to remove warnings on 16 bit
targets.
* src/bdbuf.c: Added cast to remove warning.
* pxfl/.cvsignore, pxfl/Makefile.in, pxfl/README,
pxfl/floss-bsp.h: Removed.
* mpc8260/Makefile.am: Merge-in mpc8260/include/Makefile.am.
* mpc8xx/Makefile.am: Merge-in mpc8xx/include/Makefile.am.
* mpc8260/include/Makefile.am: Remove.
* mpc8xx/include/Makefile.am: Remove.
* configure.ac: Remove mpc8260/include/Makefile.
Remove mpc8xx/include/Makefile.
* shared/soft_reset_asm.S: Removed.
* configure.ac: Add RTEMS_PROG_CCAS.
* bin2boot.c: #include POSIX compliant <string.h> instead of BSD
proprietary memory.h.
* aclocal/prog-cc.m4: Remove GCCSED.
* automake/compile.am: Remove LDFLAGS_INCOMPLETE.
Remove LDFLAGS.
Add CCAS, CCASCOMPILE.
Remove compilation rules for *.cpp, *.cxx, *.C.
Use CCASCOMPILE to compile *.S.
Add -pg to RTEMS_CFLAGS_PROFILE_V.
* setup.def: Updated to gcc-3.2.1.
* custom/default.cfg: Pickup target.cfg from BSP directory.
* .cvsignore: Remove.
* configure.ac: Remove.
* target.cfg.in: Remove.
* Makefile.am: Remove.
* ChangeLog: Remove.
* configure.ac: Remove c/make.
* target.cfg.in: New, copy of c/make/target.cfg.in.
* configure.ac: Add target.cfg.
* Makefile.am: Add target.cfg.
* aclocal/prog-ccas.m4: New.
* aclocal/check-custom-bsp.m4: New, split out from check-bsps.m4.
* aclocal/check-bsps.m4: Split out RTEMS_CHECK_CUSTOM_BSP.
* aclocal/canonicalize-tools.m4: Remove RTEMS_GCC_PRINT.
* setup.def: Updated to gcc-3.2 and newlib1.1.0 RPM version 6.
* gcc3newlib/gccnewlib.add: Reenabled i386-rtems gnat.
Remove *.la's to make rpm-4.1/RH-8.0 happy.
Remove libiberty.a to make rpm-4.1/RH-8.0 happy.
Change gcc/version.c to reflect us having patched gcc.
* binutils/binutils.add: Add BuildPreReq: /sbin/install-info.
Disable nls.
Apply gzip -9qf to compress *infos and *mans.
Apply /sbin/install-info.
Remove *c++-filt.
* binutils/base-binutils.add: Add PreReq: /sbin/install-info.
Package as.info-*.gz.
* binutils/target-binutils.add:
Package man1/*.1*.
* Makefile.am: Merge-in rtems/Makefile.am and sapi/Makefile.am.
* sapi/Makefile.am: Removed.
* rtems/Makefile.am: Removed.
* rel.am: Removed.
* configure.ac: Add RTEMS_BSP_CHECK_CACHE.
Reflect changes above.
* acinclude.m4: Conditionally append --target=.
* Makefile.am: Don't include @RTEMS_BSP@.cfg (unused).
* automake/compile.am: Remove CFLAGS_DEBUG_OPTIMIZE_V (Unused).
* aclocal/quoting.m4: Reworked (Part of fix to PR 312).
* configure.ac: Remove duplicate
AC_CONFIG_FILES(ts_1325_ada/Makefile).
* configure.ac: Remove RTEMS_OUTPUT_BUILD_SUBDIRS.
* configure.ac: Remove RTEMS_OUTPUT_BUILD_SUBDIRS. Cosmetical
changes.
* configure.ac: Cosmetical fixes.
* configure.ac: Fix package name.
* aclocal/sysv-ipc.m4: Adaptation to autoconf-2.5x.
* aclocal/check-newlib.m4: Sync with ../aclocal/check-newlib.m4.
* automake/compile.am: Remove LD_PATHS (Unused).
* aclocal/check-newlib.m4: Adaptation to autoconf-2.5x (AC_TRY_LINK
is announced obsolete).
* Makefile.am: Reflect having removed aclocal/sysv-ipc.m4.
* aclocal/sysv-ipc.m4: Remove (Unused).
* aclocal/target.m4: Sync with acinclude.m4 (Part of fix to PR 312).
* acinclude.m4: Lots of changes addressing PR 312.
* aclocal/target.m4: Apply RTEMS_CONFIGURE_ARGS_QUOTE (Part of fix
to PR 312).
* include/rtems/libio.h: Remove.
