* | Made this more binutils like. :) | Joel Sherrill | 1999-10-20 | 1 | -5/+9 |
* | New file. | Joel Sherrill | 1999-10-20 | 1 | -0/+104 |
* | New files. | Joel Sherrill | 1999-10-20 | 2 | -0/+285 |
* | Adding the infrastructure for gdb. | Joel Sherrill | 1999-10-20 | 10 | -47/+155 |
* | Corrected typo. | Joel Sherrill | 1999-10-20 | 1 | -3/+3 |
* | Restored joel's changes after merging old version from Ralf. | Joel Sherrill | 1999-10-20 | 1 | -19/+90 |
* | New version from Ralf. | Joel Sherrill | 1999-10-20 | 28 | -213/+3357 |
* | Committing changes before Ralf's changed. | Joel Sherrill | 1999-10-20 | 4 | -24/+92 |
* | Left to build overnight. | Joel Sherrill | 1999-10-19 | 7 | -10/+123 |
* | Made it easier to change version numbers. | Joel Sherrill | 1999-10-19 | 2 | -15/+21 |
* | Now easier to modify version numbers in scripts. | Joel Sherrill | 1999-10-19 | 2 | -14/+20 |
* | Easier to insert tool version number. | Joel Sherrill | 1999-10-19 | 2 | -20/+31 |
* | Making sparc-rtems rpms available. | Joel Sherrill | 1999-10-18 | 3 | -2/+3 |
* | Working on being able to cut RPMs. It now appears that the process | Joel Sherrill | 1999-10-18 | 12 | -27/+788 |
| | | | | | | | | | | | | | is working mostly for sparc at least. There is one major problem -- the current process generates a unique source file per RPM when in fact all of the source files are nearly the same -- it is only the spec part of the rpm which differs. The new file mkbinutils_subpackage_version is an attempt to address this. It does part of the job right -- one source file produces multiple binary RPMs. BUT the end user can not produce the resulting RPMS themselves from SRPMS unless they also build all targets. | ||||
* | Ralf Corsepius (corsepiu@faw.uni-ulm.de) submitted these scripts to | Joel Sherrill | 1999-10-15 | 7 | -0/+399 |
| | | | | help build RPMs. | ||||
* | Reorganized a lot per Jennifer's suggestions. | Joel Sherrill | 1999-10-13 | 4 | -120/+120 |
* | Updated copyright date. | Joel Sherrill | 1999-10-13 | 6 | -5/+7 |
* | More manuals and a little reorganization. | Joel Sherrill | 1999-10-13 | 1 | -5/+25 |
* | First commit of miscellaneous tools and documentation for a procedure | Joel Sherrill | 1999-10-13 | 8 | -0/+343 |
| | | | | that can be used to produce an online bookshelf of the GNU tools. | ||||
* | Made many changes to turn the outline into something more like a manual | Joel Sherrill | 1999-10-12 | 9 | -448/+1854 |
| | | | | and less like a collection of notes. | ||||
* | Dispersed. | Joel Sherrill | 1999-10-12 | 1 | -35/+0 |
* | Dispersed. | Joel Sherrill | 1999-10-12 | 1 | -324/+0 |
* | Dispersed. | Joel Sherrill | 1999-10-12 | 1 | -339/+0 |
* | New file. | Joel Sherrill | 1999-10-12 | 1 | -0/+34 |
* | Spacing. | Joel Sherrill | 1999-10-12 | 4 | -0/+4 |
* | Split null handlers table to own file and renamed. | Joel Sherrill | 1999-10-12 | 26 | -238/+60 |
| | | | | Renamed IMFS handler tables to include IMFS prefix. | ||||
* | Added rtems_filesystem_freenode() macro and added calls at appropriate | Joel Sherrill | 1999-10-12 | 52 | -280/+209 |
| | | | | | places to make sure memory allocated for filesystem specifif nodes gets freed. | ||||
* | Fixed spacing. | Joel Sherrill | 1999-10-12 | 4 | -4/+4 |
* | Corrected mistakes in the IMFS file handlers table and added the missing | Joel Sherrill | 1999-10-12 | 13 | -31/+428 |
| | | | | routine imfs_fcntl.c | ||||
* | Added call to freenod to let each filesystem free its own internal | Joel Sherrill | 1999-10-12 | 46 | -208/+697 |
| | | | | node used to manage file access. | ||||
* | Changed bcopy to strncpy to stick to ANSI/ISO routines. | Joel Sherrill | 1999-10-12 | 3 | -3/+3 |
* | Fixed random cut and paste problem. | Joel Sherrill | 1999-10-11 | 1 | -23/+23 |
* | Added files generated by index process to clean stanza. | Joel Sherrill | 1999-10-11 | 3 | -1/+5 |
* | Changed link for bad PDF files to BAD.html. | Joel Sherrill | 1999-10-11 | 1 | -2/+2 |
* | Changed version information. | Joel Sherrill | 1999-10-11 | 2 | -2/+2 |
* | Changed release information. | Joel Sherrill | 1999-10-11 | 1 | -5/+5 |
* | New files. | Joel Sherrill | 1999-10-11 | 4 | -0/+0 |
* | New file. | Joel Sherrill | 1999-10-11 | 1 | -0/+22 |
* | Corrected spacing. | Joel Sherrill | 1999-10-11 | 1 | -1/+0 |
* | Added support for @appendix and @preface. | Joel Sherrill | 1999-10-11 | 1 | -0/+12 |
* | Corrected bullet with @bullet. | Joel Sherrill | 1999-10-11 | 1 | -1/+1 |
* | Generated concept and function index entries. | Joel Sherrill | 1999-10-11 | 19 | -1171/+2626 |
* | Added descriptions. | Joel Sherrill | 1999-10-11 | 2 | -61/+88 |
* | Updated to incldue descriptions and reformatted to wrap lines better. | Joel Sherrill | 1999-10-11 | 1 | -93/+396 |
* | Added descriptions of routines to section headings. | Joel Sherrill | 1999-10-11 | 3 | -80/+80 |
* | Added descriptions. | Joel Sherrill | 1999-10-11 | 3 | -38/+66 |
* | More cleanup. | Joel Sherrill | 1999-10-11 | 8 | -63/+65 |
* | Enabled index generation. | Joel Sherrill | 1999-10-11 | 1 | -4/+4 |
* | Cleaned up to install dvi, use native texi2dvi, etc.. | Joel Sherrill | 1999-10-11 | 24 | -107/+117 |
* | Added filesystem design guide and scaling directives for the images. | Joel Sherrill | 1999-10-11 | 1 | -72/+144 |
