* | Split mqueue into multiple files. | Joel Sherrill | 1999-11-02 | 2 | -0/+56 |
* | Removed warnings. | Joel Sherrill | 1999-11-02 | 2 | -4/+4 |
* | Split mqueue.c into a variety of files. | Joel Sherrill | 1999-11-02 | 33 | -1345/+2247 |
* | Minor changes to make the screen match a bit better. | Joel Sherrill | 1999-11-02 | 4 | -8/+8 |
* | Minor fixes to make screen match a bit better. | Joel Sherrill | 1999-11-02 | 4 | -22/+30 |
* | Added more proper checking of F_GETFL and F_SETFL. | Joel Sherrill | 1999-11-02 | 2 | -10/+34 |
| | | | | | | Disabled test of F_DUPFD since it does not work. Added comment to indicate that seekdir(NULL) was being called. | ||||
* | Fixed F_SETFL to properly convert between internal | Joel Sherrill | 1999-11-02 | 3 | -6/+9 |
| | | | | libio flags and external fcntl.h style flags. | ||||
* | Added support for configuring base filesystem. First attempt at | Joel Sherrill | 1999-11-02 | 3 | -51/+123 |
| | | | | | | a full mount table at initialization. This is the wrong place to mount filesystems 2-n since no device drivers are initialized yet. | ||||
* | Install imfs.h so base filesystem can be configured or IMFS mounted | Joel Sherrill | 1999-11-02 | 1 | -1/+1 |
| | | | | by an application. | ||||
* | Check for NULL being passed in. | Joel Sherrill | 1999-11-02 | 12 | -6/+51 |
* | Fixed typo where memfile_handlers set twice and directory_handlers | Joel Sherrill | 1999-11-02 | 4 | -12/+12 |
| | | | | was not set. | ||||
* | Properly initialize location variable. | Joel Sherrill | 1999-11-02 | 4 | -0/+32 |
* | Fixed typo. | Joel Sherrill | 1999-11-02 | 1 | -1/+1 |
* | Clean up /opt/rtems in case junk is installed in the wrong place. | Joel Sherrill | 1999-11-02 | 1 | -4/+4 |
| | | | | This has been seen on some machine configurations. | ||||
* | Split console_reserve_resources into its own file to reduce dependencies. | Joel Sherrill | 1999-11-02 | 3 | -10/+30 |
| | | | | Still need to move debug io routines out. | ||||
* | Fixed bug which resulted in misaligned object control structures | Joel Sherrill | 1999-11-02 | 2 | -6/+10 |
| | | | | | being allocated. This bug manifested itself on the SPARC since it uses ldd/std in its context save/restore routines. | ||||
* | Added a comment to indicate that if a task blocked on a priority | Joel Sherrill | 1999-11-02 | 2 | -0/+10 |
| | | | | | based thread queue were to be reinserted based on its new priority, this is where the logic would go. | ||||
* | Added code to allocate by index. This is the object ID style used | Joel Sherrill | 1999-11-02 | 2 | -54/+268 |
| | | | | | | by ITRON. Corrected spacing. | ||||
* | Added maximum count detection logic. | Joel Sherrill | 1999-11-02 | 4 | -8/+32 |
* | Added support for message priority as required by POSIX. | Joel Sherrill | 1999-11-02 | 4 | -10/+86 |
* | Corrected spacing. | Joel Sherrill | 1999-11-02 | 2 | -4/+4 |
* | Added message queues and semaphores. | Joel Sherrill | 1999-11-02 | 2 | -0/+22 |
* | Added CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES and | Joel Sherrill | 1999-11-02 | 2 | -0/+48 |
| | | | | CONFIGURE_MAXIMUM_POSIX_SEMAPHORES. | ||||
* | Added comment to make sure Classic API priority to Core priority | Joel Sherrill | 1999-11-02 | 2 | -0/+2 |
| | | | | is added in the future. | ||||
* | Added comments for _RTEMS_tasks_Create_extension, | Joel Sherrill | 1999-11-02 | 2 | -8/+18 |
| | | | | | _RTEMS_tasks_Start_extension, _RTEMS_tasks_Delete_extension, and _RTEMS_tasks_Switch_extension. | ||||
* | Added a case to support the core semaphore error returned when the | Joel Sherrill | 1999-11-02 | 2 | -0/+16 |
| | | | | maximum semaphore count is exceeded. | ||||
* | Added code to utilize the maximum_count attribute of core semaphores | Joel Sherrill | 1999-11-02 | 2 | -0/+14 |
| | | | | | and initialize it to a value that would keep it from every being a problem. | ||||
* | Now much closer to working. | Joel Sherrill | 1999-11-02 | 2 | -14/+122 |
* | Added assert in case _Objects_Get_information fails since this | Joel Sherrill | 1999-11-02 | 2 | -0/+8 |
| | | | | should NEVER occur. | ||||
* | Commented out lines causing warning. | Joel Sherrill | 1999-11-02 | 2 | -0/+4 |
* | Added #define for SEM_FAILED. | Joel Sherrill | 1999-11-02 | 2 | -0/+4 |
* | Added include of <sys/siginfo.h>. | Joel Sherrill | 1999-11-02 | 2 | -0/+4 |
* | Added message queues and semaphores. | Joel Sherrill | 1999-11-02 | 2 | -2/+6 |
* | Backed out change that increased the minimum stack size since it | Joel Sherrill | 1999-11-02 | 62 | -62/+0 |
| | | | | | was unnecessary. The real fix was an alignment error in the object extend memory allocation scheme. | ||||
* | Modified to use minimum stack size and reserve the necessary amount | Joel Sherrill | 1999-11-02 | 10 | -14/+26 |
| | | | | of space in the workspace. | ||||
* | Corrected wildcard to pickup CPU model dependent library pieces. | Joel Sherrill | 1999-11-01 | 1 | -4/+2 |
* | Enabled configuring mini or full IMFS. | Joel Sherrill | 1999-11-01 | 2 | -0/+58 |
* | Added name to id support routine. | Joel Sherrill | 1999-11-01 | 2 | -0/+30 |
* | Increased stack space for all initialization tasks in tmtests. | Joel Sherrill | 1999-11-01 | 62 | -0/+62 |
* | Increased stack space of a task. | Joel Sherrill | 1999-11-01 | 4 | -6/+10 |
* | Increased stack space of task 2. | Joel Sherrill | 1999-11-01 | 4 | -4/+4 |
* | Increased stack space for a task. | Joel Sherrill | 1999-11-01 | 4 | -2/+6 |
* | Increased stack space for task 1. | Joel Sherrill | 1999-11-01 | 4 | -4/+4 |
* | Removed routines that had already been separated into their own files. | Joel Sherrill | 1999-11-01 | 2 | -1010/+0 |
* | Removed HAS_MP=no and commented out HAS_NETWORKING=no. | Joel Sherrill | 1999-11-01 | 1 | -8/+0 |
* | Removed all references to shared memory driver as it is not supported | Joel Sherrill | 1999-11-01 | 1 | -5/+0 |
| | | | | yet on the mvme2307. | ||||
* | Removed shmsupp directory as it is not really implemented. | Joel Sherrill | 1999-11-01 | 1 | -6/+1 |
* | MVME2307 does not really include MP support. | Joel Sherrill | 1999-11-01 | 5 | -311/+0 |
* | Moved the rmnod callback from the operations table to the handler table. | Jennifer Averett | 1999-10-29 | 23 | -42/+82 |
* | Joel added a table of mount entry requests to be processed during | Jennifer Averett | 1999-10-29 | 4 | -0/+56 |
| | | | | initialization. |
