* | Printed copy given to Steve and Mark | Joel Sherrill | 1998-04-10 | 4 | -17/+17 |
* | In texinfo nicely with all version dependent information | Joel Sherrill | 1998-04-10 | 8 | -177/+345 |
| | | | | now in variables and some updates already in place. | ||||
* | moved supplements under a subdirectory | Joel Sherrill | 1998-04-09 | 1 | -2/+3 |
* | Now builds clean for info, html, and ps. | Joel Sherrill | 1998-04-09 | 6 | -224/+250 |
* | base version | Joel Sherrill | 1998-04-09 | 8 | -0/+742 |
* | Increased stack space of the monitor task. | Joel Sherrill | 1998-04-06 | 3 | -3/+3 |
* | Increased stack size so test would run in debug mode. | Joel Sherrill | 1998-04-06 | 10 | -10/+12 |
* | Purged references to STACK_CHECKER_REPORT_USAGE | Joel Sherrill | 1998-04-06 | 2 | -6/+1 |
* | Purged references to STACK_CHECKER_REPORT_USAGE | Joel Sherrill | 1998-04-06 | 22 | -113/+1 |
* | Reordered CFLAGS definition so CFLAGS_DEFAULT is before | Joel Sherrill | 1998-04-06 | 2 | -4/+2 |
| | | | | | CFLAGS_$(TARGET_VARIANTS). This makes sure that -Wall appears before any individual warnings are disabled during "debug" builds. | ||||
* | More stuff removed as a result of using newlib's isatty() implementation. | Joel Sherrill | 1998-04-06 | 4 | -37/+0 |
| | | | | These were noticed by Eric Norum. | ||||
* | Changed CPU model to mcpu32. | Joel Sherrill | 1998-04-06 | 1 | -1/+1 |
* | Added stanzas for debug_tests and profile_tests. | Joel Sherrill | 1998-04-06 | 1 | -0/+6 |
* | new ids in aclocal directory | Joel Sherrill | 1998-04-06 | 0 | -0/+0 |
* | Fixed improperly named sections for info | Joel Sherrill | 1998-04-03 | 3 | -10/+10 |
* | Added test so the build procedure would stop if a directory did not exist. | Joel Sherrill | 1998-04-03 | 2 | -0/+4 |
| | | | | | This typically indicates a bug in a directory level Makefile or a configure scrip bug. | ||||
* | Removed isatty() since we are now using newlib's implementation as | Joel Sherrill | 1998-04-03 | 6 | -23/+0 |
| | | | | a result of enabling the newlib POSIX directory. | ||||
* | Made these have real constants. | Joel Sherrill | 1998-04-03 | 5 | -50/+58 |
* | Completed pass at constants. | Joel Sherrill | 1998-04-03 | 4 | -11/+11 |
* | Patch from Samuel Tardieu <sam@inf.enst.fr> so the messages printed | Joel Sherrill | 1998-04-03 | 2 | -6/+6 |
| | | | | followed GNU conventions. | ||||
* | Cleaned up installation of pictures and common html files. | Joel Sherrill | 1998-04-03 | 2 | -2/+8 |
* | Moved the terminate node since the "cprev" was being overwritten. | Joel Sherrill | 1998-04-03 | 1 | -2/+2 |
* | Moved to tools/texi2www since they are part of that distribution. | Joel Sherrill | 1998-04-03 | 4 | -0/+0 |
* | Moved from common directory since they belong to the texi2www distribution. | Joel Sherrill | 1998-04-03 | 5 | -0/+0 |
* | Removed incorrect comment. | Joel Sherrill | 1998-04-03 | 1 | -1/+0 |
* | Added texi2www to this tree | Joel Sherrill | 1998-04-03 | 2 | -3/+3 |
* | Renamed. | Joel Sherrill | 1998-04-03 | 1 | -1/+1 |
* | Nowbiulds html and ps. Info not supported. | Joel Sherrill | 1998-04-03 | 1 | -3/+4 |
* | Added shortname generation support with the capability for the user | Joel Sherrill | 1998-04-03 | 1 | -5/+37 |
| | | | | to specify the base of the name. BASEnnnn.html | ||||
* | Added fourth icon which takes user back to the index | Joel Sherrill | 1998-04-03 | 1 | -26/+43 |
* | Added -header and -dirfile options. | Joel Sherrill | 1998-04-03 | 1 | -2/+23 |
* | Base file | Joel Sherrill | 1998-04-03 | 4 | -1/+53 |
* | Changed Perl executable location | Joel Sherrill | 1998-04-03 | 2 | -2/+2 |
* | Base files from texi2www-960103 | Joel Sherrill | 1998-04-03 | 4 | -0/+2122 |
* | Added constants through ch13 | Joel Sherrill | 1998-04-02 | 11 | -446/+459 |
* | Make sure OAR logo is accessible | Joel Sherrill | 1998-04-02 | 1 | -0/+1 |
* | Added egcs 1.0.2 gcc docs | Joel Sherrill | 1998-04-02 | 1 | -1/+1 |
* | Corrected wildcard for info files | Joel Sherrill | 1998-04-02 | 1 | -1/+2 |
* | Went back to not printing an index. makeinfo does fine if you have indices | Joel Sherrill | 1998-04-02 | 2 | -5/+7 |
| | | | | but do not print them. texi2dvi barfs if the entries are even there. | ||||
* | Added "findex" for all directive pages but it turns out that this | Joel Sherrill | 1998-04-02 | 18 | -4/+98 |
| | | | | blows up both makeinfo and texi2dvi. So I have commented them out. | ||||
* | Added copy of HELP.html. | Joel Sherrill | 1998-04-02 | 1 | -1/+1 |
* | Added newlib to support and ada_user to internal. | Joel Sherrill | 1998-04-02 | 1 | -2/+2 |
* | changed version to 4.0.0-beta2 | Joel Sherrill | 1998-03-31 | 2 | -2/+2 |
* | Fixed CUSTOM_FILES rule so it properly picked up files included from | Joel Sherrill | 1998-03-31 | 1 | -2/+11 |
| | | | | make/custom files. | ||||
* | Make.config | Joel Sherrill | 1998-03-31 | 1 | -1/+3 |
* | Added "sigemptyset()" call to insure that the memcmp() would work. | Joel Sherrill | 1998-03-31 | 2 | -0/+8 |
| | | | | | It appears that the new glibc does not clear all the bits of the signal set with a sigprocmask. | ||||
* | Taking care of minor build problems | Joel Sherrill | 1998-03-30 | 4 | -6/+5 |
* | Making the stanza right and improving the way the isntall directories are built | Joel Sherrill | 1998-03-30 | 15 | -218/+115 |
* | Corrected distribution levels for html | Joel Sherrill | 1998-03-30 | 14 | -15/+19 |
* | Added distribution level to each manual | Joel Sherrill | 1998-03-30 | 13 | -20/+39 |
