Simplify _RBTree_Find_control(). Avoid superfluous NULL pointer checks.
Only use the parent pointer, since this pointer is never NULL for nodes
which are part of a tree.
Rename functions from *_off_rbtree() to *_off_tree().
The test sptests/sp35 showed a NULL pointer access due to an invalid
maximum node field (e.g. a tree with one element and NULL as the maximum
node).
This lays the proper structure for doing future work on
time adjustment algorithms. Any TOD adjustments should be
requested at the API level and performed at the SCORE level.
Additionally updated a test.
The first pass at building these was without networking enabled.
This pass addresses that plus accounts for some new BSPs which
needed testsuite.tcfg files and BSPs which could not link tests
which had been added since the first pass.
When a thread is removed from a thread queue or is unblocked
by receiving an event, the same actions are required.
+ timeout watchdog canceled,
+ thread must be unblocked, and
+ (MP only) proxy cleaned up
This patch makes sure there is only one copy of this code.
There was a lot of duplication between the discipline subroutines.
With the transition to RBTrees for priority discipline, there were
only a few lines of source code manipulating the data structure
for FIFO and priority. Thus is made sense to fold these back
into the main methods.
As part of doing this all of the tests for discipline were changed
to be in the same order.
Remove compare function and is unique indicator from the control
structure. Rename RBTree_Compare_function to RBTree_Compare. Rename
rtems_rbtree_compare_function to rtems_rbtree_compare. Provide C++
compatible initializers. Add compare function and is unique indicator
to _RBTree_Find(), _RBTree_Insert(), rtems_rbtree_find() and
rtems_rbtree_insert(). Remove _RBTree_Is_unique() and
rtems_rbtree_is_unique(). Remove compare function and is unique
indicator from _RBTree_Initialize_empty() and
rtems_rbtree_initialize_empty().
All,
This patch is submitted as its values are used in my to-be-submitted
beagle bsp.
tm02 and tm03 were modified to be reused for multiple configurations
of RTEMS Classic API Semaphores. This added tm31-36. The messages for
tm02 and tm03 were modified to indicate the semaphore attributes.
tm31 - tm36 were added. This resulted in the following cases:
tm02 - rtems_semaphore_obtain: Counting/FIFO not available caller blocks
tm03 - rtems_semaphore_release: Counting/FIFO task readied preempts caller
tm31 - rtems_semaphore_obtain: Counting/priority not available caller blocks
tm32 - rtems_semaphore_release: Counting/priority task readied preempts caller
tm33 - rtems_semaphore_obtain: Binary/FIFO not available caller blocks
tm34 - rtems_semaphore_release: Binary/FIFO task readied preempts caller
tm35 - rtems_semaphore_obtain: Binary/priority not available caller blocks
tm36 - rtems_semaphore_release: Binary/priority task readied preempts caller
This test verifies priority is inherited from a high priority
semaphore by a lower priority task.
This test uses a combination of priority and affinity to cause
the tasks running on all 4 cores to change due to one task priority
change.
This test walks a secondary high prority task across
all the cores.
This task walks the affinity of self across all the cores.
This test checks setting the affinity of a secondary task
on a two core system.
This test verifies that affinity is honored when set prior to task start.
Doxygen added and comment blocks standardized.
The priority affinity scheduler has the nice property that it can
produce more than one scheduled to ready state change in one operation.
Each scheduled to ready state change may lead to one thread in need for
help. Since it is currently only possible to return at most one thread
in need for help, we have a problem here.
A solution might be to move the check for migrations into the ask for
help mechanism.
Do not extract the idle threads from the ready set so that there is
always a thread available for comparison.
Switch to using awk to get a string of spaces.
This prevents failures of all tests using rtems_shell_wait_for_input(),
e.g. capture, termios, pppd, etc.
Move the APBUART console driver support to the shared SPARC area so that
it can be reused by other BSPs. Only the console driver initialization
is now BSP specific.
