On a public interface, the stack pointer must be aligned on an 8-byte
boundary. However, it may temporarily be only aligned on a 4-byte
boundary. The interrupt handling code must ensure that the stack
pointer is properly aligned before it calls a function. See also:
https://developer.arm.com/documentation/den0013/d/Interrupt-Handling/External-interrupt-requests/Nested-interrupt-handling
Update #4579.
Update #4579.
Use volatile register r0 for the per-CPU control of the current
processor instead of the non-volatile register r7. This enables the use
of r7 in a follow up patch. Do the interrupt handling in ARM mode.
Update #4579.
Update #4579.
Most BSPs which used the stubbed benachmark timer provide a CPU counter.
All BSPs provide at least a stub CPU counter. Simply use the benchmark
timer implementation using the CPU counter.
Use rtems_shell_wait_for_input() similar to other potentially
interactive test programs.
A device tree blob must be aligned on an 8-byte boundary.
Always start the executive in Exception Level 1, Non-Secure mode.
If we boot in EL3 Secure with GICv3 then we have to initialize
the distributor and redistributor to set up G1NS interrupts
early in the boot sequence before stepping down from EL3S to EL1NS.
Now there is no need to distinguish between secure and non-secure
world execution after the primary core boots, so get rid of the
AARCH64_IS_NONSECURE configuration option.
The test runner checks that there are no pending events after a test
case.
Update #3269.
Use the stack pointer to check if we have to return the real device tree
since bsp_fdt_get() may get called before the BSS is cleared to zero.
Make sure there are no pending events after a test case.
Update #4572.
Closes #4302.
close() file 'bf' to avoid leaking descriptor.
CID 1437645: Resource leak in rtems_fdt_load().
Closes #4297
This is done to get the target path for the overlay nodes which is very useful
in many cases. For example, Xen hypervisor needs it when applying overlays
because Xen needs to do further processing of the overlay nodes, e.g. mapping of
resources(IRQs and IOMMUs) to other VMs, creation of SMMU pagetables, etc.
Signed-off-by: Vikram Garhwal <fnu.vikram@xilinx.com>
Message-Id: <1637204036-382159-2-git-send-email-fnu.vikram@xilinx.com>
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
UINT32_MAX is an integer of type unsigned int. UINT32_MAX + 1 overflows
unless explicitly computed as unsigned long long. This led to some
invalid addresses being treated as valid.
Cast UINT32_MAX to uint64_t explicitly.
Signed-off-by: Elvira Khabirova <e.khabirova@omp.ru>
The ALIGNMENT error was missing a string, leading to <unknown error>
being returned.
Signed-off-by: Georg Kotheimer <georg.kotheimer@kernkonzept.com>
With -Wsign-compare, compilers warn about a mismatching signedness in
the different legs of the conditional operator, in fdtget.c.
In the questionable expression, we are constructing a 16-bit value out of
two unsigned 8-bit values, however are relying on the compiler's
automatic expansion of the uint8_t to a larger type, to survive the left
shift. This larger type happens to be an "int", so this part of the
expression becomes signed.
Fix this by explicitly blowing up the uint8_t to a larger *unsigned* type,
before doing the left shift. And while we are at it, convert the hardly
readable conditional operator usage into a sane switch/case expression.
This fixes "make fdtget", when compiled with -Wsign-compare.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Message-Id: <20210618172030.9684-3-andre.przywara@arm.com>
Coverity gets a bit confused by loading fdt_size_dt_strings() and
using it in a memmove(). In fact this is safe because the callers
have verified this information (via FDT_RW_PROBE() in fdt_pack() or
construction in fdt_open_into()).
Passing in strings_size like we already do struct_size seems to get
Coverity to follow what's going on here.
Only checking the FDT alignment in fdt_ro_probe_() means that
fdt_check_header() can pass, but then subsequent API calls fail on
alignment checks. Let's add an alignment check to fdt_check_header() so
alignment errors are found up front.
Cc: Tom Rini <trini@konsulko.com>
Cc: Frank Rowand <frowand.list@gmail.com>
Signed-off-by: Rob Herring <robh@kernel.org>
Message-Id: <20210406190712.2118098-1-robh@kernel.org>
Apparently the unchecked return value of the first fdt_next_tag() call in
fdt_add_subnode_namelen() is tripping Coverity Scan in some circumstances,
although it appears not to for the scan on our project itself.
This fdt_next_tag() should always return FDT_BEGIN_NODE, since otherwise
the fdt_subnode_offset_namelen() above would have returned BADOFFSET or
BADSTRUCTURE.
Still, add a check to shut Coverity up, gated by a can_assume() to avoid
bloat in small builds.
Reported-by: Ryan Long <ryan.long@oarcorp.com>
in fdt_open_into
Changes in v3:
- Remove noop version sets
- Set version correctly on loaded fdt in fdt_open_into
Fixes: f1879e1a50eb ("Add limited read-only support for older (V2 and V3) device tree to libfdt.")
Signed-off-by: Justin Covell <jujugoboom@gmail.com>
Message-Id: <20201229041749.2187-1-jujugoboom@gmail.com>
There's a small inaccuracy in the comment describing these new helpers.
This corrects it, and reformats while we're there.
Fixes: f98f28ab ("libfdt: Internally perform potentially unaligned loads")
Commits 6dcb8ba4 "libfdt: Add helpers for accessing unaligned words"
introduced changes to support unaligned reads for ARM platforms and
11738cf01f15 "libfdt: Don't use memcpy to handle unaligned reads on ARM"
improved the performance of these helpers.
On further discussion, while there are potential cases where we could be
used on platforms that do not fixup unaligned reads for us, making this
choice the default is very expensive in terms of binary size and access
time. To address this, introduce and use new fdt{32,64}_ld_ functions
that call fdt{32,64}_to_cpu() as was done prior to the above mentioned
commits. Leave the existing load functions as unaligned-safe and
include comments in both cases.
Reviewed-by: Rob Herring <robh@kernel.org>
Signed-off-by: Tom Rini <trini@konsulko.com>
Message-Id: <20201211022736.31657-1-trini@konsulko.com>
Tested-by: John Paul Adrian Glaubitz <glaubitz@physik.fu-berlin.de>
The device tree must be loaded in to memory at an 8-byte aligned
address. Add a check for this condition in fdt_ro_probe_() and a new
error code to return if we are not.
Message-Id: <20201104130605.28874-1-trini@konsulko.com>
The API documentation in libfdt.h seems to follow the Linux kernel's
kernel-doc format[1].
Running "scripts/kernel-doc -v -none" on the file reports some problems,
mostly missing return values and missing parameter descriptions.
Fix those up by providing the missing bits, and fixing the other small
issues reported by the script.
[1] https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/Documentation/doc-guide/kernel-doc.rst
Message-Id: <20201012165331.25016-1-andre.przywara@arm.com>
in a comparison in fdt_strerror().
Force FDT_ERRTABSIZE to be signed (it's surely small enough to fit), so
that the types match. Also move the minus sign to errval, as this is
actually what we use in the next line.
Message-Id: <20201001164630.4980-7-andre.przywara@arm.com>
comparisons in fdt_get_string().
Introduce a new usigned variable, which holds the actual (negated)
stroffset value, so we avoid negating all the other variables and have
proper types everywhere.
Message-Id: <20201001164630.4980-6-andre.przywara@arm.com>
in a comparison in fdt_setprop_inplace_namelen_partial().
fdt_getprop_namelen() will only return negative error values in "proplen"
if the return value is NULL. So we can rely on "proplen" being positive
in our case and can safely cast it to an unsigned type.
Message-Id: <20201001164630.4980-5-andre.przywara@arm.com>
in a comparison in fdt_create_with_flags().
By making hdrsize a signed integer (we are sure it's a very small
number), we avoid all the casts and have matching types.
Message-Id: <20201001164630.4980-4-andre.przywara@arm.com>
in comparisons in fdt_move().
This stems from "bufsize" being passed in as a signed integer, even
though we would expect a buffer size to be positive.
Short of changing the prototype, check that bufsize is not negative, and
cast it to an unsigned type in the comparison.
Message-Id: <20201001164630.4980-3-andre.przywara@arm.com>
in a comparison in fdt_add_string_().
Make all variables unsigned, and express the negative offset trick via
subtractions in the code.
Message-Id: <20201001164630.4980-2-andre.przywara@arm.com>
in a comparison in fdt_node_offset_by_phandle().
Uses a better suited bitwise NOT operator to denote the special value of
-1, which automatically results in an unsigned type.
Message-Id: <20200921165303.9115-14-andre.przywara@arm.com>
in a comparison in fdt_resize().
A negative buffer size will surely do us no good, so let's rule this
case out first.
In the actual comparison we then know that a cast to an unsigned type is
safe.
Message-Id: <20200921165303.9115-10-andre.przywara@arm.com>
in a comparison in fdt_splice_().
Since we just established that oldlen is not negative, we can safely
Message-Id: <20200921165303.9115-8-andre.przywara@arm.com>
In the first two cases, we have just established that the signed values
are not negative, so it's safe to cast the values to an unsigned type.
Signed-off-by: Simon Glass <sjg@chromium.org>
Message-Id: <20200921165303.9115-7-andre.przywara@arm.com>
in a comparison in fdt_grab_space_().
All the involved values cannot be negative, so let's switch the types of
the local variables to unsigned to make the compiler happy.
Message-Id: <20200921165303.9115-4-andre.przywara@arm.com>
in comparisons in fdt_mem_rsv().
Since all involved values must be positive, change the used types to be
unsigned.
Message-Id: <20200921165303.9115-3-andre.przywara@arm.com>
With -Wsign-compare, compilers warn about mismatching signedness in
comparisons in fdt_offset_ptr().
This mostly stems from "offset" being passed in as a signed integer,
even though the function would not really tolerate negative values.
Short of changing the prototype, check that offset is not negative, and
use an unsigned type internally.
Message-Id: <20200921165303.9115-2-andre.przywara@arm.com>
fdt_check_node_offset_() checks for a valid offset but also changes the
offset by calling fdt_next_tag(). Hence, do not skip this function if
ASSUME_VALID_INPUT is set but only omit the initial offset check in that
case.
As this function works very similar to fdt_check_prop_offset_(), do the
offset check there as well depending on ASSUME_VALID_INPUT.
Message-Id: <1913141.TlUzK5foHS@noys4>
Signed-off-by: Patrick Oppenlander <patrick.oppenlander@gmail.com>
Message-Id: <20200616011217.15253-1-patrick.oppenlander@gmail.com>
Message-Id: <20200618042117.131731-1-patrick.oppenlander@gmail.com>
