#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Some imx chips or boards don't use the same frequency for ECSPI and IPG.
Update #3869
- Fix the passing of std[in/out] to child threads
- Fix deleting of managed memory in the key destructor
- Only set the key in the main loop thread
- Only allocate a shell env outside of the main loop
- Fix memory leak if the task start fails
- Remove error level from shell env, it cannot be returned this way. Add
exit_code but the API is broken so it cannot be returned.
Closes #3859
Update #3875.
Close #3949.
Update #3949.
1) _Memory_Initialize makes pointer from integer
without a cast.
2) printf format error, expects %u but %lu provided.
Delete unused RTEMS_DECLARE_GLOBAL_SYMBOL().
Update #3799.
In the previous implementation, the _ISR_Stack_area_begin and
_ISR_Stack_area_end symbols were in different sections. If they do not
have the same alignment, then the following linker directive could
separate them:
*(SORT_BY_ALIGNMENT (SORT_BY_NAME (.rtemsstack*)))
Do not use different sections and instead define _ISR_Stack_area_end
directly.
Update #3799.
Update #3799.
Updates #3938.
Updates #3938.
Updates #3938.
Updates #3938.
Updates #3938.
Updates #3938.
Update #3938.
Update #3938.
Closes #3936.
This reverts commit 8e80876bdd54e36fb668eee655eec1dd588daf13
which broke several architectures.
Fixes #3903
The _ISR_Stack_area_begin and _ISR_Stack_area_end symbols are in
different sections. They must have the same alignment, otherwise the
following linker directive could separate them:
Update #3799.
CLOCK_DRIVER_ISRS_PER_TICK is the configuration define,
CLOCK_DRIVER_ISRS_PER_TICK_VALUE is the actual value of ISRS per clock
tick, therefore use this one to reset the Clock_driver_isrs after each
tick.
Statically initialize the ARMv7-M vector table to allow a placement in
ROM with read-only MPU settings.
Change licence to BSD-2-Clause in some files.
Remove the following undocumented configuration options:
* CONFIGURE_FILESYSTEM_ENTRY_DOSFS
* CONFIGURE_FILESYSTEM_ENTRY_FTPFS
* CONFIGURE_FILESYSTEM_ENTRY_IMFS
* CONFIGURE_FILESYSTEM_ENTRY_JFFS2
* CONFIGURE_FILESYSTEM_ENTRY_NFS
* CONFIGURE_FILESYSTEM_ENTRY_RFS
* CONFIGURE_FILESYSTEM_ENTRY_TFTPFS
Update #3836.
This type is unused. Do not mention non-existing
CONFIGURE_FILESYSTEM_MINIIMFS.
Close #3921.
This configuration option is obsolete since 2014.
Update #1367.
This filesystem no longer exists.
Remove unused RTEMS_FILESYSTEM_TYPE_DEVFS.
Update #3894.
These defines are not used and easily conflict with application code.
They are also defined by the standard header file <arpa/ftp.h> if
someone needs them.
Do not undefine this unused BSP configuration option. This is a follow
up of commit 92b33b8d09377feb14eb5a831ce242047c58d02b.
On most architectures, the size of the thread-local storage TCB must be
8 bytes. Fix the definition for 64-bit targets.
Add a test case which requires the use of __tls_guard() and
__tls_init().
Change license to BSD-2-Clause.
Check for configuration errors earlier. Allow fatal dumps without the
other extensions. Add some warnings.
Update #3904.
Closes #3611.
Add rtems_record_dump_base64() and rtems_record_dump_base64_zlib().
Add CONFIGURE_RECORD_FATAL_DUMP_BASE64 and
CONFIGURE_RECORD_FATAL_DUMP_BASE64_ZLIB configuration options.
Update #3904.
Update #3904.
Update #3904.
This fixes linker issues on the powerpc/virtex4 and powerpc/virtex5
BSPs.
There was a race conditon in the reference counting of file descriptors
during a close() operation. After the call to the close handler, the
rtems_libio_free() function cleared the flags to zero. However, at this
point in time there may still exist some holders of the file descriptor.
With RTEMS_DEBUG enabled this could lead to failed assertions in
rtems_libio_iop_drop().
Change the code to use only atomic read-modify-write operations on the
rtems_libio_iop::flags.
