* VERSION: 4.6.99.0.
* aclocal/version.m4: 4.6.99.0.
* configure.ac: RTEMS_CHECK_BSPDIR([$RTEMS_BSP_FAMILY]).
* Makefile.am: include local.am.
* configure.ac, setup, setup.def: Remove now unused vars.
* mkgccnewlibspec.in, gccnewlib/.cvsignore, gccnewlib/HISTORY,
gccnewlib/Makefile.am, gccnewlib/README, gccnewlib/base-chill.add,
gccnewlib/base-g77.add, gccnewlib/base-gcc.add, gccnewlib/base-gcj.add,
gccnewlib/gccnewlib.add, gccnewlib/header.add,
gccnewlib/target-chill.add, gccnewlib/target-g77.add,
gccnewlib/target-gcc.add, gccnewlib/target-gcj.add,
gccnewlib/target-objc.add: Remove (Obsolete).
* configure.ac, Makefile.am: Reflect changes above.
* gcc3newlib/gcc3newlib.add: Remove info/dir.
Cosmetics.
* Makefile.am: Don't include host.am.
* automake/compile.am: Further cleanups.
* automake/lib.am: Remove (Unused).
* Makefile.am: Cosmetics.
* setup.def: Adapt to what Joel already ships -
gcc3_version=3.3.2, gcc3_patch_version=20031216,
gcc3newlib_rpm_release=3
* wrapup/Makefile.am: Don't include lib.am.
* automake/compile.am: Use automake compilation rules.
* Makefile.am: Use CPPASCOMPILE instead of CCASCOMPILE.
* Makefile.am: Add start*.bin to CLEANFILES.
* Makefile.am: Remove startup/linkcmds.
* Makefile.am: Don't include lib.am.
* configure.ac: Remove rtemsdoc/mkspec. Add RTEMS_RPM_RELEASE.
* rtemsdoc/.cvsignore: Reformat.
* Makefile.am: Reformat. Add RTEMS_RPM_RELEASE support to
rtems-source.add, Use rtems_source_spec_DEPS instead of
rtems_source_spec_DEPENDENCIES (Conflicts with automake internals).
* rtems/rtems-source.add: Add RTEMS_RPM_RELEASE.
* rtemsdoc/mkspec.in: Remove.
* rtemsdoc/Makefile.am: Reworked.
* rtemsdoc/header.add: Update Copyright notice.
* rtemsdoc/rtemsdoc.add: Add RTEMS_RPM_RELEASE.
Add %{rpmgroup}. Remove bzip-ing *.ps.
* rtemsdoc/supplement.add.in: Add %{rpmgroup}.
* rtemsdoc/templ.add.in: Add %{rpmgroup}.
PR 575/bsps
* startup/linkcmds: Remove.
PR 565/rtems
* asm.h: Various hacks.
* libnetworking/pppd/Makefile.am,
libnetworking/rtems_servers/Makefile.am,
libnetworking/rtems_telnetd/Makefile.am,
libnetworking/rtems_webserver/Makefile.am, optman/Makefile.am,
support/Makefile.am: Don't include lib.am.
* libchip/Makefile.am: Don't include lib.am.
* librdbg/src/i386/Makefile.am, librdbg/src/m68k/Makefile.am,
librdbg/src/powerpc/Makefile.am: Don't include lib.am. Remove
unnecessary EXTRA_DISTs.
* Index: m68040/Makefile.am, mcf5206/Makefile.am, shared/Makefile.am:
* wrapup/Makefile.am: Convert to automake-building rules.
* libnetworking/Makefile.am: Remove ACLOCAL_AMFLAGS.
* rtems/rtems-source.add: Require automake-1.8.2, autoconf-2.59.
* rtems/rtems-source.add: New.
* Makefile.am: Add rtems/rtems-source.spec handling.
* configure.ac: AC_SUBST(RTEMS_VERSION,[_RTEMS_VERSION]).
* common/common.add.in: Use www.rtems.com as Vendor.
* Makefile.am: Add $(TMPINSTALL_FILES) to all-local.
* vectors/vectors.h: Force globalExceptHdl into bss section.
* Makefile.am: Add irq.h and vectors.h
* aclocal/bsp-alias.m4: Readd aliases for p4600 and p4650
which were accidentally removed when purging the mips64orion.
* Makefile.am: Split startup into multiple .rels without reorganizing
the source.
* configure.ac: Add powerpc's <bsp>/wrapup/Makefile.am detection
hack.
* mpc505/Makefile.am, mpc6xx/Makefile.am, mpc8260/Makefile.am,
mpc8xx/Makefile.am, ppc403/Makefile.am: Don't include .../lib.am.
* Makefile.am: Don't include .../lib.am.
* i960ca/Makefile.am, i960ka/Makefile.am, i960rp/Makefile.am: Don't
include .../lib.am.
* sh7032/Makefile.am, sh7045/Makefile.am, sh7750/Makefile.am: Don't
include .../lib.am.
* mongoosev/Makefile.am, r46xx/Makefile.am, tx39/Makefile.am:
Don't include .../lib.am. Remove ACLOCAL_AMFLAGS.
* shared/Makefile.am: Don't include .../lib.am.
* Makefile.am: Pickup files from ../../sparc/shared instead of
../shared. Reformat.
* Makefile.am: Pickup files from ../../c4x/shared instead of
* Makefile.am: Pickup files from ../../arm/shared instead of
* Makefile.am: Pickup files from ../../sh/shared instead of
