* 2004-03-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-03-2522-11/+59
| | | | * configure.ac: Add 2nd arg to RTEMS_TOP.
* 2004-03-25 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-254-10/+12
| | | | | | | | * configure.ac: Add 2nd arg to RTEMS_TOP. Unconditionally configure MP-directories. * Makefile.am: Don't include @RTEMS_BSP@.cfg. Add DIST_SUBDIRS comprising MP-subdirs. * samples/Makefile.am: Add DIST_SUBDIRS comprising MP-subdirs.
* 2004-03-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-03-252-3/+7
| | | | * autotools/automake-rtems.spec.in: Upgrade to 1.8.3.
* 2004-03-23 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-2323-52/+70
| | | | | | | | | | | | | | | | | | * itron/include/itronsys/mbox.h, itron/include/itronsys/types.h, itron/include/rtems/itron/eventflags.h, itron/include/rtems/itron/fmempool.h, itron/include/rtems/itron/mbox.h, itron/include/rtems/itron/msgbuffer.h, itron/include/rtems/itron/port.h, itron/include/rtems/itron/semaphore.h, itron/include/rtems/itron/task.h, itron/include/rtems/itron/vmempool.h, itron/inline/rtems/itron/semaphore.inl, itron/macros/rtems/itron/semaphore.inl, itron/src/eventflags.c, itron/src/fmempool.c, itron/src/itronsem.c, itron/src/mbox.c, itron/src/msgbuffer.c, itron/src/port.c, itron/src/snd_mbx.c, itron/src/task.c, itron/src/trcv_mbx.c, itron/src/vmempool.c: Convert to using c99 fixed size types.
* 2004-03-23 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-2331-65/+86
| | | | | | | | | | | | | | | | | | | | | * posix/include/rtems/posix/cond.h, posix/include/rtems/posix/intr.h, posix/include/rtems/posix/key.h, posix/include/rtems/posix/mqueue.h, posix/include/rtems/posix/mutex.h, posix/include/rtems/posix/pthread.h, posix/include/rtems/posix/semaphore.h, posix/include/rtems/posix/threadsup.h, posix/include/rtems/posix/timer.h, posix/src/cond.c, posix/src/intr.c, posix/src/key.c, posix/src/keycreate.c, posix/src/keydelete.c, posix/src/keygetspecific.c, posix/src/keyrundestructors.c, posix/src/keysetspecific.c, posix/src/killinfo.c, posix/src/mqueue.c, posix/src/mqueuerecvsupp.c, posix/src/mqueuesendsupp.c, posix/src/mqueuetranslatereturncode.c, posix/src/mutex.c, posix/src/posixintervaltotimespec.c, posix/src/posixtimespecsubtract.c, posix/src/psignal.c, posix/src/pthread.c, posix/src/ptimer1.c, posix/src/semaphore.c, posix/src/sysconf.c: Convert to using c99 fixed size types.
* 2004-03-23 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-232-1/+6
| | | | * score/include/rtems/system.h: include <stdint.h>.
* 2004-03-23 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-232-1153/+5
| | | | | PR/589 rtems * libchip/network/pci.h: Remove (Moved to cpukit).
* 2004-03-23 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-232-0/+1158
| | | | | PR/589 rtems * include/rtems/pci.h: New (Moved from c/src/libchip/network/pci.h).
* 2004-03-23 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-232-3/+7
| | | | * libcsupport/src/malloc.c: Remove lvalue casts.
* 2004-03-23 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-2351-497/+520
| | | | | | | | | | | | | | | | | | | | | | | | | | * libchip/ide/ata.c, libchip/ide/ata_internal.h, libchip/ide/ide_controller.c, libchip/ide/ide_ctrl_cfg.h, libchip/ide/ide_ctrl_io.h, libchip/network/cs8900.c, libchip/network/dec21140.c, libchip/network/elnk.c, libchip/network/if_fxp.c, libchip/network/open_eth.c, libchip/network/open_eth.h, libchip/network/sonic.c, libchip/network/sonic.h, libchip/rtc/icm7170.c, libchip/rtc/icm7170.h, libchip/rtc/icm7170_reg.c, libchip/rtc/icm7170_reg2.c, libchip/rtc/icm7170_reg4.c, libchip/rtc/icm7170_reg8.c, libchip/rtc/m48t08.c, libchip/rtc/m48t08.h, libchip/rtc/m48t08_reg.c, libchip/rtc/m48t08_reg2.c, libchip/rtc/m48t08_reg4.c, libchip/rtc/m48t08_reg8.c, libchip/rtc/rtc.h, libchip/serial/mc68681.c, libchip/serial/mc68681.h, libchip/serial/mc68681_reg.c, libchip/serial/mc68681_reg2.c, libchip/serial/mc68681_reg4.c, libchip/serial/mc68681_reg8.c, libchip/serial/ns16550.c, libchip/serial/ns16550_p.h, libchip/serial/serial.h, libchip/serial/z85c30.c, libchip/serial/z85c30.h, libchip/serial/z85c30_p.h, libchip/serial/z85c30_reg.c, libchip/shmdr/addlq.c, libchip/shmdr/cnvpkt.c, libchip/shmdr/dump.c, libchip/shmdr/fatal.c, libchip/shmdr/getlq.c, libchip/shmdr/init.c, libchip/shmdr/initlq.c, libchip/shmdr/intr.c, libchip/shmdr/poll.c, libchip/shmdr/send.c, libchip/shmdr/shm_driver.h: Convert to using c99 fixed-size types.
* 2004-03-23 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-2325-168/+186
| | | | | | | | | | | | | | | | | | * libcsupport/include/chain.h, libcsupport/include/clockdrv.h, libcsupport/include/ringbuf.h, libcsupport/include/spurious.h, libcsupport/include/timerdrv.h, libcsupport/include/vmeintr.h, libcsupport/include/motorola/mc68230.h, libcsupport/include/rtems/assoc.h, libcsupport/include/rtems/libio.h, libcsupport/include/rtems/libio_.h, libcsupport/include/rtems/termiostypes.h, libcsupport/include/zilog/z8036.h, libcsupport/include/zilog/z8530.h, libcsupport/include/zilog/z8536.h, libcsupport/src/__gettod.c, libcsupport/src/assoc.c, libcsupport/src/assocnamebad.c, libcsupport/src/error.c, libcsupport/src/libio.c, libcsupport/src/libio_sockets.c, libcsupport/src/malloc.c, libcsupport/src/no_libc.c, libcsupport/src/termios.c, libcsupport/src/termiosreserveresources.c: Convert to using c99 fixed-size types.
* 2004-03-22 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-2219-369/+382
| | | | | | | | | | | | | * libfs/src/dosfs/fat.c, libfs/src/dosfs/fat.h, libfs/src/dosfs/fat_fat_operations.c, libfs/src/dosfs/fat_fat_operations.h, libfs/src/dosfs/fat_file.c, libfs/src/dosfs/fat_file.h, libfs/src/dosfs/msdos.h, libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_file.c, libfs/src/dosfs/msdos_initsupp.c, libfs/src/dosfs/msdos_misc.c, libfs/src/imfs/deviceio.c, libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_directory.c, libfs/src/imfs/imfs_fchmod.c, libfs/src/imfs/linearfile.c, libfs/src/imfs/memfile.c: Convert to using c99 fixed-size types.
* 2004-03-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-03-186-34/+56
| | | | | | | | * gcc3newlib/gccnewlib.add: Disable gnats. Further preparations for gcc-3.4.0 * gcc3newlib/base-gcc.add, gcc3newlib/target-gnat.add, gcc3newlib/base-gcj.add, gcc3newlib/target-gcj.add: Reflect changes to gcc3newlib/gccnewlib.add.
* 2004-03-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-03-184-9/+20
| | | | | | * gcc3newlib/base-gcc.add, gcc3newlib/target-g77.add, gcc3newlib/target-objc.add: Preps for gcc-3.4.0. Reflect changes to gcc3newlib/gccnewlib.add.
* 2004-03-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-03-173-6/+17
| | | | | * gcc3newlib/target-gcc.add, gcc3newlib/target-c++.add: Reflect changes to gcc3newlib/gccnewlib.add.
* 2004-03-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-03-172-6/+26
| | | | | * gcc3newlib/gccnewlib.add: Preps. for gcc-3.4.0. Add %gcclib, %gccexec.
* 2004-03-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-03-152-11/+11
| | | | * binutils/base-binutils.add: Preparations for binutils-2.15.
* CS8900 driver updates.Chris Johns2004-03-141-0/+13
* Updated the BSP example code.Chris Johns2004-03-142-186/+442
* Changes made to support the DIMMPC. This is a pc396 target with IO portChris Johns2004-03-142-304/+607
| | | | | | support. Minor formating clean up. Add documentation to the header file.
* The CS8900 driver is documented in the cs8900.h header file.Chris Johns2004-03-141-17/+2
* 2004-03-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-03-092-0/+6
| | | | | * README: Add "mpc5xx (mpc565)", because Wilfried B. mentioned the mpc5xx being used on mpc565.
* 2004-03-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-03-092-2/+7
| | | | * configure.ac: SIZE, NM, OBJCOPY.
* 2004-03-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-03-092-11/+13
| | | | | * libchip/network/dec21140.c: Use __PPC__ instead of __PPC. Cosmetics.
* 2004-03-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-03-092-3/+5
| | | | | * aclocal/canonicalize-tools.m4: Revert Joel's 2004-03-04's patch. There are no application level Makefiles in here.
* Remove refs to Makefile*.Ralf Corsepius2004-03-0949-98/+0
* Unused.Ralf Corsepius2004-03-096-12/+0
* Unused.Ralf Corsepius2004-03-08186-372/+0
* 2004-03-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-03-083-0/+24
| | | | | | PR 587/bsps * shared/include/cpuIdent.h, shared/include/cpuIdent.c: Add defines for MPC_5XX.
* 2004-03-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-03-083-2/+10
| | | | * Makefile.am, configure.ac: Reflect having added mpc5xx.
* 2004-03-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-03-089-0/+773
| | | | | | | | * mpc5xx/.cvsignore, mpc5xx/Makefile.am: New. * mpc5xx/exceptions/asm_utils.S, mpc5xx/exceptions/raw_exception.c, mpc5xx/exceptions/raw_exception.h, mpc5xx/ictrl/ictrl.c, mpc5xx/ictrl/ictrl.h, mpc5xx/timer/timer.c: New (Submission from Wilfried Busalski <w.busalski@lancier-monitoring.de>).
* UnusedRalf Corsepius2004-03-083-6/+0
* UnusedRalf Corsepius2004-03-085-10/+0
* 2004-03-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-03-052-1/+5
| | | | * libnetworking/net/radix.c: Remove warning.
* 2004-03-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-03-052-7/+6
| | | | | * custom/p4650.cfg: Remove obsolete variables and get closer to gcc 3.x support.
| | | | * libmisc/shell/cmds.c: Remove warning.
* 2004-03-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-03-052-0/+8
| | | | | * aclocal/canonicalize-tools.m4: Add SIZE, NM, and OBJCOPY so they can be used in application level makefiles.
* 2004-03-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-03-052-2/+6
| | | | * sp07/buffered_io.c: Remove warning.
| | | | * libnetworking/lib/ftpfs.c: Switch bcopy to memcpy.
* 2004-03-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-03-053-19/+54
| | | | | | * libcsupport/src/newlibc.c, libcsupport/src/sync.c: Eliminate warnings. Explicitly defeat __STRICT_ANSI__ since both legitimately use routines beyond ANSI.
* 2004-03-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-03-052-1/+6
| | | | * libblock/src/bdbuf.c: Initialize pointer to avoid warning.
* 2004-03-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-03-0515-38/+57
| | | | | | | | | | * libnetworking/rtems_webserver/ejparse.c, libnetworking/rtems_webserver/emfdb.c, libnetworking/rtems_webserver/sock.c, libnetworking/rtems_webserver/socket.c, libnetworking/rtems_webserver/sym.c, libnetworking/rtems_webserver/webs.c, libnetworking/rtems_webserver/websuemf.c: Remove warnings.
* 2004-03-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-03-052-0/+24
| | | | | | * libchipnetwork/open_eth.c: Remove warnings by conditionally compiling this file only only those CPU families with supported exception models.
* 2004-03-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-03-052-0/+7
| | | | | * mpc6xx/mmu/pte121.c: Add missing ifdef DEBUG to remove warning for unused static routine.
* 2004-03-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-03-056-7/+16
| | | | | | | * bootloader/pci.c: Remove warnings by adding include <string.h>. * irq/irq.c: Clean up includes to remove warnings. * pci/pci.c, pci/pci.h, startup/bspstart.c: Better use of const on struct _int_map.
* 2004-03-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-03-052-1/+18
| | | | | * network/network.c: Remove warnings for unused routines left from original code.
* 2004-03-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-03-053-21/+9
| | | | | * score/macros/rtems/score/chain.inl, score/src/objectidtoname.c: Add cast to avoid type punning warning in gcc 3.3.
* 2004-03-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-03-0535-193/+52
| | | | | | | | | | | | | | | | | | | | | * libblock/src/bdbuf.c, libblock/src/ramdisk.c, libcsupport/src/newlibc.c, libcsupport/src/sync.c, libmisc/cpuuse/cpuuse.c, libmisc/monitor/mon-symbols.c, libmisc/shell/cmds.c, libmisc/shell/shell.c, libnetworking/kern/kern_sysctl.c, libnetworking/lib/ftpfs.c, libnetworking/lib/tftpDriver.c, libnetworking/libc/gethostbydns.c, libnetworking/libc/gethostbyht.c, libnetworking/libc/gethostnamadr.c, libnetworking/libc/getnetbyht.c, libnetworking/libc/getnetnamadr.c, libnetworking/libc/inet_addr.c, libnetworking/libc/linkaddr.c, libnetworking/libc/map_v4v6.c, libnetworking/libc/ns_print.c, libnetworking/libc/ns_ttl.c, libnetworking/libc/nsap_addr.c, libnetworking/libc/rcmd.c, libnetworking/libc/res_debug.c, libnetworking/libc/res_mkupdate.c, libnetworking/libc/res_query.c, libnetworking/libc/res_send.c, libnetworking/libc/res_update.c, libnetworking/net/radix.c, libnetworking/rtems/mkrootfs.c, librpc/src/rpc/clnt_perror.c, librpc/src/rpc/svc.c, score/macros/rtems/score/chain.inl, score/src/objectidtoname.c: Too much was accidentally committed -- revert.
* 2004-03-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-03-0537-37/+244
| | | | | | | | | | | | | | | | | | | | | * libblock/src/bdbuf.c, libblock/src/ramdisk.c, libcsupport/src/newlibc.c, libcsupport/src/sync.c, libmisc/cpuuse/cpuuse.c, libmisc/monitor/mon-symbols.c, libmisc/shell/cmds.c, libmisc/shell/shell.c, libnetworking/kern/kern_sysctl.c, libnetworking/lib/ftpfs.c, libnetworking/lib/tftpDriver.c, libnetworking/libc/gethostbydns.c, libnetworking/libc/gethostbyht.c, libnetworking/libc/gethostnamadr.c, libnetworking/libc/getnetbyht.c, libnetworking/libc/getnetnamadr.c, libnetworking/libc/inet_addr.c, libnetworking/libc/linkaddr.c, libnetworking/libc/map_v4v6.c, libnetworking/libc/ns_print.c, libnetworking/libc/ns_ttl.c, libnetworking/libc/nsap_addr.c, libnetworking/libc/rcmd.c, libnetworking/libc/res_debug.c, libnetworking/libc/res_mkupdate.c, libnetworking/libc/res_query.c, libnetworking/libc/res_send.c, libnetworking/libc/res_update.c, libnetworking/net/radix.c, libnetworking/rtems/mkrootfs.c, librpc/src/rpc/clnt_perror.c, librpc/src/rpc/rtems_rpc.c, librpc/src/rpc/svc.c, sapi/include/confdefs.h, score/macros/rtems/score/chain.inl, score/src/objectidtoname.c:
* 2004-03-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-03-055-3/+10
| | | | | * psxfile01/test.c, psxmsgq01/init.c, psxstat/test.c, psxtimer/psxtimer.c: Eliminate warnings and typos.
