* | build: Remove obsolete test excludes | Sebastian Huber | 2022-04-06 | 13 | -52/+0 |
* | bsps: Add gicv3_get_attributes() | Sebastian Huber | 2022-04-06 | 2 | -26/+33 |
* | bsps: Add gicv3_sgi_ppi_get_priority() | Sebastian Huber | 2022-04-06 | 2 | -3/+14 |
* | bsps: Add gicv3_sgi_ppi_set_priority() | Sebastian Huber | 2022-04-06 | 2 | -3/+16 |
* | bsps: Move gicv3_init_cpu_interface() | Sebastian Huber | 2022-04-06 | 2 | -30/+29 |
| | | | | Make the processor index a parameter. | ||||
* | bsps: Move gicv3_init_dist() | Sebastian Huber | 2022-04-06 | 2 | -39/+38 |
| | | | | Make the distributor register block a parameter. | ||||
* | bsps: Add gicv3_sgi_ppi_disable() | Sebastian Huber | 2022-04-06 | 2 | -4/+11 |
* | bsps: Add gicv3_sgi_ppi_enable() | Sebastian Huber | 2022-04-06 | 2 | -9/+16 |
* | bsps: Add gicv3_sgi_ppi_is_enabled() | Sebastian Huber | 2022-04-06 | 2 | -4/+11 |
* | bsps: Add gicv3_ppi_clear_pending() | Sebastian Huber | 2022-04-06 | 2 | -4/+11 |
* | bsps: Add gicv3_ppi_set_pending() | Sebastian Huber | 2022-04-06 | 2 | -4/+11 |
* | bsps: Add gicv3_trigger_sgi() | Sebastian Huber | 2022-04-06 | 2 | -14/+22 |
* | bsps: Add gicv3_sgi_ppi_is_pending() | Sebastian Huber | 2022-04-06 | 2 | -4/+12 |
* | bsps: Add <dev/irq/arm-gicv3.h> | Sebastian Huber | 2022-04-06 | 4 | -121/+165 |
| | | | | | | | | Separate the Interrupt Manager implementation from the generic Arm GICv3 support. Move parts of the Arm GICv3 support into a new header file. This helps to support systems with a clustered structure in which multiple GICv3 instances are present. For example, two clusters of two Cortex-R52 cores where each cluster has a dedicated GICv3 instance. | ||||
* | unit: Test red-black trees | Sebastian Huber | 2022-04-06 | 2 | -0/+1196 |
* | unit: Add test for misaligned builtin memcpy() | Sebastian Huber | 2022-04-06 | 2 | -0/+52 |
* | unit: Add a unit test suite | Sebastian Huber | 2022-04-06 | 6 | -0/+141 |
* | bsp/stm32h7: Disable some tests for a variant | Sebastian Huber | 2022-04-06 | 1 | -0/+2 |
| | | | | Making this BSP a small memory target is a bit coarse and could be improved. | ||||
* | bsps/stm32h7: link to flash on STM32H7B3I-DK | Karel Gardas | 2022-04-06 | 1 | -1/+4 |
| | | | | | The patch is needed due to smaller SRAM and completely disabled SDRAM on the BSP variant. | ||||
* | libmisc/untar: Use a larger block size to read and write files | Chris Johns | 2022-04-06 | 1 | -20/+33 |
| | | | | | | | - A larger block size lets files systems work better. On JFFS a 512 byte compressed block means lots of small flash updates Closes #4635 | ||||
* | sp0*/*.doc: Remove junk UTF-8 character | Joel Sherrill | 2022-04-05 | 6 | -5/+9 |
* | testsuites/sptests/sp[i-z]*/*.doc: Change license to BSD-2 | Joel Sherrill | 2022-04-05 | 40 | -120/+880 |
| | | | | Updates #3053. | ||||
* | testsuites/sptests/sp[a-h]*/*.doc: Change license to BSD-2 | Joel Sherrill | 2022-04-05 | 29 | -84/+618 |
* | testsuites/sptests/sp[0-7]*/*.doc: Change license to BSD-2 | Joel Sherrill | 2022-04-05 | 69 | -207/+1518 |
* | testsuites/sptests/sp[s-z]*: Change license to BSD-2 | Joel Sherrill | 2022-04-05 | 55 | -165/+1210 |
* | testsuites/sptests/sp[g-r]*: Change license to BSD-2 | Joel Sherrill | 2022-04-05 | 51 | -153/+1122 |
* | testsuites/sptests/sp[a-f*]*: Change license to BSD-2 | Joel Sherrill | 2022-04-05 | 52 | -156/+1144 |
* | testsuites/sptests/sp[4-7]*: Change license to BSD-2 | Joel Sherrill | 2022-04-05 | 31 | -93/+682 |
* | testsuites/sptests/sp[2-3]*: Change license to BSD-2 | Joel Sherrill | 2022-04-05 | 40 | -120/+880 |
* | testsuites/sptests/sp1*: Change license to BSD-2 | Joel Sherrill | 2022-04-05 | 49 | -147/+1078 |
* | testsuites/sptests/sp0*: Change license to BSD-2 | Joel Sherrill | 2022-04-05 | 41 | -123/+902 |
* | Update email address of Fernando Ruiz Casas to <fruizcasas@gmail.com> | Joel Sherrill | 2022-04-05 | 43 | -202/+260 |
| | | | | This was requested to be executed prior to relicensing to BSD-2. | ||||
* | bsp/stm32h7: Convert to UNIX line endings | Sebastian Huber | 2022-04-05 | 263 | -708277/+708277 |
* | bsp/stm32h7: bring all required changes into system_stm32h7xx for ↵ | Karel Gardas | 2022-04-05 | 1 | -7/+44 |
| | | | | | | | | STM32H7B3I-DK BSP variant The changes provided here are a result of a merge from various examples system_stm32h7xx.c files provided by STMicroelectronics for the STM32H7B3I-DK board with the original RTEMS file provided for the STM32H743I-EVAL2 board. | ||||
* | bsp/stm32h7: properly ifdef all unsupported features in start -hal file ↵ | Karel Gardas | 2022-04-05 | 1 | -0/+20 |
| | | | | while compiling for STM32H7B3I-DK BSP | ||||
* | bsp/stm32h7: configure peripheral clocks for STM32H7B3xxQ (e.g. ↵ | Karel Gardas | 2022-04-05 | 1 | -0/+17 |
| | | | | STM32H7B3I-DK BSP) | ||||
* | bsp/stm32h7: configure oscillator for STM32H7B3xxQ (e.g. STM32H7B3I-DK BSP) | Karel Gardas | 2022-04-05 | 1 | -0/+17 |
* | bsp/stm32h7: configure AHB clock divider for STM32H7B3xxQ (e.g. ↵ | Karel Gardas | 2022-04-05 | 1 | -0/+4 |
* | bsp/stm32h7: disable ethernet for STM32H7B3I-DK BSP variant | Karel Gardas | 2022-04-05 | 1 | -0/+4 |
| | | | | Note: the ethernet port is not presented on the board anyway. | ||||
* | bsp/stm32h7: use appropriate STM32H7B3xxQ define for STM32H7B3I-DK BSP variant | Karel Gardas | 2022-04-05 | 1 | -1/+4 |
* | bsp/stm32h7: configure S(D)RAM values for STM32H7B3I-DK BSP variant | Karel Gardas | 2022-04-05 | 6 | -6/+24 |
| | | | | Caveat: SDRAM 1 is completely disabled for now. | ||||
* | bsp/stm32h7: HSE clock value configuration for STM32H7B3I-DK BSP variant | Karel Gardas | 2022-04-05 | 1 | -0/+3 |
* | bsp/stm32h7: add flash latency configuration | Karel Gardas | 2022-04-05 | 3 | -1/+22 |
* | bsp/stm32h7: add configuration for USART1 GPIO pins, registers and alternate ↵ | Karel Gardas | 2022-04-05 | 5 | -3/+68 |
| | | | | function | ||||
* | bsp/stm32h7: disable UART 5, 7, 8, 9 and USART 3, 6, 10 for STM32H7B3I-DK BSP | Karel Gardas | 2022-04-05 | 7 | -7/+28 |
* | bsp/stm32h7: add power supply configuration | Karel Gardas | 2022-04-05 | 3 | -1/+22 |
* | bsp/stm32h7: add spec file for the STM32H7B3I-DK BSP variant | Karel Gardas | 2022-04-05 | 1 | -0/+17 |
* | cpukit/libmisc/dumpbuf/dumpbuf.c: Manually change license to BSD-2 | Joel Sherrill | 2022-04-02 | 1 | -3/+20 |
| | | | | | | | There was a typo in the license text and this file was missed by the script. Updates #3053 | ||||
* | cpukit/include; Remove SPDX from Gaisler files NOT changed to BSD-2 | Joel Sherrill | 2022-04-02 | 12 | -24/+0 |
* | cpukit/libcsupport/src/_*: Change license to BSD-2 | Joel Sherrill | 2022-04-01 | 8 | -24/+176 |
| | | | | Updates #3053. |
