* | bsps/powerpc: Remove unused files | Sebastian Huber | 2013-02-13 | 2 | -46/+0 |
* | score: use new alignment routine in object extend information. | Gedare Bloom | 2013-02-12 | 1 | -12/+16 |
* | score: New routines to align addresses up or down. | Gedare Bloom | 2013-02-12 | 1 | -0/+44 |
* | sptests/spfatal11: Update due to API changes | Sebastian Huber | 2013-02-12 | 2 | -5/+22 |
* | sapi: PR1911: Add CONFIGURE_DISABLE_BSP_SETTINGS | Sebastian Huber | 2013-02-12 | 3 | -0/+79 |
* | score: Add and use rtems_assert_context | Sebastian Huber | 2013-02-12 | 5 | -7/+52 |
* | bsp/lpc32xx: Add BSP_USB_OTG_TRANSCEIVER_VBUS | Sebastian Huber | 2013-02-12 | 1 | -0/+3 |
* | sparc64: revert linkcmds to 4 MB ram size | Gedare Bloom | 2013-02-11 | 1 | -2/+2 |
* | PR1560: _Objects_Extend_information improper alignment | Gedare Bloom | 2013-02-11 | 1 | -5/+18 |
| | | | | | | _Objects_Extend_information uses a sizeof(uint32_t) offset that leads to improper alignment in case the CPU (actually, heap) alignment is 8 or higher. The problem is solved by adding enough padding to align the sub-tables. | ||||
* | bsp/lpc24xx: Move UART probes to separate files | Sebastian Huber | 2013-02-11 | 6 | -53/+130 |
* | libchip/serial: Make NS16550 handler public | Sebastian Huber | 2013-02-11 | 5 | -18/+29 |
| | | | | This allows derived drivers to use these functions. | ||||
* | libchip/serial: Add const qualifier | Sebastian Huber | 2013-02-11 | 38 | -64/+64 |
* | libchip/serial: Fix warnings | Sebastian Huber | 2013-02-11 | 2 | -2/+13 |
* | libchip/serial: Fix warnings | Sebastian Huber | 2013-02-11 | 1 | -2/+1 |
* | libchip/serial: Fix warnings | Sebastian Huber | 2013-02-11 | 2 | -6/+9 |
* | bsp/erc32: Fix warnings | Sebastian Huber | 2013-02-11 | 1 | -2/+2 |
* | score: atomic support for RTEMS. Cleanup. | WeiY | 2013-02-07 | 3 | -226/+218 |
* | tests: atomic support for RTEMS. SMP tests for atomic operations. | WeiY | 2013-02-07 | 42 | -0/+1991 |
* | tests: atomic support for RTEMS. Uniprocessor tests for atomic ops. | WeiY | 2013-02-07 | 42 | -0/+2563 |
* | score: atomic support for RTEMS. Atomic operations for PowerPC. | WeiY | 2013-02-07 | 1 | -0/+537 |
* | score: atomic support for RTEMS. Atomic operations for i386. | WeiY | 2013-02-07 | 1 | -0/+341 |
* | score: atomic support for RTEMS. Generic atomic operations API definition. | WeiY | 2013-02-07 | 4 | -0/+876 |
* | score: atomic support for RTEMS automake and autoconf changes | WeiY | 2013-02-07 | 12 | -2/+54 |
* | bsp/mpc55xx: Add MPC55XX_ENABLE_START_PROLOGUE | Sebastian Huber | 2013-02-06 | 5 | -0/+51 |
* | bsp/mpc55xx: Merge RSM6 variants into one | Sebastian Huber | 2013-02-06 | 16 | -150/+85 |
* | bsp/mpc55xx: Add and use BSP specific fatal codes | Sebastian Huber | 2013-02-06 | 7 | -20/+45 |
* | bsps/powerpc: Add and use ppc_cpu_is_specific_e200 | Sebastian Huber | 2013-02-06 | 2 | -2/+10 |
* | bsps/powerpc: Fix e200 check | Sebastian Huber | 2013-02-06 | 1 | -4/+2 |
* | bsp/mpc55xx: Add mpc55xx_mmu_apply_config() | Sebastian Huber | 2013-02-06 | 1 | -2/+12 |
* | rtems: Revert documentation changes | Sebastian Huber | 2013-02-06 | 1 | -5/+5 |
* | Merge branch 'master' of ssh://git.rtems.org/data/git/rtems | Joel Sherrill | 2013-02-02 | 935 | -18184/+24798 |
| * | fstests/fsrdwr: Free allocated memory | Sebastian Huber | 2013-01-30 | 1 | -0/+4 |
| * | fstests: Check resources used by FAT file system | Sebastian Huber | 2013-01-30 | 1 | -0/+6 |
| * | fstests: Use global environment and clean up | Sebastian Huber | 2013-01-30 | 1 | -3/+14 |
| | | | | | | | | This releases all resources acquired by the chroot(). | ||||
| * | fstests: Initialize swapout task | Sebastian Huber | 2013-01-30 | 1 | -0/+19 |
| * | fstests: Perform a quick format | Sebastian Huber | 2013-01-30 | 1 | -1/+1 |
| * | fstests: Use designated initializers | Sebastian Huber | 2013-01-30 | 1 | -10/+10 |
| * | dosfs: Always release the buffers | Sebastian Huber | 2013-01-30 | 1 | -22/+23 |
| | | | | | | | | | | Release the buffers also if this is not the last reference to the file object since otherwise we may hold modified data indefinitely. | ||||
| * | ftpd: Check the root and current directory change | Sebastian Huber | 2013-01-30 | 1 | -20/+28 |
| | | | | | | | | | | | | Only continue the session if the root and current directory change was successful, otherwise the FTP server may access restricted file system areas. | ||||
| * | ftpfs: Fix SIZE command handling | Sebastian Huber | 2013-01-28 | 3 | -80/+124 |
| | | | | | | | | | | | | | | It is invalid to issue a SIZE command once a data transfer is in progress. For reads we issue the SIZE command before the RETR command and get a snapshot of the file size. For writes the file size is initialized to zero and incremented for each write chunk. | ||||
| * | bsp/mpc55xx: Add BSP_DATA_CACHE_USE_WRITE_THROUGH | Sebastian Huber | 2013-01-28 | 3 | -2/+13 |
| * | bsps/powerpc: Add option for write-through cache | Sebastian Huber | 2013-01-28 | 1 | -1/+2 |
| * | bsp/mpc55xx: Fix MMU configuration for RSM6 | Sebastian Huber | 2013-01-28 | 1 | -4/+4 |
| * | testsuites: Fix prototypes | Sebastian Huber | 2013-01-27 | 6 | -16/+22 |
| * | testsuites: Use rtems_fatal_source_description() | Sebastian Huber | 2013-01-27 | 4 | -27/+6 |
| * | Fixed virtex4,5 BSP compile time warnings | Ric Claus | 2013-01-26 | 6 | -7/+11 |
| * | Move <memory.h> and <sys/uio.h> to non-networking directory | Joel Sherrill | 2013-01-23 | 7 | -28/+120 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | These two header files were installed from libnetworking even when networking was disabled. This patch moves them to a non-networking location and updates uio.h to match the FreeBSD 8.x source being used for the USB stack and TCP/IP stack upgrade. - cpukit/include/memory.h Move from cpukit/libnetworking/memory.h. No changes - cpukit/include/sys/uio.h Move from cpukit/libnetworking/sys/uio.h. Replace with FreeBSD 8.x version. - cpukit/include/sys/_iovec.h New. FreeBSD 8.x file supporting <sys/uio.h>. - cpukit/Makefile.am Reflect movement of <memory.h> and <sys/uio.h>. - cpukit/preinstall.am Regenerate - cpukit/libnetworking/nfs/bootp_subr.c Eliminate use of uio_procp field no longer in FreeBSD structure. This field was set and never read so eliminating the set has no impact. | ||||
| * | bsp/gen83xx: Disable caches in bsp_restart() | Sebastian Huber | 2013-01-18 | 1 | -1/+23 |
| * | fstests: Generating .scn (Screen Shots) #4 | Alex Ivanov | 2013-01-15 | 6 | -0/+192 |
| * | psxtmtests: Generating .scn (Screen Shots) #8 | Alex Ivanov | 2013-01-15 | 7 | -0/+30 |
