* common/common.add.in: Remove __os_install_post.
* cpukit/rtems-cpukit.add, gdb/gdb.add, rtems/rtems.add,
rtemsdoc/rtemsdoc.add: Add __os_install_post.
which included commits to RCS files with non-trunk default branches.
* ChangeLog: fixed wrong date of last ChangeLog entry.
PR 849/networking
* librpc/src/rpc/rtems_portmapper.c: Increased stack size
by ARGSIZE to prevent overrun.
* shared/irq/irq_init.c, shared/openpic/openpic.h
shared/openpic/openpic.c: The 8240's EPIC has a 'serial'
mode of operation for multiplexing 16 interrupt lines.
This introduces a pipeline delay which can cause
spurious interrupts unless ending the interrupt cycle
(EOI) is delayed accordingly.
* shared/vectors/vectors.h, shared/vectors/vectors.S,
shared/vectors/vectors_init.c: Reduced size of default
prologue (some exceptions, e.g., altivec unavail.) are only
0x20 bytes apart. Also introduced a modified prologue
that switches r0..r3 shadowing off (r0..r3 undefined
on certain 603e variants when incurring a TLB miss).
* shared/irq/irq_asm.S, shared/vectors/vectors.S: Clear
CR[6] before invoking high-level handler to make sure no
varargs fn callee assumes there are FP arguments.
* shared/irq/irq.c: Fixed incorrect removal of first shared
interrupt in chain.
* aclocal/enable-bare.m4: Remove (Unused).
* aclocal/env-rtemsbsp.m4:
Remove RTEMS_ENABLE_BARE,
BARE_CPU_CFLAGS, BARE_CPU_MODEL.
* configure.ac: Remove RTEMS_ENABLE_BARE,
* automake/compile.am: Remove .obj.
* custom/gba.cfg, custom/pc386.cfg: Use .elf instead of .obj.
* custom/dmv152.cfg, custom/i386ex.cfg, custom/idp.cfg,
custom/mcf5235.cfg, custom/mrm332.cfg, custom/mvme136.cfg,
custom/mvme147.cfg, custom/mvme162.cfg, custom/mvme162lx.cfg:
Use .srec for files containing SRECs.
* automake/compile.am: Remove .coff.
* custom/gp32.cfg: Replace .gxb with .elf.
* custom/i386ex.cfg, custom/ts_386ex.cfg: Replace .coff with .elf.
* bsp_specs: remove %lib.
* new-exceptions/cpu_asm.S: the book says a context
synchronizing instruction (isync) is necessary after flipping
certain bits (e.g, MSR_FP) in msr -- since this could happen as
part of a context switch I added 'isync'.
* configure.ac: New header guard for cpuopts.h.
* gccnewlib/gccnewlib.add: Rename src.rpm back to
gcc-newlib.src.rpm. Misc fixups.
* gccnewlib/target-c++.add, gccnewlib/target-g77.add,
gccnewlib/target-gcc.add, gccnewlib/target-gcj.add,
gccnewlib/target-gfortran.add, gccnewlib/target-gnat.add
gccnewlib/target-objc.add: Add License.
* gccnewlib/base-g77.add, gccnewlib/base-gcc.add,
gccnewlib/base-gcj.add, gccnewlib/base-gfortran.add,
gccnewlib/base-gnat.add: Add License.
* configure.ac: Re-add mptests*Makefile.am.
* mptests/Makefile.am: Re-add mp?? tests.
* mptests/mp02/Makefile.am, mptests/mp02/node1/Makefile.am,
mptests/mp02/node2/Makefile.am, mptests/mp03/Makefile.am,
mptests/mp03/node1/Makefile.am, mptests/mp03/node2/Makefile.am,
mptests/mp04/Makefile.am, mptests/mp04/node1/Makefile.am,
mptests/mp04/node2/Makefile.am, mptests/mp05/Makefile.am,
mptests/mp05/node1/Makefile.am, mptests/mp05/node2/Makefile.am,
mptests/mp06/Makefile.am, mptests/mp06/node1/Makefile.am,
mptests/mp06/node2/Makefile.am, mptests/mp07/Makefile.am,
mptests/mp07/node1/Makefile.am, mptests/mp07/node2/Makefile.am,
mptests/mp08/Makefile.am, mptests/mp08/node1/Makefile.am,
mptests/mp08/node2/Makefile.am, mptests/mp09/Makefile.am,
mptests/mp09/node1/Makefile.am, mptests/mp09/node2/Makefile.am,
mptests/mp10/Makefile.am, mptests/mp10/node1/Makefile.am,
mptests/mp10/node2/Makefile.am, mptests/mp11/Makefile.am,
mptests/mp11/node1/Makefile.am, mptests/mp11/node2/Makefile.am,
mptests/mp12/Makefile.am, mptests/mp12/node1/Makefile.am,
mptests/mp12/node2/Makefile.am, mptests/mp13/Makefile.am,
mptests/mp13/node1/Makefile.am, mptests/mp13/node2/Makefile.am,
mptests/mp14/Makefile.am, mptests/mp14/node1/Makefile.am,
mptests/mp14/node2/Makefile.am: New.
* samples/base_mp/node1/Makefile.am,
samples/base_mp/node2/Makefile.am, samples/base_sp/Makefile.am,
samples/hello/Makefile.am, samples/ticker/Makefile.am,
sptests/sp01/Makefile.am, sptests/sp02/Makefile.am,
sptests/sp03/Makefile.am, sptests/sp04/Makefile.am,
sptests/sp05/Makefile.am, sptests/sp06/Makefile.am,
sptests/sp07/Makefile.am, sptests/sp08/Makefile.am,
sptests/sp09/Makefile.am, sptests/sp11/Makefile.am,
sptests/sp12/Makefile.am, sptests/sp13/Makefile.am,
sptests/sp14/Makefile.am, sptests/sp15/Makefile.am,
sptests/sp16/Makefile.am, sptests/sp17/Makefile.am,
sptests/sp19/Makefile.am, sptests/sp20/Makefile.am,
sptests/sp21/Makefile.am, sptests/sp22/Makefile.am,
sptests/sp23/Makefile.am, sptests/sp24/Makefile.am,
sptests/sp25/Makefile.am: Add scndir. Install *.scn to scndir.
* samples/base_mp/Makefile.am: Remove references to *.scn.
* samples/base_mp/node1/base_mp.scn: Remove.
* samples/base_mp/node1/base_mp-node1.scn: New.
* samples/base_mp/node1/Makefile.am: Eliminate NODE.
Reflect having renamed base_mp.scn.
* samples/base_mp/node2/base_mp.scn: Remove.
* samples/base_mp/node2/base_mp-node2.scn: New.
* samples/base_mp/node2/Makefile.am: Eliminate NODE.
