* | fixed typo | Joel Sherrill | 1997-07-18 | 3 | -12/+12 | |
* | Fixed typo of "::" | Joel Sherrill | 1997-07-18 | 1 | -1/+1 | |
* | Reordered specs. | Joel Sherrill | 1997-07-10 | 2 | -8/+8 | |
* | fixed milliseconds and microseconds to tick conversion routines. | Joel Sherrill | 1997-07-10 | 2 | -22/+20 | |
* | Added information on different MVME162 models. | Joel Sherrill | 1997-07-10 | 1 | -0/+11 | |
* | Strip the trace bit from the SR register when dispatching a thread when | Joel Sherrill | 1997-07-10 | 1 | -3/+5 | |
| | | | | | exiting from an ISR. This allows the trace bit to be set on a per task basis and tracing to be limited to that task. | |||||
* | Repository damaged -- file re-added | Joel Sherrill | 1997-07-09 | 3 | -0/+555 | |
* | Repository damaged -- files readded. | Joel Sherrill | 1997-07-09 | 3 | -0/+625 | |
* | Changed name from entry to thread_entry to be more compatible with | Joel Sherrill | 1997-07-09 | 5 | -5/+5 | |
| | | | | Ada interface where entry is a keyword. | |||||
* | Used macro instead of hard coded number. | Joel Sherrill | 1997-07-09 | 2 | -2/+2 | |
* | Added postswitch extension. | Joel Sherrill | 1997-07-09 | 3 | -0/+6 | |
* | Added post switch extension. | Joel Sherrill | 1997-07-09 | 3 | -0/+15 | |
* | Corrected typos and spacing. | Joel Sherrill | 1997-07-09 | 3 | -9/+9 | |
* | Added mvme162lx bsp configuration. | Joel Sherrill | 1997-07-09 | 2 | -8/+14 | |
| | | | | M68040 FPSP was already part of the tree but was not being built. | |||||
* | This code was in the tree but not actually being compiled. There | Joel Sherrill | 1997-07-09 | 34 | -140/+140 | |
| | | | | | | | were a number of minor problems which had to be fixed to get it to compile including modifying the compile rule to handle C++ comments, changing the syntax of the include statement, and getting rid of "%" as part of register names. | |||||
* | Added sp, sfc, and fpcsr register defines. | Joel Sherrill | 1997-07-09 | 3 | -0/+12 | |
* | Updated to the PowerPC. | Joel Sherrill | 1997-07-02 | 2 | -2/+70 | |
* | updated to properly reflect powerpc | Joel Sherrill | 1997-07-02 | 6 | -228/+86 | |
* | New files -- PowerPC supplement is based on the SPARC supplement. | Joel Sherrill | 1997-07-01 | 20 | -0/+3307 | |
| | | | | | This version has had some initial work done to convert it to be PowerPC specific. | |||||
* | This commit was generated by cvs2svn to compensate for changes in r930, | Joel Sherrill | 1997-06-16 | 9 | -0/+1379 | |
|\ | | | | | which included commits to RCS files with non-trunk default branches. | |||||
| * | base PDL 2 TEXI | Joel Sherrill | 1997-06-16 | 9 | -0/+1379 | |
* | | Initial revision | Joel Sherrill | 1997-06-16 | 7 | -0/+5348 | |
* | | new file | Joel Sherrill | 1997-06-04 | 2 | -0/+90 | |
* | | added CVS Id string | Joel Sherrill | 1997-06-04 | 181 | -70/+541 | |
* | | added CVS Id string | Joel Sherrill | 1997-06-04 | 1 | -0/+2 | |
* | | Added CVS Id string | Joel Sherrill | 1997-06-04 | 2 | -0/+6 | |
* | | changed version number | Joel Sherrill | 1997-06-04 | 4 | -5/+6 | |
* | | changed edition and version information | Joel Sherrill | 1997-06-04 | 16 | -28/+29 | |
* | | Fixed formatting problem where @example did not start early enough. | Joel Sherrill | 1997-06-04 | 1 | -2/+2 | |
* | | final corrections before 4.1.0 documentation freeze. | Joel Sherrill | 1997-06-04 | 11 | -29/+28 | |
* | | corrected name of test suite | Joel Sherrill | 1997-06-03 | 30 | -30/+30 | |
* | | fixed comment | Joel Sherrill | 1997-06-03 | 1 | -1/+1 | |
* | | *** empty log message *** | Joel Sherrill | 1997-06-03 | 0 | -0/+0 | |
* | | Removed configuration information. | Joel Sherrill | 1997-06-03 | 1 | -54/+0 | |
* | | new file | Joel Sherrill | 1997-06-03 | 4 | -0/+181 | |
* | | Removed Configuration Information. | Joel Sherrill | 1997-06-03 | 1 | -54/+0 | |
* | | new files. | Joel Sherrill | 1997-06-03 | 2 | -0/+89 | |
* | | Removed configuration information. | Joel Sherrill | 1997-06-03 | 1 | -42/+0 | |
* | | new files | Joel Sherrill | 1997-06-03 | 5 | -0/+362 | |
* | | new file. | Joel Sherrill | 1997-06-03 | 1 | -0/+9 | |
* | | corrected to compile with the new binding. | Joel Sherrill | 1997-06-03 | 5 | -35/+119 | |
* | | Corrected for this test. | Joel Sherrill | 1997-06-03 | 1 | -0/+1 | |
* | | Added correct contents | Joel Sherrill | 1997-06-03 | 1 | -0/+57 | |
* | | new file | Joel Sherrill | 1997-06-03 | 4 | -0/+700 | |
* | | Corrected maximum number of messages to be non-zero | Joel Sherrill | 1997-06-03 | 1 | -1/+1 | |
* | | removed reference to Stub Device Driver | Joel Sherrill | 1997-06-03 | 1 | -1/+0 | |
* | | Replaced prototype for Last_Task which was accidentally removed when | Joel Sherrill | 1997-06-03 | 1 | -0/+14 | |
| | | | | | | | | the Configuration Tables were deleted from the Ada specification. | |||||
* | | Changed RTEMS.Boolean to Standard.Boolean to avoid typing problems. | Joel Sherrill | 1997-06-03 | 1 | -1/+1 | |
* | | Fixed incorrect invocation of Message_Queue_Create | Joel Sherrill | 1997-06-03 | 1 | -1/+0 | |
* | | fixed typo which resulted in Message_Queue_Create being invoked incorrectly. | Joel Sherrill | 1997-06-03 | 1 | -1/+0 | |
