* | 2005-08-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-08-17 | 1 | -0/+9 |
| | | | | | | | | | * binutils/binutils.add: Special-case _prefix=/usr. * gccnewlib/base-g77.add, gccnewlib/base-gcc.add, gccnewlib/base-gcj.add, gccnewlib/base-gfortran.add, gccnewlib/base-gnat.add, gccnewlib/gccnewlib.add: Special-case _prefix=/usr. | ||||
* | Special-case _prefix == /usr | Ralf Corsepius | 2005-08-17 | 7 | -2/+18 |
* | Add special treatment for _prefix=/usr | Ralf Corsepius | 2005-08-16 | 2 | -0/+10 |
* | 2005-08-15 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-08-15 | 1 | -0/+2 |
| | | | | | * posix/include/mqueue.h, posix/src/mqueuetimedreceive.c: ssize_t mq_timedreceive() (POSIX compliance). | ||||
* | ssize_t mq_timedreceive() (POSIX compliance) | Ralf Corsepius | 2005-08-15 | 2 | -2/+2 |
* | 2005-08-15 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-08-15 | 1 | -0/+5 |
| | | | | | * gccnewlib/Makefile.am: Remove h8300-rtemscoff. * binutils/Makefile.am: Remove h8300-rtemscoff. | ||||
* | Remove h8300-rtemscoff | Ralf Corsepius | 2005-08-15 | 2 | -8/+0 |
* | 2005-08-15 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-08-15 | 2 | -51/+7 |
| | | | | * optman/Makefile.am: Add preinstall.am. | ||||
* | New. | Ralf Corsepius | 2005-08-15 | 2 | -0/+121 |
* | 2005-08-15 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-08-15 | 1 | -0/+6 |
| | | | | | | * Makefile.am: Add preinstall.am. * configure.ac: Add AMPOLISH3. * preinstall.am: New. | ||||
* | Add AMPOLISH3. | Ralf Corsepius | 2005-08-15 | 1 | -0/+4 |
* | Add preinstall.am. | Ralf Corsepius | 2005-08-15 | 1 | -54/+3 |
* | Regenerate. | Ralf Corsepius | 2005-08-15 | 1 | -0/+8 |
* | 2005-08-15 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-08-15 | 2 | -2/+7 |
| | | | | * wrapup/Makefile.am: Use librtemscpu_a_LIBRARIES. | ||||
* | Regenerate. | Ralf Corsepius | 2005-08-15 | 1 | -0/+4 |
* | 2005-08-12 Chris Johns <chrisj@rtems.org> | Joel Sherrill | 2005-08-12 | 2 | -4/+8 |
| | | | | | | PR 808/rtems_misc * libcsupport/src/printk.c: Fix bug where specifying field width crashed on pc386 BSP. | ||||
* | 2005-08-12 Phil Torre <ptorre@zetron.com> | Joel Sherrill | 2005-08-12 | 2 | -1/+9 |
| | | | | | | | | PR 816/bsps * mpc8xx/include/mpc8xx.h: The struct which describes SCC Ethernet mode parameters (m8xxSCCENparms_t) does not match the hardware: members taddr_h and taddr_l are transposed. When loading new multicast group addresses into the hash table, the wrong hash bit is set. | ||||
* | 2005-08-06 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-08-06 | 2 | -2/+5 |
| | | | | | * libnetworking/nfs/bootp_subr.c: Don't include nfs/nfs.h, nfs/krpc.h. | ||||
* | 2005-08-05 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-08-05 | 1 | -0/+9 |
| | | | | | | | | | * libfs/src/dosfs/msdos.h, libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_eval.c, libfs/src/dosfs/msdos_file.c, libfs/src/dosfs/msdos_free.c, libfs/src/dosfs/msdos_fsunmount.c, libfs/src/dosfs/msdos_init.c, libfs/src/dosfs/msdos_misc.c, libfs/src/dosfs/msdos_mknod.c: Introduce msdos_status_t (dosfs statii are at least 32bit, not int). | ||||
* | Introduce msdos_status_t. | Ralf Corsepius | 2005-08-05 | 9 | -32/+34 |
* | Regenerate. | Ralf Corsepius | 2005-08-05 | 2 | -4/+8 |
* | 2005-08-05 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-08-05 | 3 | -490/+40 |
| | | | | | * Makefile.am: Add libnetworking/memory.h * libnetworking/Makefile.am: Remove memory.h | ||||
* | 2005-08-05 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-08-05 | 2 | -5/+11 |
| | | | | * Makefile.am: Unconditionally initialize include_libcpu_HEADERS. | ||||
* | Fixed formatting. | Joel Sherrill | 2005-08-02 | 1 | -1/+2 |
* | Corrected placement of log entries. | Joel Sherrill | 2005-08-02 | 3 | -6/+12 |
* | 2005-08-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-08-02 | 2 | -1/+8 |
| | | | | | | | PR 817/rtems * libcsupport/src/gxx_wrappers.c: Rename rtems_gxx_recursive_mutex_init_function to rtems_gxx_recursive_mutex_init. | ||||
* | 2005-08-01 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-08-01 | 1 | -0/+4 |
| | | | | * libnetworking/sys/syslog.h: Partial update from FreeBSD. | ||||
* | Partial update from FreeBSD. | Ralf Corsepius | 2005-08-01 | 1 | -16/+15 |
* | 2005-07-28 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-07-28 | 1 | -0/+8 |
| | | | | | | | | * autotools/automake.add: Update to automake-1.9.6. * brp-rtems-strip.in: New. * brp-rtems-compress.in: New. * binutils/binutils.add: Reflect using brp-rtems*. * gccnewlib/gccnewlib.add: Reflect using brp-rtems*. | ||||
* | Reflect using brp-rtems*. | Ralf Corsepius | 2005-07-28 | 2 | -30/+32 |
* | New. | Ralf Corsepius | 2005-07-28 | 2 | -0/+72 |
* | Update to automake-1.9.6 | Ralf Corsepius | 2005-07-28 | 1 | -3/+3 |
* | Changes provided by Phillip Sorensen <pas37@cornell.edu> to get MVME550 BSP ↵ | Eric Norum | 2005-07-28 | 5 | -4/+13 |
| | | | | running. | ||||
* | Regenerate. | Ralf Corsepius | 2005-07-27 | 1 | -10/+10 |
* | 2005-07-27 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-07-27 | 2 | -1/+5 |
| | | | | * Makefile.am: Fix broken patch to mcf5235. | ||||
* | 2005-07-25 Philippe Simons <loki_666@fastmail.fm> | Philippe Simons | 2005-07-25 | 4 | -1/+685 |
| | | | | | * Makefile.am: added smc.rel. * smc/smc.c, smc/smc.h: New files. | ||||
* | Add some new regions. | Eric Norum | 2005-07-25 | 2 | -2/+6 |
* | Add .gnu.linkonce.b | Eric Norum | 2005-07-24 | 2 | -1/+5 |
* | Add .gnu.linkonce.b.* relocation. | Eric Norum | 2005-07-24 | 1 | -0/+1 |
* | 2005-07-18 Karel Gardas <kgardas@objectsecurity.com> | Joel Sherrill | 2005-07-18 | 2 | -1/+6 |
| | | | | | * libchip/network/if_fxp.c: Change status of PCI Id 0x1229 from UNTESTED to tested. | ||||
* | 2005-07-18 Lars Munch <lars@segv.dk> | Joel Sherrill | 2005-07-18 | 2 | -0/+11 |
| | | | | | | | | | | PR 813/networking * ne2000/ne2000.c: The ne2000 driver on pc386 has been broken since a parameter was added to irq handlers (2005-04-18). Before these changes the argument to the interrupt handler was the interrupt number, now the argument is handle, but the ne2000 driver needs the interrupt number. The fix is to set the handle to the interrupt number. | ||||
* | This commit was generated by cvs2svn to compensate for changes in r12147, | Ralf Corsepius | 2005-07-18 | 2 | -0/+234 |
|\ | | | | | which included commits to RCS files with non-trunk default branches. | ||||
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2005-07-18 | 2 | -0/+234 |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2005-02-06 | 1 | -0/+10 |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2005-02-06 | 1 | -0/+2 |
* | | Pass along errno from failed ftruncate(). | Eric Norum | 2005-07-13 | 2 | -0/+5 |
* | | 2005-07-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-07-08 | 2 | -7/+5 |
| | | | | | | | | * Makefile.am: Eliminate duplicate entry for include_mcf5235... . | ||||
* | | 2005-06-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-07-08 | 1 | -0/+4 |
| | | | | | | | | * mpc5xx/vectors/vectors.h: Add hack to avoid warning. | ||||
* | | 2005-07-07 Philippe Simons <loki_666@fastmail.fm> | Philippe Simons | 2005-07-07 | 1 | -156/+0 |
| | | | | | | | | * lcd/lcd.c: removed. | ||||
* | | 2005-07-07 Philippe Simons <loki_666@fastmail.fm> | Philippe Simons | 2005-07-07 | 9 | -1240/+295 |
| | | | | | | | | | | | | | | | | | | | | | | * Makefile.am: Remove lcd.rel, added console/uart.c, removed conio stuffs. * console/conio.c, console/console.c, console/defaultfont.c, include/conio.h : files removed. * console/uart.c: New file. * include/bsp.h: lcd.c prototypes removed. * startup/bspstart.c: bsp_reset() cause gp32 to reset to bios, added a bsp_idle_task which put s3c2400 in a "wait for IRQ" state. |
