* bootstrap: Add -p (regenerate preinstall.ams).
* libchip/network/dec21140.c: Fix spacing -- remove long sections of
blank lines.
* psxsem01/init.c: Account for change in POSIX semaphore time handling.
Previously the timeout was not absolute time and checked BEFORE
attempting to lock semaphore.
* sp09/screen12.c, sp16/task2.c, sp16/task3.c: Ensure tests generate
cases intended on all targets possible with new heap algorithm.
* score/inline/rtems/score/object.inl, score/src/objectnametoid.c:
Properly honor searching only local node even when on single CPU
system.
* score/src/coresemseize.c: Add missing ISR enable.
* score/src/heapwalk.c: Use printk not printf.
* libmisc/rtmonuse/rtmonuse.c: Do not use float for calculations.
* libcsupport/src/sync.c: Do not dereference NULL reent.
* posix/src/semtimedwait.c: Used wrong constant for blocking with bad
timeout value.
* posix/src/semtimedwait.c: Reverse accidentally included
semtimedwait.c.
* posix/src/keygetspecific.c, posix/src/keysetspecific.c,
posix/src/semtimedwait.c: Correct indexing of key data to use api and
index NOT class and index. Class is always 1.
* timer/timer.c: Update timer overhead for start/stop.
* runtest.in: Change toolname to match 4.8.
* clock_driver_stub.c, clockdrv_shell.c: Use common clock driver
template and eliminate all fast idle code specific to this BSP. This
eliminates a fair amount of code in the BSP clock driver and
bsp_startup. The LEON3 has to do a scan of the AMBA bus to find the
timer so I added the new hook Clock_driver_support_find_timer to
support this. In general, there was some clean up to the file headers
of various files.
* psim, psim-gdb, runtest: Change toolname to match 4.8.
* runtest: Change toolname to match 4.8.
* clock/clockdrv.c: Add copyright.
* itrontask04/init.c, itrontask04/itrontask04.scn: Cannot print with
dispatching disabled so fix test not to print while dispatching is
disabled.
* configure.ac: Suppress itron if int8/int16_t are not provided.
* configure.ac, Makefile.am, itron/Makefile.am, wrapup/Makefile.am:
Introduce AM_CONDITIONAL(LIBITRON).
Remove AM_CONDITIONAL(HAS_ITRON).
* wrapup/Makefile.am: Introduce AM_CONDITIONAL(LIBDOSFS).
* configure.ac, Makefile.am, libfs/Makefile.am:
* rtems/score/types.h: Remove unsigned64, signed64.
* libnetworking/libc/gethostbydns.c, libnetworking/libc/linkaddr.c,
libnetworking/libc/map_v4v6.c: Cosmetic updates from FreeBSD.
Eliminate bcopy in favor of memcpy.
* shared/bspstart.c, shared/start.S: Use common clock driver template
of various files.
* clock/ckinit.c, startup/bspstart.c: Use common clock driver template
of various files.
* clock/ckinit.c: Use common clock driver template and eliminate all
fast idle code specific to this BSP. This eliminates a fair amount of
code in the BSP clock driver and bsp_startup. The LEON3 has to do a
scan of the AMBA bus to find the timer so I added the new hook
Clock_driver_support_find_timer to support this. In general, there
was some clean up to the file headers of various files.
* clock/ckinit.c, console/console.c: Use common clock driver template
of various files.
* libnetworking/rtems/rtems_bsdnet_internal.h: Add timeout() define.
* libnetworking/rtems/rtems_glue.c: Rename timeout() into
rtems_bsdnet_timeout().
* libnetworking/sys/malloc.h: Remove contigmalloc (non-implemented).
Remove __P-guards from malloc, free.
* sapi/src/io.c: Fix spacing.
* sapi/include/confdefs.h: Enable memory for new objects.
* posix/Makefile.am: Add file missed in previous commit.
* posix/src/posixtimespecabsolutetimeout.c: New file.
* Makefile.am: Merge c_rtems_main() into boot_card(). This eliminated a
file and simplified initialization.
* shared/startup/bspstart.c: Merge c_rtems_main() into boot_card().
This eliminated a file and simplified initialization.
* Makefile.am, irq/irq.h: Merge c_rtems_main() into boot_card(). This
* bootcard.c: Merge c_rtems_main() into boot_card(). This eliminated a
* main.c: Removed.
* configure.ac: Remove RTEMS_AMPOLISH3.
* aclocal/bsp-configure.m4: AC_PREREQ(2.60).
Remove checks for AMPOLISH3.
* aclocal/rtems-ampolish.m4: Pick up ampolish3 from ac_aux_dir.
* aclocal/rtems-top.m4: Add RTEMS_AMPOLISH3.
* ampolish3: Remove.
