* sh7032/Makefile.am, sh7045/Makefile.am, sh7750/Makefile.am:
Remove build-variant support.
* Makefile.am: Remove build-variant support.
* mpc505/Makefile.am, mpc5xx/Makefile.am, mpc6xx/Makefile.am,
mpc8260/Makefile.am, mpc8xx/Makefile.am, ppc403/Makefile.am,
shared/Makefile.am: Remove build-variant support.
* mongoosev/Makefile.am, r46xx/Makefile.am, shared/Makefile.am,
tx39/Makefile.am: Remove build-variant support.
* m68040/Makefile.am, mcf5206/Makefile.am, mcf5272/Makefile.am,
* ChangeLog: Merge-in mcf5272/ChangeLog.
* mcf5272/ChangeLog: Remove.
* at91rm9200/Makefile.am, mc9328mxl/Makefile.am,
* ChangeLog: Merge-in at91rm9200/ChangeLog, mc9328mxl/ChangeLog,
shared/ChangeLog.
* at91rm9200/ChangeLog, mc9328mxl/ChangeLog, shared/ChangeLog:
Remove.
* Makefile.am: Remove ACLOCAL_FILES.
* Makefile.am: Remove DIST_SUBDIRS.
* console/leds.c: Fix prototype of led_putnum().
* automake/compile.am: Remove build-variant support.
* libnetworking/pppd/Makefile.am,
libnetworking/rtems_servers/Makefile.am,
libnetworking/rtems_telnetd/Makefile.am:
* libchip/Makefile.am, librdbg/Makefile.am, optman/Makefile.am
support/Makefile.am, wrapup/Makefile.am:
* compilers/gcc-portsw.cfg: Remove.
* Makefile.am: Reflect change above.
* configure.ac: Use AS_HELP_STRING instead of AC_HELP_STRING.
* automake/compile.am, httpd/Makefile.am, itron/Makefile.am,
libblock/Makefile.am, libcsupport/Makefile.am, libfs/Makefile.am,
libmisc/Makefile.am, libnetworking/Makefile.am, librpc/Makefile.am,
posix/Makefile.am, rtems/Makefile.am, sapi/Makefile.am,
score/Makefile.am, wrapup/Makefile.am:
* Makefile.am, psim: Split psim into two files.
* psim-gdb: New file.
* httpd/rtems_webserver.h: Add doxygen preamble.
Add C++ guards.
* httpd/Makefile.am: Remove -DOS="RTEMS".
* acinclude.m4: Reflect eth_comm having been removed.
* score/include/rtems/score/chain.h:
Use uint32_t instead of unsigned32.
* score/src/chain.c: Remove superfluous type cast.
PR 704/bsps.
* ide_ctrl.c: Removed (obsolete).
PR 733/rtems
* rtems/score/cpu.h: Remove output arg from inline asm in
_CPU_ISR_Disable.
* posix/include/aio.h, posix/include/devctl.h,
posix/include/intr.h, posix/include/mqueue.h,
posix/include/sched.h, posix/include/semaphore.h,
posix/src/ptimer.c, posix/src/ptimer1.c:
Include <unistd.h> instead of <sys/features.h> to pick up
_POSIX_* defines (Mandated by POSIX).
* score/include/rtems/system.h: Don't define NULL, include
<stddef.h>.
* cpu_asm.S: Collected PR 601 changes for commit to cvshead
for rtems-4.7
Greg Menke 12/06/2004
* bootloader/pci.c: Removed the r->size=0 and r->base=0
assignement which makes too-large regions conflict with onboard
hardware, replacing it with sfree which deletes the memory region
from the setup code, leaving it disabled.
* libnetworking/net/if_ethersubr.c,
libnetworking/net/radix.h,
libnetworking/netinet/if_ether.h,
libnetworking/netinet/igmp_var.h,
libnetworking/netinet/in_var.h,
libnetworking/netinet/tcp_timer.h,
libnetworking/netinet/udp_usrreq.c,
libnetworking/rtems/rtems_glue.c:
Misc. updates from FreeBSD and bugfixes tripped by GCC-4.0.0.
* libnetworking/kern/kern_sysctl.c,
libnetworking/sys/sysctl.h: Add SYSCTL_CHILDREN_SET
(Update from FreeBSD for GCC-4.0.0).
* libnetworking/kern/kern_sysctl.c, libnetworking/netinet/ip_mroute.c,
libnetworking/sys/socketvar.h: Remove warnings.
* libnetworking/net/radix.c, libnetworking/net/radix.h,
libnetworking/net/route.h, libnetworking/netinet/if_ether.h,
libnetworking/netinet/in_var.h, libnetworking/netinet/tcp_timer.h,
libnetworking/netinet/udp_usrreq.c, libnetworking/netinet/udp_var.h,
libnetworking/sys/callout.h, libnetworking/sys/socketvar.h,
libnetworking/sys/sysctl.h: Cosmetics from FreeBSD.
* libmisc/capture/capture-cli.h, libmisc/capture/capture.h,
libmisc/monitor/monitor.h, libmisc/rtmonuse/rtmonuse.h,
libmisc/shell/shell.h: Partial doxygenification.
* libmisc/capture/capture.h: Use INT32_C for constants.
* libcsupport/include/chain.h,
libcsupport/include/clockdrv.h,
libcsupport/include/console.h,
libcsupport/include/iosupp.h,
libcsupport/include/ringbuf.h,
libcsupport/include/rtc.h,
libcsupport/include/spurious.h,
libcsupport/include/timerdrv.h,
libcsupport/include/vmeintr.h,
libcsupport/include/motorola/mc68230.h,
libcsupport/include/motorola/mc68681.h,
libcsupport/include/rtems/assoc.h,
libcsupport/include/rtems/cdefs.h,
libcsupport/include/rtems/error.h,
libcsupport/include/rtems/libcsupport.h,
libcsupport/include/rtems/libio.h,
libcsupport/include/rtems/libio_.h,
libcsupport/include/rtems/termiostypes.h,
libcsupport/include/zilog/z8036.h,
libcsupport/include/zilog/z8530.h,
libcsupport/include/zilog/z8536.h: Add doxygen preamble.
* libcsupport/src/mallocfreespace.c, rtems/Makefile.am,
rtems/include/rtems/rtems/region.h, score/Makefile.am,
score/include/rtems/score/heap.h, score/src/heapgetinfo.c: Add
capability to return information about just the free blocks in a
region or heap. Also changed the semantics of free space available
to be the largest block of memory that can be allocated.
* rtems/src/regiongetfreeinfo.c, score/src/heapgetfreeinfo.c: New files.
: score/include/rtems/score/object.h,
score/src/objectinitializeinformation.c: Remove warning.
* timer/timerisr.S: Include rtems/asm.h not asm.h
* startup/linkcmds: Add new bss sections .bss.* and .gnu.linkonce.b*.
