* start/Makefile.am: Eliminate PGMS.
bsplib_DATA += $(PROJECT_RELEASE)/lib/except_vect_332_ROM$(LIB_VARIANT).o
bsplib_DATA += $(PROJECT_RELEASE)/lib/ram_init$(LIB_VARIANT)
bsplib_DATA += $(PROJECT_RELEASE)/lib/ram_init_FW$(LIB_VARIANT)
Add bsplib_DATA = $(PROJECT_RELEASE)/lib/rxgen_romld$(LIB_VARIANT).o.
* start/Makefile.am: Remove leftover from eliminating PGM.
Add bsplib_DATA += $(PROJECT_RELEASE)/lib/start16$(LIB_VARIANT).bin.
* capture/capture.c: include <string.h> for memset.
* startup/Makefile.am: Add bsplib_DATA = linkcmds device-tree.
* startup/Makefile.am: Add bsplib_DATA = linkcmds linkcmds-le.
* startup/Makefile.am: Add bsplib_DATA = linkcmds linkcmds.rom
linkcmds.rom2ram.
* startup/Makefile.am: Add bsplib_DATA = linkcmds ghlinkcmds.
* startup/Makefile.am: Add bsplib_DATA = linkcmds rom debugger.
* startup/Makefile.am: Add bsplib_DATA = linkcmds linkcmds_ROM.
* startup/Makefile.am: Add bsplib_DATA = linkcmds gdbinit
linkcmds.flash.
* startup/Makefile.am: Add bsplib_DATA = linkcmds linkcmds.prom
linkcmds.bootp.
* include/rtems/score/apimutex.h (_API_Mutex_Lock): Added missing
_ISR_Disable.
* setup.def: Updated newlib patch to get sh and hppa crt0 mods.
* startup/Makefile.am: Add bsplib_DATA = linkcmds ramlink romlink.
* Makefile.am: Remove setting up bsplibdir.
* bsp.am: Add bsplib_DATA = bsp_specs.
* aclocal/env-rtemsbsp.m4: Add libdir, bsplibdir.
* aclocal/rtems-top.m4: Reflect relocation of c/src/exec to cpukit.
* aclocal/check-cpu.m4: Ditto.
* aclocal/check-bsps.m4: Ditto.
* aclocal/version.m4: Updated to rtems-ss-20020717.
* irq_bsp_irq_asm.S: Update to reflect irq_asm modifications.
* irq/irq_asm.S: Significant rework in attempt to make interrupts
work. They appear to be very close to correct but not 100%.
* start/start.S: Added SWI_Handler.
* irq/bsp_irq_asm.S: Disable code to touch PIC.
* rtems/score/cpu_asm.h: Enhanced to include register offsets.
* Makefile.am: Install rtems/score/cpu_asm.h.
* cpu.c: Significantly enhanced including the implementation of
_CPU_ISR_Get_level.
* cpu_asm.S: Improved behavior of context switch and interrupt
dispatching.
* rtems/score/arm.h: Improved the CPU model name determination.
* rtems/score/cpu.h: Improved interrupt disable/enable functions.
* netinet/in.h, netinet/ip.h, netinet/ip_var.h, netinet/tcp.h:
Modified to added packed attribute.o
* New driver for the Intel EtherExpressPro (82559ER) chip.
* network/if_fxp.c, network/if_fxpreg.h, network/if_fxpvar.h,
network/pci.h: New file.
* network/Makefile.am: Modified to reflect above.
* console/console.c: Others on the rtems-users list have expressed
concern about this run-time selection, so I've enclosed the changes
in a #ifdef RTEMS_RUNTIME_CONSOLE_SELECT conditional.
* comm/uart.c: I am using a PC-104 card with no video output. I
found that things would lock up if a printk was followed closely by
a printf when BSPConsolePort = BSP_UART_COM2 and
BSPPrintkPort = BSP_UART_COM1. With this change in place,
printf/printk calls can be intermingled with no apparent problems.
* cpu_asm.S: Added SR_IEO to context restore to fix isr disabled
deadlock caused by interrupt arriving while dispatching.
* macros/rtems/score/object.inl: Corrected typos in
_Objects_Open, _Objects_Close, and _Objects_Namespace_remove.
* config-ml.in: Imported from gcc-3.1.
Change to match c/src/config-ml.in.
