* inline/rtems/rtems/attr.inl: Correct typo and use correct
attribute RTEMS_SYSTEM_TASK. Reported by Chris Johns <ccj@acm.org>.
* src/coremutexseize.c: Add missing code for proper handling
of nesting acquisitions. This only impacts building with
inlines disabled on the source with the "fast mutex" optimizations.
This was post the 4.5 branch and did not impact released versions.
* .cvsignore: Add buildalltar.
* buildalltar.in: New file.
* configure.in, Makefile.am: Modified to reflect addition of file.
* macros/rtems/posix/mqueue.inl: Add cast so negation works.
* include/Makefile.am: Include coverhd.h so tmtests will compile.
* include/rtems/libio_.h: Added ifdef to ensure that LOGIN_NAME_MAX
is defined on GNU/Linux (RedHat 6.2 distribution).
* libc/unixlibc.c: Added stubs for rtems_io_register_name() and
rtems_io_lookup_name() so UNIX port would compile the IO manager
sptest that registers /dev/null.
* pppd/STATUS: Updated by Joel based upon email from Mike.
* pppd/cbcp.c, pppd/cbcp.h: Readded files. These support callback
functionality that has not even been compiled under RTEMS yet.
* score/cpu_asm.c (sh_set_irq_priority): Changed interrupt vector
number range check and handling of interrupt priority regs to
conform SH2 specs.
* sci/sci_termios.c: New file.
* include/sci_termios.h: New file.
* include/Makefile.am (EXTRA_DIST): Added sci_termios.h.
(include_sh_HEADERS): Added sci_termios.h.
* score/ispsh7045.c (isp): Calling an ISR with immediate argument
casued negative sign extension for vector numbers of 128 and
above. This was fixed.
* sci/sci.c: Cleaned initialization of SCI registers; added
necessary setup for new TERMIOS console cooperation
* libc/lseek.c: Modified after discussion with Eugeny S. Mints
<jack@oktet.ru> to correct the behavior. There were two mistakes.
First, iop->offset was incorrectly set for SEEK_END. Second,
iop->offset should be left unmodified if there are errors.
This modification attempts to fix both situations.
conform SH2 specs.
* include/bsp.h: Disabled redefinition of
CONSOLE_DRIVER_TABLE_ENTRY. Some "FIXME:" comments added.
* console/config.c: New file. Definitions of externs referenced
from libbsp/shared/console.c.
* console/Makefile.am: Changed VPATH to point to
libbsp/shared. Added config.c to C_FILES and EXTRA_DIST.
* mw-fb\Makefile.am: Corrected problem.
* cpu.c (_CPU_ISR_install_vector): Corrected interrupt range
checking which was SH1 specific. It didn't work for SH2 (has more
interrupt sources).
conform SH2 specs.
* pppd/example/Makefile: Removed.
* pppd/example/Makefile-user: Added was Makefile. Renamed to
avoid bootstrap -c clobbering it.
* libc/termios.c: Fix a bug in the termios implementation in
the following scenario:
The General Terminal Interface document that me states that
if VMIN = 0 and VTIME = 0, then read() should return the minimum
of two values:
a) number of bytes available
b) number of bytes requested (I assume from the read call)
The current implementation of the fillBufferQueue() in termios.c is
always return 1 character with these setting values. I know the
termios buffer has more than one character available and my read()
call is requesting 1024 bytes.
* comm/tty_drv.c, comm/uart.c: Correct some minor cut and paste bugs.
* include/rtems/termiostypes.h, include/sys/ioccom.h:
Update of PPPD to 2.3.11 from 2.3.5 touched these files.
* Update of PPPD to 2.3.11 from 2.3.5 and addition of an example
application. Mike's notes on the modifications:
- renamed error() function because of namespace problems
- removed calls to the exit() funciton
- removed extra files from the pppd source directory
- defined pppd task constant values in rtemspppd.h
- modifyied example code to get actual tick per second value
- placed the pppd 2.3.11 man page file (pppd.8) into the pppd
directory
* pppd/cbcp.c, pppd/cbcp.h, pppd/main.c, pppd/ppp_tty.c,
pppd/pppmain.c, pppd/rtems-ppp.c, pppd/rtems-ppp.c: Deleted.
* pppd/pppd.8, pppd/rtemsmain.c, pppd/rtemspppd.c, pppd/rtemspppd.h,
pppd/sys-rtems.c, pppd/utils.c, pppd/example/Makefile,
pppd/example/README, pppd/example/init.c, pppd/example/netconfig.h,
pppd/example/ppp.conf, pppd/example/pppdapp.c, pppd/example/system.h:
New files.
* modem/ppp_tty.c, net/if_ppp.h, pppd/Makefile.am, pppd/README,
pppd/STATUS, pppd/auth.c, pppd/ccp.c, pppd/ccp.h, pppd/chap.c,
pppd/chap.h, pppd/chap_ms.c, pppd/chap_ms.h, pppd/chat.c,
pppd/demand.c, pppd/fsm.c, pppd/fsm.h, pppd/ipcp.c, pppd/ipcp.h,
pppd/ipxcp.c, pppd/ipxcp.h, pppd/lcp.c, pppd/lcp.h, pppd/magic.c,
pppd/magic.h, pppd/options.c, pppd/patchlevel.h,
pppd/pathnames.h, pppd/pppd.h, pppd/upap.c, pppd/upap.h: Modified.
of two values:
* clock/clock.c: Ensure that clock ticks are long enough to
make forward progress. This was modified to improve results
on the RTEMS tests and the ACATS.
* startup/linkcmds: Modified to work better with gcc 2.8.1 and
gnat 3.13p.
* src/msgqsubmit.c: Add a comment indicating that we do not have
to account for possibly blocking during the core send operation
because Classic API message queue send is always non-blocking.
* src/mqueuesendsupp.c: Account for possibly blocking during the
core send operation.
* setup.def, gnatnewlib/gnatnewlib.spec.in: Modified to properly
build gnat 3.13p-2 RPMs. These were used to run the ACATS with
the following results on the powepc-rtems/psim:
acats4gnat results cz 3 / 4
acats4gnat results a 75 / 75
acats4gnat results c2 35 / 35
acats4gnat results c3 347 / 349
acats4gnat results c4 333 / 338
acats4gnat results c5 95 / 95
acats4gnat results c6 81 / 81
acats4gnat results c7 47 / 50
acats4gnat results c8 140 / 140
acats4gnat results c9 246 / 255
acats4gnat results ca 73 / 74
acats4gnat results cb 43 / 43
acats4gnat results cc 117 / 117
acats4gnat results cd 172 / 172
acats4gnat results ce 262 / 268
acats4gnat results cxa 85 / 85
acats4gnat results cxb 29 / 30
acats4gnat results cxc 9 / 16
acats4gnat results cxd 27 / 39
acats4gnat results cxe 1 / 1
acats4gnat results cxf 20 / 20
acats4gnat results cxg 28 / 29
acats4gnat results cxh 4 / 4
acats4gnat results d 4 / 4
acats4gnat results e 11 / 11
acats4gnat results l 26 / 26
This compares favorably with the results on Linux. Laurent
Guerby's <guerby@acm.org> acats4gnat-0.2 scripts were used
with minor modifications to support cross testing.
* include/tmacros.h: Attempt to print errno as further information.
* sp20/system.h: Account for extra task stacks properly.
* sp13/sp13.scn: Id in screen had wrong class field value.
* sp13/system.h: Account for message buffer memory.
* sp13/task2.c: Remove unnecessary check for failure.
* tools/runtest.in: Recognize debug variant of monitor test.
gnat 3.13p.
* src/coremutexsurrender.c: Use holder thread not executing
thread because even though they may and often are the same
it is not guaranteed unless the proper attribute is set.
* include/rtems/score/coremsg.h, src/coremsgsubmit.c: Add a new
return status to account for blocking sends. Otherwise, the
caller will think that the returned message status will have
the ultimate results of the operation. If the send times out,
the final status will be in the return_code of the thread.
* rtems_telnetd/.cvsignore: New file.
* mkgdbspec.in: Make list of simulators very complete.
* setup.def: Update versions.
* shell/pty.c: Moved to libnetworking/rtems_telnetd.
* libc/getgrent.c, libc/getpwent.c: the 'ls' and more related command
previous failed after a chroot(). (unknown user & group)
* src/imfs/imfs_eval.c: The CD_UP problem in imfs_eval has been
touched. The order of the questions is the key.
* shell/Makefile.am, shell/README, shell/cmds.c, shell/shell.c,
shell/shell.h: Updates.
* Makefile.am, configure.in, rtems_servers/Makefile.am,
rtems_servers/telnetd.c, rtems_servers/telnetd.h,
rtems_telnetd/Makefile.am, rtems_telnetd/README, rtems_telnetd/icmds.c,
rtems_telnetd/pty.c, rtems_telnetd/pty.h, rtems_telnetd/telnetd.c,
rtems_telnetd/telnetd.h, wrapup/Makefile.am:
- pty and telnetd have a new subdir rtems_telnetd to avoid
the side effect when ftpd change.
- the tcp/ip stats have been implemented into icmds.c and
started when telnetd daemon is started.
* rtems_servers/telnetd.c, rtems_servers/telnetd.h: Removed.
* rtems_telnetd: New directory.
* rtems_telnetd/Makefile.am, rtems_telnetd/README,
rtems_telnetd/icmds.c, rtems_telnetd/pty.c, rtems_telnetd/pty.h,
rtems_telnetd/telnetd.c, rtems_telnetd/telnetd.h: New files.
* psxchroot01/.cvsignore, psxchroot01/Makefile.am, psxchroot01/main.c,
psxchroot01/psxchroot01.scn, psxchroot01/test.c: Implemented the
psxchroot01 test.
* monitor/mon-command.c: Add support for partial command matching.
The monitor used to have this functionality before it was overhauled
to support addition of user commands.
* cpu_asm.S: This patch was co-developed with Eric Norum
<eric.norum@usask.ca>. It closes a one instruction window
on some m68k CPU cores. It fixes symptoms seen as:
1) No more `interrupt handler invoked twice for
a single interrupt'.
2) No more `lockup when mc68360 CPM and PIT interrupts
are at different levels'.
It does insert a little more overhead on machines without hardware
interrupt stacks but correctness has a price.
* src/snd_mbx.c, src/tsnd_mbf.c: Unblocking message queue operations
should NOT use _Thread_Executing for return status since it is
permissible to invoke message send operations from an ISR. This was
reported by Suvrat Gupta <suvrat@utstar.com>.
* src/mqueuesendsupp.c: Unblocking message queue operations should
