* Makefile.am: Cosmetics.
* configure.ac: Remove make/custom/Makefile.
* automake/compile.am: Remove compilation rules.
Remove $(ARCH) directory generation.
* custom/Makefile.am: Remove.
* Makefile.am: Merge-in former custom/Makefile.am
* autotools/Makefile.am: Cosmetics.
* autotools/autoconf-rtems.spec.in: 2.59.
* autotools/automake-rtems.spec.in: 1.8, Require autoconf-2.59.
* binutils/Makefile.am: Cosmetics.
* cpukit/Makefile.am: Cosmetics.
* gcc3newlib/Makefile.am: Cosmetics.
* gccnewlib/Makefile.am: Cosmetics.
* gdb/Makefile.am: Cosmetics.
* rtems/Makefile.am: Cosmetics.
* rtemsdoc/Makefile.am: Cosmetics.
* configure.ac: Cosmetics.
* Makefile.am: Use include_ada_HEADERS.
* psxcancel/Makefile.am: Remove used H_FILES.
* Makefile.am: Use bsptools_bin_SCRIPTS to install scripts.
PR 540/rtems_misc
* cpuuse/cpuuse.c, rtmonuse/rtmonuse.c: Correct object name printing.
PR 531/rtems_misc
* rtmonuse/rtmonuse.c, stackchk/check.c: Correct indexing.
* startup/Makefile.am: Add custom compilation rule for
rtems-ctor$(LIB_VARIANT).$(OBJEXT).
* aclocal/env-rtemsbsp.m4: AC_SUBST(project_libdir).
* automake/lib.am: Remove project_libdir.
* wrapup/Makefile.am: Reworked.
* bsp.am: Remove project_libdir.
* Makefile.am: Add dirstamp support.
* Makefile.am: Misc. fixes.
* bsp.am: Add project_libdir.
* Makefile.am: Misc cleanups and fixes.
* Makefile.am: install runtest to bsptools_bindir.
* wrapup/Makefile.am: Build libcpu.a.
Don't preinstall libcpu.a
* clock/Makefile.am: Misc cleanups and fixes.
* timer/Makefile.am: Misc cleanups and fixes.
* configure.ac: Require automake 1.7.2.
* console/Makefile.am: Misc cleanups and fixes.
* i2c/Makefile.am: Misc cleanups and fixes.
* nvram/Makefile.am: Misc cleanups and fixes.
* tod/Makefile.am: Misc cleanups and fixes.
* startup/linkcmds: Preparations for gcc-3.3.x.
* bootloader/Makefile.am: Misc cleanups and fixes.
* motorola/Makefile.am: Misc cleanups and fixes.
* startup/linkcmds: Preparations to gcc-3.3.x.
