* | added priority ceiling support | Joel Sherrill | 1996-06-03 | 4 | -66/+126 |
* | added an assert if a pthread_t is not the same size as an Objects_Id | Joel Sherrill | 1996-06-03 | 2 | -4/+10 |
* | deleted POSIX threads typedef masking Thread_Control | Joel Sherrill | 1996-06-03 | 7 | -41/+184 |
| | | | | added initial version of pthread_detach and pthread_join | ||||
* | deleted POSIX threads typedef masking Thread_Control | Joel Sherrill | 1996-06-03 | 6 | -33/+18 |
* | updated screen | Joel Sherrill | 1996-06-03 | 10 | -80/+68 |
* | added test code for return of remaining time from sleep(). | Joel Sherrill | 1996-06-03 | 2 | -4/+16 |
* | sleep moved into newlibc.c so the sleep.o object would not be in the library. | Joel Sherrill | 1996-06-03 | 3 | -3/+78 |
| | | | | | This implementation of sleep is now only used when the POSIX API is not configured. | ||||
* | added test case for nanosleep filling in the time remaining structure. | Joel Sherrill | 1996-06-03 | 2 | -0/+2 |
* | nanosleep now fills in the time remaining structure. | Joel Sherrill | 1996-06-03 | 2 | -8/+6 |
* | renamed _POSIX_Time_Spec_to_interval to _POSIX_Timespec_to_interval | Joel Sherrill | 1996-06-03 | 15 | -43/+127 |
* | added test code for nanosleep and return code from sleep. | Joel Sherrill | 1996-06-03 | 2 | -4/+54 |
* | created ptimer.c and moved the timer_* routines out of time.c into ptimer.c | Joel Sherrill | 1996-06-03 | 4 | -116/+152 |
* | added constant for seconds between posix epoch (1970) and rtems epoch (1988). | Joel Sherrill | 1996-06-03 | 3 | -0/+33 |
| | | | | Formerly this constant was in the file src/time.c. | ||||
* | changed so this file is usable from assembly files. | Joel Sherrill | 1996-06-03 | 3 | -150/+192 |
| | | | | no longer uses efi332.h | ||||
* | added ifdef for sunos 4.x since it does not have strtoul. | Joel Sherrill | 1996-06-03 | 4 | -8/+24 |
* | renamed _TOD_Ticks_since_boot as _Watchdog_Ticks_since_boot so the Watchdog | Joel Sherrill | 1996-05-31 | 27 | -38/+55 |
| | | | | | Handler could timestamp the starting and stopping of timers. Since TOD is built on top of Watchdog, this avoided a circular dependency. | ||||
* | added checks to validate values passed to set attribute routines | Joel Sherrill | 1996-05-31 | 12 | -52/+210 |
* | fixed typo in merge of Eric Norum's patch | Joel Sherrill | 1996-05-31 | 1 | -2/+1 |
* | added nanoseconds per second constant | Joel Sherrill | 1996-05-31 | 3 | -3/+6 |
* | corrected minor problem in Eric Norum's changes in the bfffo macro. | Joel Sherrill | 1996-05-31 | 1 | -1/+1 |
* | moved sleep() from psignal.c to unistd.c | Joel Sherrill | 1996-05-31 | 7 | -52/+209 |
| | | | | | | | implemented sigemptyset() sigfillset(), sigaddset(), sigdelset(), and sigismember(). added checks for valid attribute values to some of the pthread_attr_t sets. | ||||
* | commented out cancel handlers related items. | Joel Sherrill | 1996-05-31 | 3 | -0/+9 |
* | moved attribute related constants into the rtems specific sys/types.h | Joel Sherrill | 1996-05-31 | 2 | -26/+0 |
| | | | | file in newlib. | ||||
* | added code to test clock and time related functionality. | Joel Sherrill | 1996-05-30 | 4 | -34/+126 |
* | Added nanoseconds constant | Joel Sherrill | 1996-05-30 | 3 | -6/+9 |
* | First cut at implementing time, clock_gettime, clock_settime, clock_getres, | Joel Sherrill | 1996-05-30 | 4 | -34/+336 |
| | | | | | sleep, and nanosleep. Does not yet support per process clock, per thread clock, interruptible sleep (sleep/nanosleep), or time remaining on nanosleep. | ||||
* | added dummy versions of __kill and __getpid which assert(0) so that | Joel Sherrill | 1996-05-30 | 3 | -0/+69 |
| | | | | | applications which use only the rtems api (i.e. not the posix api) will link. | ||||
* | Eric Norum sent in new versions of the inline assembly macros which | Joel Sherrill | 1996-05-30 | 2 | -82/+17 |
| | | | | do not generate warnings for unitialized variables. | ||||
* | tests now specify whether they are using rtems initialization tasks | Joel Sherrill | 1996-05-30 | 58 | -0/+116 |
| | | | | or posix initialization threads | ||||
* | tests now specify whether using posix initialization threads table | Joel Sherrill | 1996-05-29 | 103 | -51/+327 |
| | | | | or rtems initialization table in configuration table | ||||
* | posix initialization threads table was misnamed "posix initialization | Joel Sherrill | 1996-05-29 | 8 | -88/+90 |
| | | | | tasks table" | ||||
* | comment clean up | Joel Sherrill | 1996-05-29 | 31 | -62/+39 |
* | types.c: spacing | Joel Sherrill | 1996-05-29 | 4 | -56/+66 |
| | | | | | psignal.c: kill recognizes SIGABRT and exits to prevent asserts from recursively occurring because kill was not implemented and asserted. | ||||
* | fixed support for posix initialization threads table | Joel Sherrill | 1996-05-29 | 3 | -6/+66 |
* | simple version of test which shows pthread_create, pthread_exit, and exit | Joel Sherrill | 1996-05-29 | 6 | -8/+38 |
| | | | | are basically working. This test will be enhanced further. | ||||
* | added pthread_exit | Joel Sherrill | 1996-05-29 | 2 | -16/+90 |
| | | | | first posix thread ran | ||||
* | cleaned up spacing and parentheses | Joel Sherrill | 1996-05-29 | 3 | -6/+6 |
* | spacing | Joel Sherrill | 1996-05-29 | 2 | -0/+2 |
* | first cut at pthread_create | Joel Sherrill | 1996-05-29 | 5 | -17/+153 |
* | addressed minimum stack size attribute. | Joel Sherrill | 1996-05-29 | 2 | -2/+8 |
| | | | | | | | There is a potential problem if setting PTHREAD_STACK_MIN to 0 does not work with all applications since it is in limit.h over in newlib. There is a potential build order issue with newlib needing to know the rtems cpu dependent stack size minimum. | ||||
* | *** empty log message *** | Joel Sherrill | 1996-05-29 | 2 | -0/+6 |
* | removed all ifdef's on NOT_IMPLEMENTED. | Joel Sherrill | 1996-05-29 | 19 | -84/+60 |
* | added entry point for posix initialization threads to the posix initialization | Joel Sherrill | 1996-05-29 | 3 | -6/+24 |
| | | | | threads table structure | ||||
* | Addressed RTEMS API initialization tasks table in a system without | Joel Sherrill | 1996-05-29 | 3 | -9/+21 |
| | | | | RTEMS initialization tasks. | ||||
* | Gutted test of rtems api calls and added comments to indicate what the test | Joel Sherrill | 1996-05-29 | 6 | -154/+62 |
| | | | | should do in their place. It now compiles and links. | ||||
* | Added default POSIX API configuration table. | Joel Sherrill | 1996-05-29 | 2 | -2/+26 |
* | It is now not an error to have 0 RTEMS initialization tasks since you could | Joel Sherrill | 1996-05-29 | 2 | -0/+12 |
| | | | | create POSIX initialization threads. | ||||
* | renamed signal.c to psignal.c to avoid naming problems. | Joel Sherrill | 1996-05-29 | 10 | -14/+238 |
| | | | | | | added mp stubs to cond.c and mutex.c to eliminate link errors. added pthread_exit to pthread.c | ||||
* | split the inclusion of "EXTERN" data based on whether it was sapi, | Joel Sherrill | 1996-05-28 | 137 | -333/+559 |
| | | | | score, rtems api, or posix api related. | ||||
* | added maximum keys | Joel Sherrill | 1996-05-28 | 3 | -3/+3 |
