* | m68k/mvme167: Compiles again | Joel Sherrill | 2013-01-08 | 3 | -48/+36 |
| | | | | | | Was including non-existent .h file. Fixed some warnings. Reformatted file header comment blocks. | ||||
* | arm/smdk2410: Update to include bspidle.c | Joel Sherrill | 2013-01-08 | 1 | -1/+1 |
| | | | | | This BSP shares code with the gp32 and needed to include the new bspidle.c file. | ||||
* | arm/gp32: Correct compilation error in BSP Idle Thread | Joel Sherrill | 2013-01-08 | 4 | -24/+38 |
| | | | | | | | Split BSP Idle Thread into separate file to follow convention used on other BSPs. Slight reformatting of file header comment block. | ||||
* | score: Doxygen Clean Up Task #15 | Alex Ivanov | 2013-01-08 | 20 | -733/+769 |
* | libfs: Doxygen Clean Up Task #1 | Alex Ivanov | 2013-01-08 | 19 | -482/+666 |
| | | | | | | http://www.google-melange.com/gci/task/view/google/gci2012/8120204 Patch committed with fixes for whitespace issues. | ||||
* | sapi: Doxygen Clean Up Task #1 | Alex Ivanov | 2013-01-08 | 18 | -770/+791 |
* | libcsupport: Doxygen Clean Up Task #1 | Alex Ivanov | 2013-01-08 | 15 | -143/+162 |
* | sapi: Add rtems_fatal_source_description() | Sebastian Huber | 2013-01-07 | 6 | -3/+123 |
* | bsp/lpc24xx: Declare conditionally | Sebastian Huber | 2013-01-07 | 1 | -0/+4 |
* | posix: Doxygen Clean Up Task #1 | Alex Ivanov | 2013-01-07 | 20 | -345/+419 |
* | score: Doxygen Clean Up Task #11 | Mathew Kallada | 2013-01-07 | 20 | -830/+1068 |
* | rtems: Simplify _Event_Surrender() | Sebastian Huber | 2013-01-07 | 1 | -28/+14 |
| | | | | Check for a satisfied event condition only once. | ||||
* | rtems: Simplify _Event_Surrender() | Sebastian Huber | 2013-01-07 | 1 | -4/+6 |
| | | | | Remove superfluous test for _ISR_Is_in_progress(). | ||||
* | rtems: Simplify _Event_Surrender() | Sebastian Huber | 2013-01-07 | 1 | -2/+1 |
| | | | | | | | It is impossible to reach the simplified expression if we are in the THREAD_BLOCKING_OPERATION_TIMEOUT state since in this case Wait.count (event condition) would be set to zero and thus the seized event set would be empty. | ||||
* | rtems: Critical fix for events | Sebastian Huber | 2013-01-07 | 3 | -30/+301 |
| | | | | | | | Commit 4b45c1393ce4ee3e1c2762ef3145d2bd6b5b38da marked a test in _Event_Timeout() as debug only. This test is required also in non-debug configurations since otherwise state corruption can happen. A revised test sptests/spintrcritical10 checks the relevant sequences. | ||||
* | rtems: Add comment | Sebastian Huber | 2013-01-07 | 1 | -0/+5 |
* | bsp/lpc32xx: System reset after fatal conditions | Sebastian Huber | 2013-01-07 | 1 | -1/+1 |
* | bsp/lpc24xx: System reset after fatal conditions | Sebastian Huber | 2013-01-07 | 1 | -1/+1 |
* | bsp/lpc24xx: Request system reset for LPC17XX | Sebastian Huber | 2013-01-07 | 1 | -4/+6 |
* | bsp/lpc24xx: Add WWDT module defines | Sebastian Huber | 2013-01-07 | 1 | -1/+21 |
* | arm: Add AIRCR register defines | Sebastian Huber | 2013-01-07 | 1 | -0/+15 |
* | arm: Implement CPU_Exception_frame_print() | Sebastian Huber | 2013-01-07 | 3 | -35/+40 |
* | arm: Add and use _ARMV7M_Exception_default() | Sebastian Huber | 2013-01-07 | 4 | -15/+72 |
* | arm: Include <rtems/score/cpu.h> | Sebastian Huber | 2013-01-07 | 16 | -40/+20 |
* | arm: Provide CPU_Exception_frame for ARMv7-M | Sebastian Huber | 2013-01-07 | 1 | -14/+12 |
* | arm: Rename inline functions | Sebastian Huber | 2013-01-07 | 3 | -6/+6 |
| | | | | | Rename arm_status_irq_enable() to _ARMV4_Status_irq_enable() and arm_status_restore() to _ARMV4_Status_restore(). | ||||
* | arm: Move inline functions | Sebastian Huber | 2013-01-07 | 3 | -34/+36 |
* | arm: Add and use default exception handler | Sebastian Huber | 2013-01-07 | 4 | -15/+147 |
| | | | | | | | | Add and use _ARMV4_Exception_undef_default(), _ARMV4_Exception_swi_default(), _ARMV4_Exception_data_abort_default(), _ARMV4_Exception_pref_abort_default(), _ARMV4_Exception_reserved_default(), _ARMV4_Exception_irq_default(), and _ARMV4_Exception_fiq_default(). | ||||
* | arm: Add and use _ARM_Exception_default() | Sebastian Huber | 2013-01-07 | 4 | -4/+31 |
* | arm: Change CPU_Exception_frame | Sebastian Huber | 2013-01-07 | 4 | -33/+27 |
| | | | | | Provide proper CPU_Exception_frame definition for ARMv4 and use it. Remove arm_cpu_context. | ||||
* | arm: Rename type and functions | Sebastian Huber | 2013-01-07 | 2 | -13/+17 |
| | | | | | | | | | | Rename arm_exc_abort_handler to ARMV4_Exception_abort_handler, arm_exc_data_abort() to _ARMV4_Exception_data_abort(), arm_exc_data_abort_set_handler() to _ARMV4_Exception_data_abort_set_handler(), arm_exc_prefetch_abort() to _ARMV4_Exception_prefetch_abort(), and arm_exc_prefetch_abort_set_handler() to _ARMV4_Exception_prefetch_abort_set_handler(), | ||||
* | arm: Move type definition and prototypes | Sebastian Huber | 2013-01-07 | 2 | -10/+10 |
* | arm: Rename arm_exc_interrupt() | Sebastian Huber | 2013-01-07 | 11 | -12/+12 |
| | | | | Rename arm_exc_interrupt() to _ARMV4_Exception_interrupt(). | ||||
* | arm: Move prototypes to new file | Sebastian Huber | 2013-01-07 | 12 | -4/+56 |
| | | | | | | Move bsp_interrupt_dispatch() and arm_exc_interrupt() prototypes to new file <rtems/score/armv4.h> since they have nothing to do with the CPU port. | ||||
* | arm: Delete unused arm_exc_undefined() | Sebastian Huber | 2013-01-07 | 1 | -2/+0 |
* | score: Fix _Objects_Shrink_information() | Sebastian Huber | 2013-01-07 | 1 | -20/+16 |
| | | | | The chain iteration was wrong. The chain tail is not an object. | ||||
* | bsps: Fix rtems_interrupt_server_handler_remove() | Sebastian Huber | 2013-01-07 | 1 | -2/+2 |
* | tmoverhd.doc | Cynthia Rempel | 2013-01-06 | 1 | -0/+75 |
| | | | | | Hi, Adding test documentation... | ||||
* | libmisc: Doxygen Clean Up Task #1 | Ayush Awasthi | 2013-01-04 | 12 | -307/+360 |
| | | | | | Conflicts occured durning this patch and modifications in the repo were favored over the patch. | ||||
* | posix: Doxygen Clean Up Task #2 | Alex Ivanov | 2013-01-04 | 14 | -138/+201 |
* | rtems: Doxygen Clean Up Task #1 | Ayush Awasthi | 2013-01-04 | 20 | -819/+887 |
* | rtems: Doxygen Clean Up Task #2 | Ayush Awasthi | 2013-01-04 | 20 | -652/+726 |
* | score: Doxygen Clean Up Task #10 | Mathew Kallada | 2013-01-04 | 20 | -801/+1046 |
* | score: Doxygen Clean Up Task #3 | Mathew Kallada | 2013-01-04 | 20 | -230/+349 |
* | score: Doxygen Clean Up Task #9 | Alex Ivanov | 2013-01-04 | 20 | -1001/+1773 |
* | libfs: Doxygen Clean Up Task #2 | Mathew Kallada | 2013-01-04 | 9 | -94/+195 |
| | | | | | | There were minor conflicts and the modifications that were in the repo were favored over the modifications in the submitted patch. | ||||
* | IMFS: Generating .scn (Screen Shots) #2 | Christopher Kerl | 2013-01-02 | 6 | -0/+276 |
* | score: Doxygen Clean Up Task #5 | Alex Ivanov | 2013-01-02 | 19 | -1348/+1448 |
* | sptests/spintrcritical16: Fix NULL pointer access | Sebastian Huber | 2013-01-02 | 1 | -1/+4 |
* | score: Add const qualifier | Sebastian Huber | 2013-01-02 | 3 | -12/+12 |
