* aclocal/enable-itron.m4, aclocal/check-itron.m4:
Allow building itron for unix.
* include/buffer_test_io.h: Use iprintf iff _NEWLIB_VERSION is
defined.
* libnetworking/Makefile.am: Don't install bpfilter.h (Private
header).
* configure.ac: Remove -ansi to prevent folks from further damaging
the code with broken prototypes.
* putenvtest/init.c: Remove broken putenv prototype.
* termios/init.c (print_c_cc): Don't loop over NCCS.
* aclocal/enable-itron.m4: Remove (unused).
* aclocal/enable-itron.m4: New (moved from ../aclocal).
PR 721/tests
* itronsem01/init.c: Fix bogus assert.
* configure.ac: Misc. quoting cleanups.
Enable ada-tests iff --enable-ada and --enable-tests.
* libblock/include/rtems/bdbuf.h,
libblock/include/rtems/blkdev.h,
libblock/include/rtems/diskdevs.h,
libblock/include/rtems/ide_part_table.h,
libblock/include/rtems/ramdisk.h:
Add doxygen preamble.
* rtems/score/types.h: Use __rtems_score_types_h as preprocessor
guard.
* asm.h: Add doxygen preamble.
* sapi/include/confdefs.h, sapi/include/rtems/config.h,
sapi/include/rtems/extension.h, sapi/include/rtems/fatal.h,
sapi/include/rtems/init.h, sapi/include/rtems/io.h,
sapi/include/rtems/sptables.h, sapi/inline/rtems/extension.inl,
sapi/macros/rtems/extension.inl: Add doxygen preamble.
* score/include/rtems/debug.h, score/include/rtems/seterr.h,
score/include/rtems/system.h, score/include/rtems/score/address.h,
score/include/rtems/score/apiext.h,
score/include/rtems/score/apimutex.h,
score/include/rtems/score/bitfield.h,
score/include/rtems/score/chain.h,
score/include/rtems/score/context.h,
score/include/rtems/score/copyrt.h,
score/include/rtems/score/coresem.h,
score/include/rtems/score/heap.h,
score/include/rtems/score/interr.h, score/include/rtems/score/isr.h,
score/include/rtems/score/mpci.h, score/include/rtems/score/mppkt.h,
score/include/rtems/score/objectmp.h,
score/include/rtems/score/stack.h,
score/include/rtems/score/states.h,
score/include/rtems/score/sysstate.h,
score/include/rtems/score/threadmp.h,
score/include/rtems/score/threadq.h,
score/include/rtems/score/tod.h, score/include/rtems/score/tqdata.h,
score/include/rtems/score/userext.h,
score/include/rtems/score/watchdog.h,
score/include/rtems/score/wkspace.h,
score/inline/rtems/score/address.inl,
score/inline/rtems/score/chain.inl,
score/inline/rtems/score/coremsg.inl,
score/inline/rtems/score/coremutex.inl,
score/inline/rtems/score/coresem.inl,
score/inline/rtems/score/heap.inl, score/inline/rtems/score/isr.inl,
score/inline/rtems/score/mppkt.inl,
score/inline/rtems/score/object.inl,
score/inline/rtems/score/objectmp.inl,
score/inline/rtems/score/priority.inl,
score/inline/rtems/score/stack.inl,
score/inline/rtems/score/states.inl,
score/inline/rtems/score/sysstate.inl,
score/inline/rtems/score/thread.inl,
score/inline/rtems/score/threadmp.inl,
score/inline/rtems/score/tod.inl,
score/inline/rtems/score/tqdata.inl,
score/inline/rtems/score/userext.inl,
score/inline/rtems/score/watchdog.inl,
score/inline/rtems/score/wkspace.inl,
score/macros/rtems/score/object.inl: Adjust doxygen @file.
* posix/include/aio.h, posix/include/devctl.h, posix/include/intr.h,
posix/include/mqueue.h, posix/include/sched.h,
posix/include/semaphore.h, posix/include/rtems/posix/cancel.h,
posix/include/rtems/posix/cond.h,
posix/include/rtems/posix/condmp.h,
posix/include/rtems/posix/config.h,
posix/include/rtems/posix/intr.h, posix/include/rtems/posix/key.h,
posix/include/rtems/posix/mqueue.h,
posix/include/rtems/posix/mqueuemp.h,
posix/include/rtems/posix/mutex.h,
posix/include/rtems/posix/mutexmp.h,
posix/include/rtems/posix/posixapi.h,
posix/include/rtems/posix/pthreadmp.h,
posix/include/rtems/posix/ptimer.h,
posix/include/rtems/posix/semaphoremp.h,
posix/inline/rtems/posix/intr.inl, posix/inline/rtems/posix/key.inl,
posix/inline/rtems/posix/timer.inl,
posix/macros/rtems/posix/cond.inl,
posix/macros/rtems/posix/intr.inl, posix/macros/rtems/posix/key.inl,
posix/macros/rtems/posix/mqueue.inl,
posix/macros/rtems/posix/mutex.inl,
posix/macros/rtems/posix/priority.inl,
posix/macros/rtems/posix/pthread.inl,
posix/macros/rtems/posix/semaphore.inl,
posix/macros/rtems/posix/timer.inl: Add doxygen preamble.
* itron/include/itron.h, itron/include/itronsys/eventflags.h,
itron/include/itronsys/fmempool.h, itron/include/itronsys/intr.h,
itron/include/itronsys/mbox.h, itron/include/itronsys/msgbuffer.h,
itron/include/itronsys/network.h, itron/include/itronsys/port.h,
itron/include/itronsys/semaphore.h, itron/include/itronsys/status.h,
itron/include/itronsys/sysmgmt.h, itron/include/itronsys/task.h,
itron/include/itronsys/time.h, itron/include/itronsys/types.h,
itron/include/itronsys/vmempool.h,
itron/include/rtems/itron/config.h,
itron/include/rtems/itron/eventflags.h,
itron/include/rtems/itron/fmempool.h,
itron/include/rtems/itron/intr.h,
itron/include/rtems/itron/itronapi.h,
itron/include/rtems/itron/mbox.h,
itron/include/rtems/itron/msgbuffer.h,
itron/include/rtems/itron/network.h,
itron/include/rtems/itron/object.h,
itron/include/rtems/itron/port.h,
itron/include/rtems/itron/semaphore.h,
itron/include/rtems/itron/sysmgmt.h,
itron/include/rtems/itron/task.h, itron/include/rtems/itron/time.h,
itron/include/rtems/itron/vmempool.h,
itron/inline/rtems/itron/eventflags.inl,
itron/inline/rtems/itron/fmempool.inl,
itron/inline/rtems/itron/intr.inl,
itron/inline/rtems/itron/mbox.inl,
itron/inline/rtems/itron/msgbuffer.inl,
itron/inline/rtems/itron/network.inl,
itron/inline/rtems/itron/port.inl,
itron/inline/rtems/itron/semaphore.inl,
itron/inline/rtems/itron/sysmgmt.inl,
itron/inline/rtems/itron/task.inl,
itron/inline/rtems/itron/time.inl,
itron/inline/rtems/itron/vmempool.inl,
itron/macros/rtems/itron/eventflags.inl,
itron/macros/rtems/itron/fmempool.inl,
itron/macros/rtems/itron/intr.inl,
itron/macros/rtems/itron/mbox.inl,
itron/macros/rtems/itron/msgbuffer.inl,
itron/macros/rtems/itron/network.inl,
itron/macros/rtems/itron/port.inl,
itron/macros/rtems/itron/semaphore.inl,
itron/macros/rtems/itron/sysmgmt.inl,
itron/macros/rtems/itron/task.inl,
itron/macros/rtems/itron/time.inl,
itron/macros/rtems/itron/vmempool.inl: Add doxygen preamble.
* librpc/include/rpc/types.h: Include <rtems/stdint.h>.
* librpc/src/rpc/clnt_raw.c, librpc/src/rpc/rpcdname.c,
librpc/src/rpc/rtems_portmapper.c, librpc/src/rpc/svc.c,
librpc/src/rpc/svc_simple.c: Misc. cast-related fixes.
Convert to ANSI.
* librpc/include/rpc/rpc.h (struct _rtems_rpc_task_variables):
Use pointers to types instead of void* to avoid casts.
* librpc/src/rpc/clnt_perror.c, librpc/src/rpc/clnt_raw.c,
librpc/src/rpc/clnt_simple.c, librpc/src/rpc/rpcdname.c,
librpc/src/rpc/svc.c, librpc/src/rpc/svc_auth.c,
Eliminate lvalue casts gcc-3.4 warns about.
* powerpc/shared/include/cpuIdent.c,
powerpc/shared/include/cpuIdent.h: Add 603le.
(Submitted by Thomas.Doerfler <Thomas.Doerfler@imd-systems.de>
as part of the patch attached to PR 703).
PR 703/filesystem
* ide/pcmcia_ide.c: Extend the "modes_available" and "mode_active" parameters
to uint16_t for UDMA support.
PR 703/filesystem
* ide/ide.c: Extend the "modes_available" and "mode_active" parameters
PR 703/filesystem
* shared/ide_ctrl.c: Extend the "modes_available" and "mode_active"
parameters to uint16_t for UDMA support.
PR 703/filesystem
* libchip/ide/ata_internal.h, libchip/ide/ide_ctrl_cfg.h,
libchip/ide/ide_ctrl_io.h, libchip/ide/ata.c,
libchip/ide/ide_controller.c:
Move definitions for ATA modes into ide_ctrl_cfg.h, to make them
available for BSPS/device drivers.
Extend the "modes_available" and "mode_active" parameters to
* libfs/src/dosfs/dosfs.h: Add doxygen preamble.
* libfs/src/dosfs/msdos.h: Remove RC_OK.
* libfs/src/dosfs/msdos_format.c: Remove unnecessary casts.
PR 720/filesystem:
* libfs/src/dosfs/dosfs.h, libfs/src/dosfs/fat.c,
libfs/src/dosfs/fat.h, libfs/src/dosfs/msdos_format.c:
Adaptations to msdos_format.
(From Thomas Doerfler <Thomas.Doerfler@imd-systems.de>).
Adaptations to RTEMS-4.7.
PR 720/filesystem:
* libfs/src/dosfs/msdos_format.c: New
* libfs/Makefile.am: Reflect changes above:
* libcsupport/include/stdint.h: Move mal-placed comment.
* startup/m68k-stub.c: Use (defined(__mc68020__) && !defined(__mcpu32__))
instead of defined(__mc68020__) to reflect GCC-3.4's expectations.
* shared/cache/cache.c, shared/cache/cache_.h:
* rtems/score/m68k.h: Use (defined(__mc68020__) && !defined(__mcpu32__))
* custom/mvme2100.cfg: Add make-cxx-exe rule.
* startup/linkcmds: Add sections required by gcc 3.3.x so it will link.
* vmeUniverse/vmeUniverse.c: Use PCI_MEM_BASE_ADJUSTMENT because some
boards -- notably the MVME2100 -- return the physical address, not an
offset in PCI memory space.
* README.MVME2100: Update to include DBAT0.
* startup/linkcmds: Add sections from new gcc versions.
* aclocal/check-bsps.m4: Use ls instead of globs to pickup
bsp_specs.
PR 717/bsps
* bootloader/Makefile.am: Set up BOOTLOADER_CPU_CFLAGS.
* aclocal/check-bsps.m4: Add MVME2100 BSP as alias of
motorola_shared.
* include/rtems/pci.h: BSPs use the name BSP_pci_configuration not pci.
Also need to address that this largely duplicates
libbsp/powerpc/pci/pci.h but that file is not used when both are
included due to the same double inclusion protection.
* libchip/network/dec21140.c: Cleanup a bit and remove message about
not supported on PowerPC since it works on the MVME2100 BSP.
* configure.ac, mpc6xx/exceptions/raw_exception.c,
mpc6xx/exceptions/raw_exception.h, mpc6xx/mmu/bat.c,
mpc6xx/mmu/bat.h, mpc6xx/mmu/mmuAsm.S, shared/include/cpuIdent.c,
shared/include/cpuIdent.h: Add MPC8240 and MPC8245 support. There was
also a significant amount of spelling and whitespace cleanup.
* Makefile.am, bootloader/misc.c, bootloader/pci.c, bootloader/pci.h,
console/console.c, console/inch.c, console/reboot.c, console/uart.c,
console/uart.h, irq/irq.c, irq/irq.h, irq/irq_init.c,
motorola/motorola.c, motorola/motorola.h, openpic/openpic.c,
openpic/openpic.h, pci/detect_raven_bridge.c, pci/pci.c,
start/start.S, startup/bspstart.c, vectors/vectors_init.c,
vme/vmeconfig.c: Add MVME2100 BSP and MPC8240 support. There was also
* tod/todcfg.c: New file.
* Makefile.am, configure.ac, bootloader/Makefile.am, include/bsp.h,
wrapup/Makefile.am: Add MVME2100 BSP and MPC8240 support. There was
* README.MVME2100: New file.
