* | Added information on hardware to aid in debugging. Primarily this is | Joel Sherrill | 1999-07-15 | 5 | -4/+95 |
| | | | | information on gdb and bdm for the MPC8xx, MC683xx, and ColdFire. | ||||
* | New file. | Joel Sherrill | 1999-07-14 | 1 | -0/+19 |
* | Added comment on where this manager came from. | Joel Sherrill | 1999-07-13 | 1 | -1/+2 |
* | Update from Jeff Mayes, Jennifer Averett, and Suzie Provitt. | Joel Sherrill | 1999-07-13 | 1 | -17/+160 |
* | Update including fixes for my comments from Xiangyang Wu <wux@cspar.uah.edu> | Joel Sherrill | 1999-07-13 | 1 | -734/+858 |
| | | | | and xing@ebs330.eb.uah.edu. | ||||
* | Added section on Free Software that Supports RTEMS. | Joel Sherrill | 1999-07-13 | 3 | -1/+79 |
* | Patch from Rosimildo DaSilva <rdasilva@connecttel.com> to readd calls to | Joel Sherrill | 1999-07-13 | 1 | -0/+10 |
| | | | | init() and fini() routines. | ||||
* | Patch from Eric Norum <eric@cls.usask.ca>: | Joel Sherrill | 1999-07-12 | 4 | -80/+60 |
| | | | | | | | | | | | | | | I get the following warning when compiling the latest snapshot. I had a quick look at the source -- it certainly looks to me like this is a real bug. ../../../../src/rtems-19990709/c/src/lib/libc/mount.c:97: warning: `options' might be used uninitialized in this function Also, I changed the TFTP test program and TFTP driver to reflect the changes in the way paths are passed to the TFTP driver. The TFTP driver now needs a proper `dotted-decimal' hostname as the second component of the path name. | ||||
* | changed version to 19990709 | Joel Sherrill | 1999-07-09 | 1 | -1/+1 |
* | Updated version | Joel Sherrill | 1999-07-09 | 3 | -11/+11 |
* | Added information on the workspace versus heap. | Joel Sherrill | 1999-07-09 | 1 | -0/+5 |
* | changed version to 19990709 | Joel Sherrill | 1999-07-09 | 2 | -2/+2 |
* | New files from Jiri Gaisler <jgais@ws.estec.esa.nl>. | Joel Sherrill | 1999-07-09 | 3 | -0/+153 |
* | New file from Jake Janovetz <janovetz@tempest.ece.uiuc.edu>. | Joel Sherrill | 1999-07-09 | 3 | -0/+78 |
* | Patch from Eric Valette <valette@crf.canon.fr>: | Joel Sherrill | 1999-07-09 | 30 | -226/+108 |
| | | | | | | | | | | | | | | | - The same bug fix that was done on pc386 to prevent interrupt from occuring (never experienced it but who knows as I have 8259 emulation :() - Removed every compiler warning (except wrong ones and ones I can't do anything). - Removed any libc available code in code linked with mcp750 rtems executbale. Unfortunately using newlib functions for linking the bootloader does not work as the compilation options in bootloader (-mrelocatable -fixed-r13) are not compatible with newlib options. => I have put any libc external reference in one single new file (lib.c) that is linked only with the boot loader. Removing the file from ${OBJ} and using -lc crash the bootloader. Added big warning... | ||||
* | Patch from Jiri Gaisler <jgais@ws.estec.esa.nl>: | Joel Sherrill | 1999-07-09 | 19 | -66/+285 |
| | | | | | | + interrupt masking correction + FPU rev.B workaround + minor erc32 related fixes | ||||
* | Make sure pthread init stack size is always set. | Joel Sherrill | 1999-07-09 | 2 | -0/+10 |
* | Moved definitions to a more logical place. | Joel Sherrill | 1999-07-08 | 2 | -8/+8 |
* | Some cleanup to make it format better. Compensated for multiple services | Joel Sherrill | 1999-07-08 | 1 | -31/+142 |
| | | | | on a single page. | ||||
* | First draft from Xiangyang Wu <wux@cspar.uah.edu>. | Joel Sherrill | 1999-07-08 | 1 | -12/+351 |
* | From Fei Ling <fling@cs.uah.edu>. | Joel Sherrill | 1999-07-06 | 1 | -19/+524 |
* | Added a lot of information on confdefs.t | Joel Sherrill | 1999-07-03 | 1 | -16/+367 |
* | Added documentation on "two new SOL_SOCKET level options for setsockopt and | Joel Sherrill | 1999-07-03 | 2 | -4/+68 |
| | | | | | getsockopt: SO_SNDWAKEUP and SO_RCVWAKEUP" from Ian Lance Taylor <ian@airs.com>. | ||||
* | Removed concept of distribution level. | Joel Sherrill | 1999-07-03 | 27 | -35/+10 |
* | Changed System Database routines to implemented. | Joel Sherrill | 1999-07-03 | 1 | -10/+10 |
* | New file. | Joel Sherrill | 1999-07-03 | 1 | -0/+56 |
* | New files missed in previous addition. | Joel Sherrill | 1999-07-03 | 4 | -0/+1896 |
* | Added some C++/GNU sections. | Joel Sherrill | 1999-07-03 | 1 | -1/+8 |
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> that splits | Joel Sherrill | 1999-07-02 | 36 | -121/+131 |
| | | | | | | boot_card() and main() into separate files to ease configuration of other packages. This was a big step in the way to build TCL, ncurses, and zlib for RTEMS. | ||||
* | Added code to initialize the /etc/group and /etc/passwd files. | Joel Sherrill | 1999-07-02 | 6 | -0/+273 |
* | Fixed format strings and warnings. | Joel Sherrill | 1999-07-02 | 6 | -27/+27 |
* | Reentrant versions added by Joel. Signficant formatting cleanup. | Joel Sherrill | 1999-07-02 | 7 | -346/+529 |
* | Password and group routines added by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 1999-07-02 | 7 | -1/+749 |
* | Patch from Eric Valette <valette@crf.canon.fr> to clean up the | Joel Sherrill | 1999-07-01 | 77 | -709/+751 |
| | | | | previous submission. | ||||
* | Added error status for bad return pointer argument on rtems_task_set_priority. | Joel Sherrill | 1999-07-01 | 1 | -0/+1 |
* | Corrected formatting so argument was in code font. | Joel Sherrill | 1999-07-01 | 1 | -1/+1 |
* | Fixed reference to initialize_executive to use the current name. | Joel Sherrill | 1999-07-01 | 1 | -1/+2 |
* | Filled in. | Joel Sherrill | 1999-07-01 | 1 | -10/+30 |
* | Cleaned up and much neater. | Joel Sherrill | 1999-07-01 | 1 | -19/+33 |
* | Honor 0 as PID of caller. | Joel Sherrill | 1999-07-01 | 2 | -2/+2 |
* | Another attempt at getting everything to build with the new powerpc | Joel Sherrill | 1999-07-01 | 1 | -1/+1 |
| | | | | libcpu. | ||||
* | Fixed typo. | Joel Sherrill | 1999-07-01 | 1 | -2/+2 |
* | Added signal_2 file to contain signal(2). | Joel Sherrill | 1999-07-01 | 1 | -1/+1 |
* | New file to implement signal(2). | Joel Sherrill | 1999-07-01 | 2 | -0/+100 |
* | Modified to reflect change in calling sequence of mount(). | Joel Sherrill | 1999-07-01 | 2 | -2/+2 |
* | Test modified to reflect change in calling sequence of mount(). | Joel Sherrill | 1999-07-01 | 2 | -20/+20 |
* | Cleaned up to behave properly -- does not make a directory in the | Joel Sherrill | 1999-07-01 | 1 | -2/+1 |
| | | | | install tree and does not "cd wrapup." | ||||
* | Now preinstalls header files. | Joel Sherrill | 1999-07-01 | 1 | -4/+8 |
* | Removed mkdir of libcpu. This should have been at the top of the tree. | Joel Sherrill | 1999-07-01 | 1 | -1/+0 |
* | Remove mkdir command. It should be at the top level of the tree. | Joel Sherrill | 1999-07-01 | 1 | -1/+0 |
