Close #4140.
- Do not start threads detached
updates #4028.
Improve file header comment.
Update #3994.
Update #3993.
The old network stack is not supported on 64-bit targets.
Update #4105.
Update #3818.
Close #4116.
This adds an AArch64 ILP32 BSP variant based on Qemu's Cortex-A53
emulation with interrupt support using GICv3 and clock support using
the ARM GPT.
This adds an AArch64 basic BSP based on Qemu's Cortex-A53 emulation with
interrupt support using GICv3 and clock support using the ARM GPT.
This adds a CPU port for AArch64(ARMv8) with support for exceptions and
interrupts.
Fix spmsgq_err01 on systems with 64-bit pointers and correct max value
mismatches and inaccuracies that are more noticable on 64-bit systems.
This adds a bsp_reset implementation based on the ARM PSCI
specification often present in ARMv8 systems.
This breaks out AArch32-specific code so that the shared GICv3 code can
be reused by other architectures.
This breaks AArch32-specific portions of the ARM GPT driver into their
own file so that the generic code can be moved for reuse by other
architectures.
This UART driver is now needed for BSPs other than ARM.
Close #4121.
Due to the static allocation of operating system resources the .bss section
needs more space than the .work section.
Close #4117.
Close #4120.
Update #3818.
Enable it only for selected BSPs. Improve description.
Before this patch RTEMS_Malloc_Initialize() had a fixed dependency on
_Workspace_Area. Introduce _Workspace_Malloc_initializer to have this
dependency only if CONFIGURE_UNIFIED_WORK_AREAS is defined by the
application configuration.
Check the name followed by the id check in all create directives.
Compare pointers against NULL. Fix formatting.
Add the build option RTEMS_TEST_VERBOSITY to control the verbosity of
test suites using the RTEMS Test Framework.
Close #4107.
The Autoconf/Automake build system did something similar. This fixes
the build of sigprogmask.c which uses RTEMS_POSIX_API and expects to get
it defined via "config.h".
Update #3818.
The implementation was added and removed in 2009.
Closes #4099.
This patch fixes a tiny bug in the command line editing of the RTEMS shell.
Typing CTRL-U in the shell should remove all characters left of the cursor.
After pressing CTRL-U, the current implementation does wrongly place the cursor
at the end of the line instead at its beginning.
To reproduce the bug, start the shell and type 'abc123' (no <RETURN>):
> ~/src/rtems $ qemu-system-arm -net none -nographic -M realview-pbx-a9 \
-m 256M -kernel build/arm/realview_pbx_a9_qemu/testsuites/libtests/dl10.exe
> *** BEGIN OF TEST libdl (RTL) 10 ***
> *** TEST VERSION: 6.0.0.d9bdf166644f612dd628fe4951c12c6f8e94ba5f
> *** TEST STATE: USER_INPUT
> *** TEST BUILD: RTEMS_DEBUG RTEMS_NETWORKING RTEMS_POSIX_API RTEMS_SMP
> *** TEST TOOLS: 10.2.1 20200904 \
(RTEMS 6, RSB 31f936a7b74d60bda609a9960c6e1a705ba54974, Newlib a0d7982)
> RTL (libdl) commands: dl, rtl
> RTEMS Shell on /dev/foobar. Use 'help' to list commands.
> SHLL [/] # abc123
Then move the cursor onto the '1' by hitting three times the <ARROW-LEFT> key.
Next type <CTRL>-U:
> SHLL [/] # 123
Note that the cursor is at the end of the line (after '3') instead of correctly
at the beginning (on the '1'), now.
Continuing typing 'echo ' incorrectly results in the output:
> SHLL [/] # 123echo 123
The patch changes this behavior so that the cursor in the second last step will
be on the '1' and typing 'echo ' will then correctly reflected as:
> SHLL [/] # echo 123
Close #4097.
Update #4007.
In contrast to message queues created by rtems_message_queue_create(), the
message queues constructed by this directive use a user-provided message buffer
storage area.
Add RTEMS_MESSAGE_QUEUE_BUFFER() to define a message buffer type for message
buffer storage areas.
Update #4007.
Add Message_queue_Control::is_global if RTEMS_MULTIPROCESSING is defined. This
reduces the Message_queue_Control size in standard RTEMS configurations.
Update #4007.
Move the CORE_message_queue_Buffer definition to a separate header file to be
able to use it independent of the remaining Message Queue Handler API.
Change license to BSD-2-Clause according to file history.
Update #3053.
Update #4007.
Merge CORE_message_queue_Buffer structure into
CORE_message_queue_Buffer_control.
Use a zero-length array for the actual message buffer. This reduces the
structure size on all targets.
Update #4007.
Return a status code and differentiate between error conditions.
Update #4007.
Initialize the structure in a single code block after the error checks and
calculations.
Update #4007.
The previous multiplication error check is broken on 64-bit machines. Use the
recommended check from SEI CERT C Coding Standard, "INT30-C. Ensure that
unsigned integer operations do not wrap".
Make sure the message size computation does not overflow.
Update #4007.
