* libmisc/shell/login_prompt.c, libmisc/shell/shell_script.c,
rtems/include/rtems/rtems/timer.h: Fix warnings.
* support/src/tmtests_empty_function.c: Fix warnings.
* sp04/system.h, sp04/task1.c, sp04/tswitch.c, sp07/init.c,
sp12/init.c, sp13/putbuff.c, sp13/system.h, sp13/task1.c,
sp15/init.c, sp16/system.h, sp19/fptask.c, sp25/system.h,
sp26/task1.c, sp27/init.c, sp28/init.c, sp29/init.c, sp31/task1.c,
sp33/init.c, sp34/changepri.c, sp35/priinv.c, sp37/init.c,
sp38/init.c, sp39/init.c, sp41/init.c, sp42/init.c, sp43/init.c,
sp44/init.c, sp45/init.c, sp46/init.c, sp47/init.c, sp48/init.c,
spfatal03/testcase.h, spfatal05/testcase.h, spfatal06/testcase.h,
spfatal_support/system.h, spobjgetnext/init.c, spsize/getint.c,
spsize/size.c: Fix warnings.
* malloctest/init.c: Fix warning.
* include/bsp.h: Defined as a small memory target. It cannot build
one of the sample programs any more.
* irq/BSP_irq.c: New file.
* irq/irq.c, network/if_1GHz/POSSIBLEBUG: Removed.
* include/bsp.h, start/start.S, startup/bspstart.c:
added CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK in bsp.h.
removed BSP_INIT_STACK_SIZE in bsp.h -- it uses __stack defined
by the linker script (shared/startup/linkcmds) for the initial
stack.
replaced __rtems_end+4096 with __stack in start.S
Removed legacy code in bspstart.c (inherited from old mvme2307 BSP
but not relevant to this one) that tested trapping
into PPCBug.
Changed ConfVPD_buff[] to be static and added ReadConfVPD_buf() in
bspstart.c
* posix/include/rtems/posix/psignal.h,
rtems/inline/rtems/rtems/support.inl: Remove warnings.
* user/conf.t: Change work_space_size to uintptr_t since it cannot be
negative.
* sapi/include/rtems/config.h: Switch from ssize_t to uintptr_t for
work space size since it is larger than a single allocatable object.
* bootcard.c, bspgetworkarea.c, include/bootcard.h: Switch from ssize_t
to uintptr_t for bsp_get_work_area() since the work area is larger
* startup/bspgetworkarea.c: Switch from ssize_t to uintptr_t for
bsp_get_work_area() since the work area is larger than a single
allocatable object.
* shared/bspgetworkarea.c: Switch from ssize_t to uintptr_t for
allocatable object.
* shared/startup/bspgetworkarea.c: Switch from ssize_t to uintptr_t for
allocatable object.
* startup/linkcmds: Correct to have 65K total RAM (mostly external) and
correct base address.
* cpukit/libblock/src/bdpart.c, libmisc/shell/main_msdosfmt.c,
libmisc/shell/main_rm.c, libnetworking/libc/gethostnamadr.c,
score/include/rtems/score/bitfield.h,
score/inline/rtems/score/priority.inl: Remove warnings.
* score/src/objectgetnext.c: Add checks for NULL pointers.
* Makefile.am, configure.ac: Add initial test of _Objects_Get_next.
* spobjgetnext/.cvsignore, spobjgetnext/Makefile.am,
spobjgetnext/init.c, spobjgetnext/spobjgetnext.scn,
spobjgetnext/system.h: New files.
* malloctest/init.c: Fix typo.
* Makefile.am, configure.ac: Add shell of heap walk test for Santosh.
* heapwalk/.cvsignore, heapwalk/Makefile.am, heapwalk/heapwalk.scn,
heapwalk/init.c, heapwalk/system.h: New files.
* malloctest/init.c: Add test case for heap resize block when the
resize creates a free block large enough to free.
timeouts. Options are now per file system instance.
* bspinit.c: Fix warning by adding include file.
* libchip/network/if_dc.c: Fixed warnings.
* page.c: Fixed warnings.
* libmisc/uuid/gen_uuid.c, libnetworking/lib/syslog.c,
telnetd/telnetd.c: Fixed warnings.
* shared/comm/i386-stub-glue.c, shared/comm/uart.c, shared/irq/irq.c,
shared/pci/pcibios.c: Fixed warnings.
* console/console.c, console/inch.c, ide/ide.c: Fixed warnings.
* libcsupport/Makefile.am:
* libcsupport/src/isatty_r.c: New file.
PR 1409/bsps
* gdbstub/rtems-stub-glue.c: Print object names correctly.
* shared/start/start.S: Confirmed OK by mwalle.
* bootcard.c, gdbstub/rtems-stub-glue.c: Add info to not enough memory
message.
* rtems/include/rtems/rtems/part.h,
rtems/inline/rtems/rtems/region.inl: Fix warnings.
* rtems/score/cpu.h: Lower number of priorities and do not inline as
much.
* score/include/rtems/score/heap.h,
score/inline/rtems/score/address.inl,
score/inline/rtems/score/heap.inl,
score/inline/rtems/score/object.inl,
score/inline/rtems/score/priority.inl,
score/inline/rtems/score/tod.inl: Remove warnings.
* rtems/score/cpu.h: Remove warnings.
* shared/pci/pci.c: Removed warnings.
