* | Updated to reference the standards. | Joel Sherrill | 1998-09-28 | 1 | -5/+18 |
* | Documented the mount and umount routines. | Wade A Smith | 1998-09-28 | 1 | -5/+233 |
* | Documented the ftruncate and opendir routines. Removed reference to the | Wade A Smith | 1998-09-28 | 1 | -121/+197 |
| | | | | readdir_r routine. | ||||
* | New files. | Joel Sherrill | 1998-09-27 | 5 | -1/+69 |
* | Documented the following routines: dup, dup2, close, read, write, and fcntl.f | Wade A Smith | 1998-09-27 | 1 | -49/+168 |
* | Documented the following routines in this file: rewinddir, pathconf, | Wade A Smith | 1998-09-26 | 1 | -47/+274 |
| | | | | fpathconf, fchmod, fstat, mkfifo, and telldir | ||||
* | Documented the creat, scandir, and access routines. | Wade A Smith | 1998-09-25 | 1 | -22/+120 |
* | Docmumented the access routine in for this file. | Wade A Smith | 1998-09-25 | 1 | -6/+31 |
* | Fixed typos so this would build. | Joel Sherrill | 1998-09-25 | 1 | -2/+2 |
* | Now compiles. | Joel Sherrill | 1998-09-25 | 5 | -1/+9 |
* | Added information on every service in this chapter. Most of them are | Joel Sherrill | 1998-09-25 | 1 | -51/+123 |
| | | | | ENOSYS stubs at this time. | ||||
* | Added ENOSYS stubs for a number of process routines. | Joel Sherrill | 1998-09-25 | 16 | -0/+264 |
* | Stuff added by Kerwin. | Joel Sherrill | 1998-09-25 | 1 | -64/+525 |
* | Improved missing directory message. | Joel Sherrill | 1998-09-24 | 2 | -2/+8 |
* | Removed blank line. | Joel Sherrill | 1998-09-24 | 1 | -1/+0 |
* | Removed superfluous initialization of PC video. | Joel Sherrill | 1998-09-24 | 1 | -3/+4 |
* | Patch from Erik Ivanenko <erik.ivanenko@utoronto.ca>: | Joel Sherrill | 1998-09-24 | 2 | -33/+7 |
| | | | | | | | | | | | | | | | | Please find attached a start.s that includes a cli prior to the hlt instruction. This ensures that external interrupts cannot restart the system after returning to the startup code. ( According to the hlt docs, they will! ) Also find a new timer.c. ( I forgot to update the countdowm value in the timer when I changed the PSCLK frequency in start.s) . This improves timer accuracy. The raw_idt_notify messages are no longer infinite, I tested sp11 and sp05, both which were bad, and I have seen the message print once in one test. I think it's ok if it prints out once. In fact, I don't think you can effectively stop it! | ||||
* | New version from Erik Ivanenko <erik.ivanenko@utoronto.ca>. | Joel Sherrill | 1998-09-24 | 1 | -1/+23 |
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 1998-09-23 | 4 | -4/+4 |
* | IDLE task stack size now specified as a field in the CPU Table for all | Joel Sherrill | 1998-09-23 | 17 | -30/+26 |
| | | | | ports. | ||||
* | Modifed to zero out the C heap if the CPU Table indicates that the | Joel Sherrill | 1998-09-23 | 3 | -0/+45 |
| | | | | RTEMS workspace is to be zeroed out. | ||||
* | changed version to 980923 | Joel Sherrill | 1998-09-23 | 3 | -4/+3 |
* | Updated to remove bad comment. | Joel Sherrill | 1998-09-23 | 1 | -4/+1 |
* | Removed printk() references. | Joel Sherrill | 1998-09-23 | 1 | -4/+4 |
* | Patch from Erik Ivanenko <erik.ivanenko@utoronto.ca>: | Joel Sherrill | 1998-09-23 | 2 | -23/+40 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Please find attached the two files that have been changed relative to 980921 . The changes here are in the handling of the counter-timer used as the basis for the rtems executive clock. For the most part, these are housekeeping changes. The PSCLK frequency change in start.s... was a part of several bug-fixes. The fix improves executive clock and timer accuracy. changes : start.s -- All timers are disabled by the initialization routine -- PSCLK ( used by clock and timers ) frequency changed to 1MHz The clock_initialize routine now assumes that the PSCLK frequency is exactly 1 MHz. ckinit.c Clock_isr -- removed division by 1000. Now use 'static' variable -- clock_intial_isr_value -- to reset Clock_isrs variable. clock_initialize -- moved counter timer initialization here. Values used to configure the timer are totally dependent on BSP_configuration.microseconds_per_tick ( and the PSCLK assumption). Initializes clock_initial_isr_value used by th Clock_isr to reset Clock_isrs. clock_on -- no longer configures the timer, just enables it. Since altering the number of sections in the BSP, I decided to give it a good "once over" . The clock handling is now cleaner. | ||||
* | Patch from Aleksey (Quality Quorum <qqi@world.std.com>): | Joel Sherrill | 1998-09-23 | 16 | -86/+88 |
| | | | | | | | | | | | 1. Finally fixes raw interrupts for pc386 2. Makes some minor cleanup in console and startup 3. Makes rtems_termios_dequeue_characters() to return count of outstanding chars - it allows to simplify console isrs a little bit. 4. pc386 uart modified to be friendlier to termios parameter changes, to have minor performance improvement and to take advantage of of above termios modification. | ||||
* | Switched "NEW_GAS" flag. | Joel Sherrill | 1998-09-23 | 1 | -2/+0 |
* | Regenerated. | Joel Sherrill | 1998-09-23 | 1 | -2/+3 |
* | Updated file based upon red-lines received. | Wade A Smith | 1998-09-21 | 1 | -15/+11 |
* | Updated file based upon read_lines received. | Wade A Smith | 1998-09-21 | 1 | -1/+1 |
* | Updated file based upon red-lines received. | Wade A Smith | 1998-09-21 | 1 | -121/+110 |
* | changed version to 980921 | Joel Sherrill | 1998-09-21 | 3 | -3/+3 |
* | Modified sentences in the file to avoid using "shall" statements. | Wade A Smith | 1998-09-21 | 1 | -6/+6 |
* | Described the constants used by the admin_type in the background section | Wade A Smith | 1998-09-21 | 1 | -10/+14 |
| | | | | of this file. | ||||
* | Corrected ColdFire port information. | Joel Sherrill | 1998-09-21 | 1 | -2/+4 |
* | New file from Emmanuel Raguet <raguet@crf.canon.fr>. | Joel Sherrill | 1998-09-21 | 1 | -0/+64 |
* | Patch from Eric Norum <eric@skatter.usask.ca>: | Joel Sherrill | 1998-09-21 | 4 | -116/+404 |
| | | | | | | | Here's a patch to make the rtems_showroute routine a little more useful. For `host' route table entries the link-level address is now displayed. This is equivalent to the old `show arp table' information displayed by the KA9Q code. | ||||
* | Patch from Eric Norum and David Fiddes to put ColdFire support in | Joel Sherrill | 1998-09-21 | 5 | -40/+45 |
| | | | | the inet checksum routine. | ||||
* | Update from Aleksey (Quality Quorum <qqi@world.std.com>) to pick up some | Joel Sherrill | 1998-09-21 | 3 | -48/+138 |
| | | | | patches missing from 980911. | ||||
* | Removed by patch from Aleksey. | Joel Sherrill | 1998-09-21 | 1 | -1/+0 |
* | Patches from Aleksey which were not in 980911. | Joel Sherrill | 1998-09-21 | 1 | -1/+4 |
| | | | | | | I am sending you patch which was lost. As far as I remember there were minor patches on top of it, either by Eric Valette or by Eric Norum or by both. | ||||
* | Update from Eric Valette <valette@crf.canon.fr>: | Joel Sherrill | 1998-09-21 | 4 | -16/+16 |
| | | | | | | Here are patches that bring 980911 back to what I think is a correct version of raw IDT management as well as a correct initialisation of video console and rtems managed interrupts. | ||||
* | Update from Erik Ivanenko <erik.ivanenko@utoronto.ca> to bring the | Joel Sherrill | 1998-09-21 | 5 | -298/+138 |
| | | | | | | | i386ex bsp up to date. 1) A 'hlt' instruction is coded in case of a return from boot_card in start.s. | ||||
* | Patch from Eric Norum: | Joel Sherrill | 1998-09-21 | 4 | -22/+7 |
| | | | | | | | | I fixed the problems noted by Victor Vengerov. 1) Fix typo in cfsetispeed(). 2) In rtems_termios_open, ensure that args->iop->data1 is set before calling device-specific open routine. | ||||
* | Patch from Eric Valette <valette@crf.canon.fr>: | Joel Sherrill | 1998-09-20 | 1 | -1/+1 |
| | | | | | Compiled and booted without problem. However console was set on COM2. At least for 4.0 it should be video :-) | ||||
* | Remove many of the shall verbs and replaced them with present tense verbs | Wade A Smith | 1998-09-16 | 1 | -91/+86 |
* | Changes the name of readdir, umask, mkdir, chmod, chown to cfg_readdir, | Wade A Smith | 1998-09-13 | 1 | -22/+22 |
| | | | | cfg_umask, cfg_mkdir, cfg_chmod, cfg_chown respectively. | ||||
* | Documented the following routines added to the Configuration Space | Wade A Smith | 1998-09-12 | 1 | -1/+488 |
| | | | | Management: readdir, open, umask, link, mkdir, unlink, chmod, and chown., | ||||
* | Updates to tree to make it build with all desired changes and the conversion | Joel Sherrill | 1998-09-11 | 12 | -801/+848 |
| | | | | of the SONIC driver to the new FreeBSD stack instead of KA9Q. | ||||
* | Added documentation for the log_facilityisvalid routine and add thew | Wade A Smith | 1998-09-11 | 1 | -3/+67 |
| | | | | status code EINVAL to the log_seek routine. |
