* | Corrected comment. | Joel Sherrill | 1997-11-30 | 3 | -10/+1 |
* | Do not generate make/os at install point. | Joel Sherrill | 1997-11-30 | 1 | -2/+1 |
* | Serious cleanup to reduce the number of explicitly listed Makefiles, | Joel Sherrill | 1997-11-30 | 4 | -1411/+461 |
| | | | | | eliminated autoconf looking for commands which are unused, and reduce the number of Makefiles generated. | ||||
* | Removed warnings. | Joel Sherrill | 1997-11-29 | 6 | -3/+18 |
* | Added credit for host.cfg stuff from Ralf Corsepius (corsepiu@faw.uni-ulm.de). | Joel Sherrill | 1997-11-29 | 1 | -0/+4 |
* | Changes from Ralf Corsepius (corsepiu@faw.uni-ulm.de) to automatically | Joel Sherrill | 1997-11-29 | 4 | -547/+363 |
| | | | | generate the list of Makefiles in the configure script. | ||||
* | Patch from Chris Johns to filter out the trace bit on CPU models | Joel Sherrill | 1997-11-29 | 1 | -2/+5 |
| | | | | which have hardware support for a separate interrupt stack. | ||||
* | Removed warning. | Joel Sherrill | 1997-11-18 | 2 | -2/+2 |
* | New file. | Joel Sherrill | 1997-11-18 | 2 | -0/+90 |
* | Removed warning under linux port. | Joel Sherrill | 1997-11-18 | 3 | -0/+15 |
* | Removed warnings. | Joel Sherrill | 1997-11-18 | 2 | -1/+6 |
* | Added argument as required by new version of termios_open. | Joel Sherrill | 1997-11-18 | 1 | -2/+4 |
* | Fixed assignment to dereference ch. | Joel Sherrill | 1997-11-18 | 1 | -1/+1 |
* | Changed from DOS style CR/LF to Unix style. | Joel Sherrill | 1997-11-18 | 1 | -534/+534 |
* | Added CONFIGURE_MEMORY_USER_OVERHEAD constant per Chris Johns request. | Joel Sherrill | 1997-11-18 | 3 | -3/+18 |
* | Merged code from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to generate | Joel Sherrill | 1997-11-18 | 2 | -300/+1336 |
| | | | | the information in the make/os/XYZ.cfg files using autoconf. | ||||
* | Modified to rezongize CPU-rtemsXYZ rather than just CPU-rtems. | Joel Sherrill | 1997-11-18 | 1 | -9/+15 |
* | Submitted by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 1997-11-18 | 1 | -0/+41 |
* | interrupt driven change from Eric Norum | Joel Sherrill | 1997-11-15 | 8 | -261/+618 |
* | Fixed prototype | Joel Sherrill | 1997-11-10 | 4 | -4/+4 |
* | Set return code to avoid spurious errors. | Joel Sherrill | 1997-11-10 | 3 | -0/+3 |
* | Test document. | Joel Sherrill | 1997-10-31 | 1 | -0/+690 |
* | New test file. | Joel Sherrill | 1997-10-31 | 1 | -4/+4 |
* | Replaced the algorithm used to build the texinfo nodes and menus. This | Joel Sherrill | 1997-10-31 | 1 | -218/+236 |
| | | | | | | | | | was necessary to fix some bugs and to support the "@subsubsection", "@raise", and "@lower" commands. The major known bug was that single section chapters were not being processed correctly. Added the -c option so chapter names do not always have to included in the node names. | ||||
* | added katsutoshi Shibuya | Joel Sherrill | 1997-10-24 | 3 | -3/+24 |
* | Changed prototype of read routine. | Joel Sherrill | 1997-10-23 | 7 | -43/+22 |
* | Switched to new style for read support routine. | Joel Sherrill | 1997-10-23 | 1 | -10/+6 |
* | Added TOD driver from Katsutoshi Shibuya. | Joel Sherrill | 1997-10-23 | 6 | -3/+190 |
* | Removed GEN68360_INIT. | Joel Sherrill | 1997-10-23 | 1 | -8/+0 |
* | Update from Eric Norum. | Joel Sherrill | 1997-10-23 | 1 | -161/+153 |
* | Updated console driver to use new read routine conventions. | Joel Sherrill | 1997-10-23 | 1 | -6/+3 |
* | Added TOD code for MVME162 BSP from Katsutoshi Shibuya. | Joel Sherrill | 1997-10-23 | 2 | -6/+8 |
* | Added new test for termios style consoles from Eric Norum. | Joel Sherrill | 1997-10-23 | 4 | -1/+346 |
* | Added console_reserve_resources. | Joel Sherrill | 1997-10-23 | 2 | -6/+15 |
* | Overhauled console driver to use termios and to simultaneously support | Joel Sherrill | 1997-10-23 | 3 | -149/+170 |
| | | | | both ports. | ||||
* | Added prototype for console_reserve_resources. | Joel Sherrill | 1997-10-23 | 3 | -0/+12 |
* | Added termios test. | Joel Sherrill | 1997-10-23 | 2 | -8/+10 |
* | fixed comment | Joel Sherrill | 1997-10-23 | 3 | -6/+3 |
* | New termios.c from Eric Norum. | Joel Sherrill | 1997-10-23 | 7 | -1803/+1942 |
| | | | | Added new entry point to add in per physical port resource requirements. | ||||
* | Added test case for rtems_interrupt_catch checking that the pointer | Joel Sherrill | 1997-10-21 | 4 | -2/+22 |
| | | | | for the returned old_isr_handler was non-NULL. | ||||
* | Fixed a number of warnings regarding comparisons between signed and | Joel Sherrill | 1997-10-21 | 12 | -27/+27 |
| | | | | unsigned numbers. | ||||
* | Fixed endian problem in printing object names. | Joel Sherrill | 1997-10-21 | 3 | -0/+15 |
* | Converted to termios style device driver. | Joel Sherrill | 1997-10-21 | 1 | -265/+144 |
* | Added check that return argument pointer for old_isr_handler was valid. | Joel Sherrill | 1997-10-21 | 2 | -0/+6 |
* | Moved rtems directory up one directory in the install point. It was | Joel Sherrill | 1997-10-21 | 1 | -9/+9 |
| | | | | formerly under $(target) and is now at the same level. | ||||
* | Added termios submission from Eric Norum and Katsutoshi Shibuya. | Joel Sherrill | 1997-10-21 | 1 | -1/+4 |
* | Converted from using a message queue for the raw input queue to using a | Joel Sherrill | 1997-10-21 | 3 | -147/+105 |
| | | | | ring buffer in conjunction with a counting semaphore. | ||||
* | Added termios submission from Eric Norum and Katsutoshi Shibuya. | Joel Sherrill | 1997-10-21 | 4 | -1/+2281 |
* | Added termios submission from Eric Norum and Katsutoshi Shibuya. | Joel Sherrill | 1997-10-21 | 4 | -8/+88 |
* | Added casts and fixed line break. | Joel Sherrill | 1997-10-21 | 3 | -6/+9 |
