* Makefile.am: Remove SUBDIRS.
* configure.ac: Reflect having removed shared/*/Makefile.am
* Makefile.am: Merge-in bootloader/Makefile.am, clock/Makefile.am,
console/Makefile.am, include/Makefile.am, irq/Makefile.am,
motorola/Makefile.am, openpic/Makefile.am, pci/Makefile.am,
residual/Makefile.am, start/Makefile.am, startup/Makefile.am,
vectors/Makefile.am, vme/Makefile.am. Use automake compilation rules.
* bootloader/Makefile.am, clock/Makefile.am, console/Makefile.am,
include/Makefile.am, irq/Makefile.am, motorola/Makefile.am,
openpic/Makefile.am, pci/Makefile.am, residual/Makefile.am,
start/Makefile.am, startup/Makefile.am, vectors/Makefile.am,
vme/Makefile.am: Remove.
* Makefile.am: Merge-in 3c509/Makefile.am, clock/Makefile.am,
console/Makefile.am, ide/Makefile.am, ne2000/Makefile.am,
startup/Makefile.am, timer/Makefile.am, wd8003/Makefile.am,
wrapup/Makefile.am. Use automake compilation rules.
* 3c509/Makefile.am, clock/Makefile.am, console/Makefile.am,
ide/Makefile.am, ne2000/Makefile.am, startup/Makefile.am,
timer/Makefile.am, wd8003/Makefile.am, wrapup/Makefile.am: Remove.
* start/start.S: Change comment to make it gcc -ansi compliant.
* irq/irq_asm.S: Convert #..-comments to /*..*/ comments.
* Makefile.am: Correct path to clockdrv_shell.c.
* configure.ac: Remove AM_CONDITIONAL(HAS_MP).
Remove RTEMS_CHECK_MULTIPROCESSING.
* libnetworking/rtems_webserver/Makefile.am: Add PREINSTALL_DIRS.
* libnetworking/rtems_telnetd/Makefile.am: Add PREINSTALL_DIRS.
* libnetworking/rtems_servers/Makefile.am: Add PREINSTALL_DIRS.
* libnetworking/pppd/Makefile.am: Add PREINSTALL_DIRS.
* aclocal/rpm.m4: Make osversions the default.
* aclocal/rtems-top.m4: Remove check for version.m4 (Breaks make
distcheck).
* Makefile.am: Cosmetics.
* configure.ac: Remove RTEMS_CHECK_MULTIPROCESSING.
* aclocal/check-multiprocessing.m4: Remove AC_SUBST(HAS_MP).
Add AM_CONDITIONAL(HAS_MP).
* wrapup/Makefile.am: Fix path to ../libchip/shmdr.rel.
* aclocal/enable-cxx.m4, aclocal/enable-itron.m4,
aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4,
aclocal/enable-posix.m4, aclocal/enable-rdbg.m4,
aclocal/multilib.m4: Use AS_HELP_STRING instead of AC_HELP_STRING
(Deprecated by autoconf 2.59).
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove.
* bsp_specs: Sync with other BSPs, fixup missing brace.
* Makefile.am: Correct path to libcpu.
* Makefile.am: Fix minor bugs in previous patch.
shmsupp/Makefile.am, start/Makefile.am, startup/Makefile.am,
timer/Makefile.am, wrapup/Makefile.am. Use automake compilation rules.
shmsupp/Makefile.am, startup/Makefile.am, timer/Makefile.am,
* Makefile.am: Merge-in console/Makefile.am, liblnk/Makefile.am,
start/Makefile.am, startup/Makefile.am, wrapup/Makefile.am. Use automake
compilation rules.
* console/Makefile.am, liblnk/Makefile.am, start/Makefile.am,
startup/Makefile.am, wrapup/Makefile.am: Remove.
* configure.ac: Add RTEMSRPMGROUP.
* common/rtems.texi.in: Add RTEMSRPMGROUP.
* started/binaries.t: Add RTEMSRPMGROUP.
* aclocal/rpms.m4: New (extracted from scripts/configure.ac).
* ChangeLog: Merge-in started/ChangeLog.
* started/ChangeLog: Remove.
* binaries.t, buildc.t: Use @value{RTEMSRPMPREFIX} in refs to rpms.
* configure.ac: Add RTEMS_ENABLE_RPMPREFIX.
Add RTEMSRPMPREFIX.
* common/rtems.texi.in: Add RTEMSRPMPREFIX.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am. Use automake
compilation rules.
* clock/Makefile.am, console/Makefile.am, startup/Makefile.am,
* start/start.S: Replace #-ASM-style comments with C-/**/ comments.
* start/reg.S: Remove //-comments
* Makefile.am: Merge-in clock/.cvsignore, console/.cvsignore,
irq/.cvsignore, network/.cvsignore, startup/.cvsignore,
vectors/.cvsignore. Use automake compilation rules.
* clock/.cvsignore, console/.cvsignore, irq/.cvsignore,
network/.cvsignore, startup/.cvsignore, vectors/.cvsignore: Remove.
* wrapup/Makefile: Reflect changes above.
network/Makefile.am, nvram/Makefile.am, pci/Makefile.am,
startup/Makefile.am, timer/Makefile.am, tod/Makefile.am,
universe/Makefile.am, vectors/Makefile.am. Use automake compilation
rules.
* clock/Makefile.am, console/Makefile.am, network/Makefile.am,
nvram/Makefile.am, pci/Makefile.am, startup/Makefile.am,
timer/Makefile.am, tod/Makefile.am, universe/Makefile.am,
vectors/Makefile.am: Remove.
PCI_bus/Makefile.am, startup/Makefile.am, timer/Makefile.am,
tod/Makefile.am, vectors/Makefile.am. Use automake compilation rules.
* clock/Makefile.am, console/Makefile.am, PCI_bus/Makefile.am,
ide/Makefile.am, irq/Makefile.am, network/Makefile.am,
startup/Makefile.am, vectors/Makefile.am. Use automake compilation rules.
* clock/Makefile.am, console/Makefile.am, ide/Makefile.am,
irq/Makefile.am, network/Makefile.am, startup/Makefile.am,
* Makefile.am: Merge-in dlentry/Makefile.am, flashentry/Makefile.am,
startup/Makefile.am. Use automake compilation rules.
* dlentry/Makefile.am, flashentry/Makefile.am, startup/Makefile.am:
Remove.
scv64/Makefile.am, sonic/Makefile.am, start/Makefile.am,
startup/Makefile.am, timer/Makefile.am, tod/Makefile.am. Use automake
compilation rules.
* clock/Makefile.am, console/Makefile.am, scv64/Makefile.am,
sonic/Makefile.am, start/Makefile.am, startup/Makefile.am,
timer/Makefile.am, tod/Makefile.am: Remove.
* configure.ac, wrapup/Makefile.am: Reflect changes above.
* Makefile.am: Merge-in dlentry/Makefile.am, startup/Makefile.am. Use
* dlentry/Makefile.am, startup/Makefile.am: Remove.
startup/Makefile.am, timer/Makefile.am, vectors/Makefile.am: Remove.
* Makefile.am: Merge-in canbus/Makefile.am, clock/Makefile.am,
console/Makefile.am, irq/Makefile.am, network/Makefile.am,
* canbus/Makefile.am, clock/Makefile.am, console/Makefile.am,
* wrapup/Makefile.am: Remove.
* configure.ac: Remove wrapup.
* shared/Makefile.am: Use automake compilation rules.
Build *.rels.
irq/Makefile.am, motorola/Makefile.am, openpic/Makefile.am,
pci/Makefile.am, residual/Makefile.am, start/Makefile.am,
startup/Makefile.am, vectors/Makefile.am, vme/Makefile.am.
Rename clock.rel to pclock.rel (Conflict with libcpu).
* clock/Makefile.am, console/Makefile.am, irq/Makefile.am,
vectors/Makefile.am, vme/Makefile.am: Remove.
PR pppd/564
* libnetworking/net/if_ppp.c, libnetworking/net/if_pppvar.h,
libnetworking/net/ppp_tty.c: ppp0 Interface lose packets if the
system use a slow baudrate for the modem or the tcp/ip-packet is
fragmented.
* ChangeLog, rtems/Makefile.am, rtems/include/rtems/rtems/support.h:
Reverse developmental patches accidentally committed.
PR pppd/564
* rtems/Makefile.am, rtems/include/rtems/rtems/support.h: ppp0
Interface lose packets if the system use a slow baudrate for the
modem or the tcp/ip-packet is fragmented.
* Makefile.am: Merge-in start/Makefile.am.
* start/Makefile.am: Remove.
* wrapup/Makefile.am: Reflect changes to
../support/*exception_processing/*.
* configure.ac: Add RTEMS_PROG_CCAS.
* Makefile.am: Use automake compilation rules.
