* shared/start.S: Backport from rtems-4-6-branch.
* leon_smc91111/leon_smc91111.c, README, timer/timer.c,
startup/ithread.S, startup/setvec.c, startup/spurious.c,
startup/linkcmds, startup/bspstart.c, console/console.c,
console/debugputs.c, console/consolereserveresources.c,
bsp_specs, amba/amba.c, gnatsupp/gnatsupp.c, include/coverhd.h,
include/tm27.h, include/leon.h, include/bsp.h, include/amba.h,
Makefile.am, configure.ac, times, leon_open_eth/leon_open_eth.c
clock/ckinit.c: Backport from rtems-4-6-branch.
startup/setvec.c, startup/spurious.c, startup/linkcmds,
console/console.c, console/debugputs.c,
console/consolereserveresources.c, bsp_specs, gnatsupp/gnatsupp.c,
include/coverhd.h, include/tm27.h, include/leon.h, include/bsp.h,
Makefile.am, configure.ac, times, leon_open_eth/leon_open_eth.c,
* Makefile.am, runtest.in, configure.ac: Backport from
rtems-4-6-branch.
* libnetworking/rtems/rtems_mii_ioctl.h: Fix formatting.
* network/network.c: Remove warnings.
* acinclude.m4: Add gen5200 to list of BSPs.
* Makefile.am, vme/vmeconfig.c: VME code now compiles but is untested.
Jennifer will have to test this.
* optman/sapi/no-io.c: Change rtems_io_register_name to take a const
char *.
* libcsupport/src/unixlibc.c, libfs/src/imfs/ioman.c: Change
rtems_io_register_name to take a const char *.
* sapi/include/rtems/io.h, sapi/src/io.c: Change rtems_io_register_name
* user/io.t: Change rtems_io_register_name to take a const char *.
* libchip/i2c/i2c-2b-eeprom.c, libchip/i2c/i2c-ds1621.c: Eliminate
warnings.
* .cvsignore: Add install-sh and missing.
* psim, psim-gdb: Add setting of PVR to 0xfffe0000 since psim needs a
special processor version value or exceptions will not work.
the exception vector number to yield correct result even if
the vectors reside in the upper area (0xfff00000; psim).
known variant.
* vectors/asm_utils.S: Remove (Bogus, now in libcpu).
submission).
PR 851/bsps
* custom/gen5200.cfg, custom/pm520_cr825.cfg, custom/pm520_ze30.cfg:
New (Submission by Thomas Doerfler <Thomas.Doerfler@embedded-brains.de>).
* bestcomm/bestcomm_glue.c, bestcomm/bestcomm_glue.h, clock/clock.c,
console/console.c, i2c/i2cdrv.c, i2c/mpc5200mbus.c,
i2c/mpc5200mbus.h, ide/idecfg.c, ide/pcmcia_ide.c, ide/pcmcia_ide.h,
include/bsp.h, include/mpc5200.h, irq/irq.c, irq/irq.h,
irq/irq_asm.S, irq/irq_init.c, mscan/mscan.c, mscan/mscan.h,
network_5200/network.c, nvram/m93cxx.h, nvram/nvram.c,
nvram/nvram.h, slicetimer/slicetimer.c, slicetimer/slicetimer.h,
start/start.S, startup/bspstart.c, startup/cpuinit.c, tod/pcf8563.c,
tod/pcf8563.h, tod/todcfg.c, vectors/vectors.S,
vectors/vectors_init.c: Cleanup CVS data.
PR 851/bsps
* aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Add gen5200 BSP
family.
* irq/irq.c, irq/irq_init.c, vectors/vectors_init.c:
include <libcpu/raw_exceptions.h>.
* include/raw_exception.h, vectors/raw_exception.c: Remove.
Use implementation from libcpu instead.
PR 851/bsps
* mpc6xx/exceptions/raw_exception.c: Add PPC_603le.
* mpc6xx/exceptions/raw_exception.c: Cosmetics.
* bestcomm/bestcomm_glue.c, clock/clock.c, console/console.c,
i2c/i2c.c, i2c/i2cdrv.c, ide/idecfg.c, ide/pcmcia_ide.c,
ide/pcmcia_ide.h, include/i2c.h, irq/irq.c, irq/irq_init.c,
mscan/mscan.c, network_5200/network.c, nvram/nvram.c, nvram/nvram.h,
slicetimer/slicetimer.c, startup/bspstart.c, startup/cpuinit.c,
tod/todcfg.c, vectors/vectors_init.c: Misc include file fixes.
submission).
