* | Remove (Abandoned) | Ralf Corsepius | 2010-06-17 | 79 | -4413/+0 |
* | 2010-06-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-17 | 2 | -7/+4 |
| | | | | * configure.ac: Remove itron. | ||||
* | 2010-06-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-17 | 3 | -13/+5 |
| | | | | | * aclocal/enable-itron.m4: Remove. * configure.ac: Remove itron. | ||||
* | 2010-06-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-17 | 1 | -0/+88 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * itron/Makefile.am, itron/preinstall.am itron/include/itron.h, itron/include/itronsys/README itron/include/itronsys/eventflags.h, itron/include/itronsys/fmempool.h, itron/include/itronsys/intr.h, itron/include/itronsys/mbox.h, itron/include/itronsys/msgbuffer.h, itron/include/itronsys/network.h, itron/include/itronsys/port.h, itron/include/itronsys/semaphore.h, itron/include/itronsys/status.h, itron/include/itronsys/sysmgmt.h, itron/include/itronsys/task.h, itron/include/itronsys/time.h, itron/include/itronsys/types.h, itron/include/itronsys/vmempool.h, itron/include/rtems/itron/README, itron/include/rtems/itron/config.h, itron/include/rtems/itron/eventflags.h, itron/include/rtems/itron/fmempool.h, itron/include/rtems/itron/intr.h, itron/include/rtems/itron/itronapi.h, itron/include/rtems/itron/mbox.h, itron/include/rtems/itron/msgbuffer.h, itron/include/rtems/itron/network.h, itron/include/rtems/itron/object.h, itron/include/rtems/itron/port.h, itron/include/rtems/itron/semaphore.h, itron/include/rtems/itron/sysmgmt.h, itron/include/rtems/itron/task.h, itron/include/rtems/itron/time.h, itron/include/rtems/itron/vmempool.h, itron/inline/rtems/itron/eventflags.inl, itron/inline/rtems/itron/fmempool.inl, itron/inline/rtems/itron/intr.inl, itron/inline/rtems/itron/mbox.inl, itron/inline/rtems/itron/msgbuffer.inl, itron/inline/rtems/itron/network.inl, itron/inline/rtems/itron/port.inl, itron/inline/rtems/itron/semaphore.inl, itron/inline/rtems/itron/sysmgmt.inl, itron/inline/rtems/itron/task.inl, itron/inline/rtems/itron/time.inl, itron/inline/rtems/itron/vmempool.inl, itron/src/TODO, itron/src/acp_por.c, itron/src/act_cyc.c, itron/src/cal_por.c, itron/src/can_wup.c, itron/src/chg_iXX.c, itron/src/chg_pri.c, itron/src/clr_flg.c, itron/src/cre_flg.c, itron/src/cre_mbf.c, itron/src/cre_mbx.c, itron/src/cre_mpf.c, itron/src/cre_mpl.c, itron/src/cre_por.c, itron/src/cre_sem.c, itron/src/cre_tsk.c, itron/src/def_alm.c, itron/src/def_cyc.c, itron/src/def_exc.c, itron/src/def_int.c, itron/src/def_svc.c, itron/src/del_flg.c, itron/src/del_mbf.c, itron/src/del_mbx.c, itron/src/del_mpf.c, itron/src/del_mpl.c, itron/src/del_por.c, itron/src/del_sem.c, itron/src/del_tsk.c, itron/src/dis_dsp.c, itron/src/dis_int.c, itron/src/dly_tsk.c, itron/src/ena_dsp.c, itron/src/ena_int.c, itron/src/eventflags.c, itron/src/exd_tsk.c, itron/src/ext_tsk.c, itron/src/fmempool.c, itron/src/frsm_tsk.c, itron/src/fwd_por.c, itron/src/get_blf.c, itron/src/get_blk.c, itron/src/get_tid.c, itron/src/get_tim.c, itron/src/get_ver.c, itron/src/itroninittasks.c, itron/src/itronintr.c, itron/src/itronsem.c, itron/src/itrontime.c, itron/src/loc_cpu.c, itron/src/mbox.c, itron/src/mboxtranslatereturncode.c, itron/src/msgbuffer.c, itron/src/msgbuffertranslatereturncode.c, itron/src/network.c, itron/src/nget_nod.c, itron/src/nget_ver.c, itron/src/nrea_dat.c, itron/src/nwri_dat.c, itron/src/pacp_por.c, itron/src/pcal_por.c, itron/src/pget_blf.c, itron/src/pget_blk.c, itron/src/pol_flg.c, itron/src/port.c, itron/src/prcv_mbf.c, itron/src/prcv_mbx.c, itron/src/preq_sem.c, itron/src/psnd_mbf.c, itron/src/rcv_mbf.c, itron/src/rcv_mbx.c, itron/src/ref_alm.c, itron/src/ref_cfg.c, itron/src/ref_cyc.c, itron/src/ref_flg.c, itron/src/ref_iXX.c, itron/src/ref_mbf.c, itron/src/ref_mbx.c, itron/src/ref_mpf.c, itron/src/ref_mpl.c, itron/src/ref_por.c, itron/src/ref_sem.c, itron/src/ref_sys.c, itron/src/ref_tsk.c, itron/src/rel_blf.c, itron/src/rel_blk.c, itron/src/rel_wai.c, itron/src/ret_int.c, itron/src/ret_tmr.c, itron/src/ret_wup.c, itron/src/rot_rdq.c, itron/src/rpl_rdv.c, itron/src/rsm_tsk.c, itron/src/set_flg.c, itron/src/set_tim.c, itron/src/sig_sem.c, itron/src/slp_tsk.c, itron/src/snd_mbf.c, itron/src/snd_mbx.c, itron/src/sta_tsk.c, itron/src/sus_tsk.c, itron/src/sysmgmt.c, itron/src/tacp_por.c, itron/src/task.c, itron/src/tcal_por.c, itron/src/ter_tsk.c, itron/src/tget_blf.c, itron/src/tget_blk.c, itron/src/trcv_mbf.c, itron/src/trcv_mbx.c, itron/src/tslp_tsk.c, itron/src/tsnd_mbf.c, itron/src/twai_flg.c, itron/src/twai_sem.c, itron/src/unl_cpu.c, itron/src/vmempool.c, itron/src/wai_flg.c, itron/src/wai_sem.c, itron/src/wup_tsk.c: Remove (Abandoned). | ||||
* | Remove (Abandoned). | Ralf Corsepius | 2010-06-17 | 167 | -10462/+0 |
* | 2010-06-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-17 | 1 | -0/+9 |
| | | | | | | | | | * wrapup/Makefile.am, score/Makefile.am: Remove LIBITRON. * score/src/objectallocatebyindex.c, score/src/objectgetbyindex.c, score/src/threadrotatequeue.c: Remove. * Makefile.am: Remove itron. * configure.ac: Remove itron. * aclocal/check-itron.m4, aclocal/enable-itron.m4: Remove. | ||||
* | Remove LIBITRON. | Ralf Corsepius | 2010-06-17 | 2 | -14/+0 |
* | Remove itron. | Ralf Corsepius | 2010-06-17 | 2 | -10/+1 |
* | Remove. | Ralf Corsepius | 2010-06-17 | 5 | -282/+0 |
* | 2010-06-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-17 | 2 | -2/+4 |
| | | | | | * libfs/src/rfs/rtems-rfs-file-system.h: Revert previous change. Force RTEMS_RFS_VERSION_MASK to be 32bit. | ||||
* | 2010-06-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-17 | 2 | -1/+4 |
| | | | | * libfs/src/rfs/rtems-rfs-rtems-dir.c: Various 64bit fixes. | ||||
* | 2010-06-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-17 | 2 | -9/+11 |
| | | | | * libfs/src/rfs/rtems-rfs-format.c: Various 64bit fixes. | ||||
* | 2010-06-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-17 | 2 | -2/+5 |
| | | | | * libfs/src/rfs/rtems-rfs-file-system.c: Various 64bit fixes. | ||||
| | | | | * libfs/src/rfs/rtems-rfs-rtems-file.c: Various 64bit fixes. | ||||
* | 2010-06-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-17 | 2 | -13/+14 |
| | | | | * libfs/src/rfs/rtems-rfs-buffer.c: Various 64bit fixes. | ||||
* | 2010-06-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-17 | 2 | -29/+35 |
| | | | | * libfs/src/rfs/rtems-rfs-shell.c: Various 64bit fixes. | ||||
* | 2010-06-17 Chris Johns <chrisj@rtems.org> | Chris Johns | 2010-06-17 | 4 | -6/+12 |
| | | | | | | libfs/src/rfs/rtems-rfs-bitmaps.h, libfs/src/rfs/rtems-rfs-block-pos.h, libfs/src/rfs/rtems-rfs-block.h: PR 1556. Struct clean up. | ||||
* | 2010-06-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-17 | 2 | -21/+23 |
| | | | | * libfs/src/rfs/rtems-rfs-bitmaps-ut.c: Various 64bit fixes. | ||||
* | 2010-06-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-17 | 2 | -5/+11 |
| | | | | * libfs/src/rfs/rtems-rfs-group.c: Various 64bit fixes. | ||||
* | 2010-06-16 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-06-16 | 2 | -1/+21 |
| | | | | | PR 1568/doc * user/intr.t: Fix list of services callable from ISR. | ||||
* | 2010-06-16 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-06-16 | 2 | -3/+8 |
| | | | | | | PR 1453/cpukit * posix/Makefile.am: newlib uses sysconf() for _CLOCKS_PER_SEC_ so enable it even when POSIX threads are disabled. | ||||
* | 2010-06-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-16 | 2 | -11/+17 |
| | | | | * libfs/src/rfs/rtems-rfs-file.c: Various 64bit fixes. | ||||
* | 2010-06-16 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-06-16 | 2 | -0/+23 |
| | | | | | | | * score/src/objectallocate.c: Add conditionally compiled debug code to printk a message when an object allocation error occurs. This should be helpful in identifying when a ported package required more resources. | ||||
* | 2010-06-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-16 | 2 | -5/+8 |
| | | | | * libfs/src/rfs/rtems-rfs-inode.c: Various 64bit fixes. | ||||
* | 2010-06-16 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-06-16 | 2 | -68/+70 |
| | | | | * cpu_asm.S: Remove trailing tabs. | ||||
* | 2010-06-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-16 | 2 | -17/+28 |
| | | | | | * libfs/src/rfs/rtems-rfs-rtems.c: Various 64bit fixes. Add PRIomode_t. | ||||
* | 2010-06-16 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-06-16 | 2 | -103/+106 |
| | | | | * cpu_asm.S: Use SYM macro to be consistent with other ports. | ||||
* | 2010-06-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-16 | 2 | -2/+8 |
| | | | | | * libfs/src/rfs/rtems-rfs-buffer-bdbuf.c: Various 64bit fixes. | ||||
* | 2010-06-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-16 | 10 | -16/+24 |
| | | | | | | | | | | | | | | PR 1556/cpukit * libfs/src/rfs/rtems-rfs-bitmaps.h, libfs/src/rfs/rtems-rfs-block-pos.h, libfs/src/rfs/rtems-rfs-buffer.h, libfs/src/rfs/rtems-rfs-file-system-fwd.h, libfs/src/rfs/rtems-rfs-file-system.h, libfs/src/rfs/rtems-rfs-file.h, libfs/src/rfs/rtems-rfs-format.h, libfs/src/rfs/rtems-rfs-group.h, libfs/src/rfs/rtems-rfs-inode.h: Rename "struct rtems_rfs_*_t" into "struct _rtems_rfs_*". | ||||
* | 2010-06-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-16 | 2 | -1/+6 |
| | | | | | PR 1556/cpukit * libfs/src/rfs/rtems-rfs-shell.c: Remove rtems_rfs_shell_cmd_t. | ||||
* | 2010-06-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-16 | 5 | -8/+16 |
| | | | | | | | | PR 1566/filesystem * libnetworking/rtems/mkrootfs.c, libnetworking/rtems/mkrootfs.h: Let rtems_rootfs_append_host_rec take an in_addr_t as first arg. * libnetworking/rtems/rtems_dhcp.c, libnetworking/nfs/bootp_subr.c: Reflect changes above. | ||||
* | 2010-06-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-15 | 3 | -49/+68 |
| | | | | | | | * libfs/src/rfs/rtems-rfs-dir.c: Various 64bit compatibility fixes. Add PRIdoff_t. Remove stray "\"s. * libfs/src/rfs/rtems-rfs-link.c: Various 64bit compatibility fixes. | ||||
* | Never should have been added. | Joel Sherrill | 2010-06-15 | 1 | -654/+0 |
* | 2010-06-15 Gedare Bloom <giddyup44@yahoo.com> | Joel Sherrill | 2010-06-15 | 4 | -1/+832 |
| | | | | | | | PR 1565/cpukit * cpu_supplement/Makefile.am, cpu_supplement/cpu_supplement.texi: Merge SPARC64 port. * cpu_supplement/sparc64.t: New file. | ||||
* | 2010-06-15 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-06-15 | 2 | -0/+6 |
| | | | | | PR 1561/cpukit * aclocal/rtems-cpu-subdirs.m4: Merge SPARC64 port. | ||||
* | 2010-06-15 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-06-15 | 3 | -0/+7 |
| | | | | | PR 1561/cpukit * configure.ac, score/cpu/Makefile.am: Merge SPARC64 port. | ||||
* | 2010-06-15 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-06-15 | 12 | -0/+2766 |
| | | | | | | | PR 1561/cpukit * .cvsignore, ChangeLog, Makefile.am, Makefile.in, README, context.S, cpu.c, preinstall.am, rtems/asm.h, rtems/score/cpu.h, rtems/score/sparc64.h, rtems/score/types.h: New files. | ||||
* | 2010-06-15 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-06-15 | 2 | -1/+5 |
| | | | | * shared/irq/irq_asm.S: Fix capitalization. | ||||
| | | | | * posix/src/psignal.c: Formatting. | ||||
* | 2010-06-15 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-06-15 | 2 | -1/+4 |
| | | | | * cpu_asm.S: Formatting. | ||||
* | 2010-06-15 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-06-15 | 2 | -4/+15 |
| | | | | * posix/include/rtems/posix/pthread.h: Improve comments. | ||||
* | 2010-06-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-15 | 2 | -1/+2 |
| | | | | * libfs/src/rfs/rtems-rfs-file-system.h: Remove bogus typecast. | ||||
* | 2010-06-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-15 | 4 | -9/+14 |
| | | | | | * libfs/src/rfs/rtems-rfs-block.c, libfs/src/rfs/rtems-rfs-buffer.c, libnetworking/nfs/bootp_subr.c: Misc. 64bit-compatibility fixes. | ||||
* | 2010-06-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-15 | 2 | -3/+8 |
| | | | | | * posix/include/rtems/posix/pthread.h: Remove stray comment. Work-around doxygen comment bug. | ||||
* | 2010-06-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-15 | 3 | -5/+11 |
| | | | | | * libnetworking/netinet/ip_fw.c, libnetworking/netinet/ip_input.c: Misc. 64bit-compatibility fixes. | ||||
* | 2010-06-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-15 | 3 | -5/+14 |
| | | | | | | * libmisc/shell/print-ls.c, libmisc/shell/main_msdosfmt.c: Include <inttypes.h>. Misc. 64bit-compatibility fixes. | ||||
* | 2010-06-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-14 | 2 | -2/+4 |
| | | | | * libmd/md5.h: Revert Sebastian's patch. | ||||
* | 2010-06-14 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-06-14 | 2 | -1/+6 |
| | | | | * Makefile.am: Formatting. | ||||
* | 2010-06-14 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-06-14 | 2 | -1/+5 |
| | | | | * startup/bspclean.c: Spelling. | ||||
* | 2010-06-14 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-06-14 | 4 | -7/+16 |
| | | | | * startup/bspstart.c: Formatting. |
