* | 2009-10-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-14 | 5 | -20/+7 |
| | | | | | * HELP.html, bsp_howto/support.t, relnotes/status.texi, started_ada/buildada.t: Remove references to posix/Unix port. | ||||
* | 2009-10-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-14 | 2 | -5/+4 |
| | | | | * tmck/task1.c: Remove support for "unix". | ||||
* | 2009-10-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-14 | 2 | -125/+1 |
| | | | | * aclocal/sysv-ipc.m4: Remove (unused). | ||||
* | 2009-10-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-14 | 2 | -10/+4 |
| | | | | * configure.ac: Remove RTEMS_UNIX, RTEMS_UNIXLIB. | ||||
* | 2009-10-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-14 | 1 | -1/+4 |
| | | | | | | | * configure.ac: Remove some unix-specific checks. Remove unix-CPU_CONTEXT size checking. Remove enable-unixlib. Remove unix subdir. | ||||
* | Remove some unix-specific checks. | Ralf Corsepius | 2009-10-14 | 1 | -4/+2 |
* | Remove unix-CPU_CONTEXT size checking. | Ralf Corsepius | 2009-10-14 | 1 | -5/+0 |
* | Remove unix-CPU_CONTEXT size checking. | Ralf Corsepius | 2009-10-14 | 1 | -17/+0 |
* | Remove enable-unixlib. | Ralf Corsepius | 2009-10-14 | 1 | -6/+0 |
* | 2009-10-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-14 | 1 | -0/+8 |
| | | | | * configure.ac: Remove unix subdir. | ||||
* | Remove unix subdir. | Ralf Corsepius | 2009-10-14 | 1 | -1/+0 |
* | 2009-10-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-14 | 1 | -0/+6 |
| | | | | | | * aclocal/canonical-target-name.m4, aclocal/check-networking.m4, aclocal/check-posix.m4, aclocal/enable-posix.m4: Remove unix/posix. | ||||
* | Remove unix/posix. | Ralf Corsepius | 2009-10-14 | 4 | -27/+0 |
* | Remove posix/unix. | Ralf Corsepius | 2009-10-14 | 5 | -34/+0 |
* | Remove (Abandoned). | Ralf Corsepius | 2009-10-14 | 42 | -2569/+0 |
* | 2009-10-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-14 | 1 | -0/+4 |
| | | | | * score/cpu/Makefile.am: Remove unix subdir. | ||||
* | 2009-10-14 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-10-14 | 2 | -1/+5 |
| | | | | * Makefile.am: Remove reference to timer_SOURCES. | ||||
* | Remove unix subdir. | Ralf Corsepius | 2009-10-14 | 1 | -1/+1 |
* | Remove (Abandoned) | Ralf Corsepius | 2009-10-14 | 9 | -2936/+0 |
* | 2009-10-14 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-14 | 1 | -0/+5 |
| | | | | | * aclocal/canonical-target-name.m4: Remove posix/unix simulator. | ||||
* | Remove posix/unix simulator. | Ralf Corsepius | 2009-10-14 | 3 | -39/+0 |
| | | | | | * aclocal/canonical-target-name.m4, aclocal/enable-posix.m4: Remove posix/unix simulator. | ||||
| | | | | | | * custom/Cygwin-posix.cfg, custom/FreeBSD-posix.cfg, custom/Linux-posix.cfg, custom/Solaris-posix.cfg, custom/posix.cfg: Remove. | ||||
* | Remove. | Ralf Corsepius | 2009-10-14 | 5 | -108/+0 |
| | | | | | | * configure.ac: Rework make/custom/* handling. * aclocal/check-custom-bsp.m4: Change *.cfg handling. * Makefile.am: Remove make/custom/default.cfg-rule. | ||||
* | Rework make/custom/* handling. | Ralf Corsepius | 2009-10-14 | 1 | -10/+20 |
* | Change *.cfg handling. | Ralf Corsepius | 2009-10-14 | 1 | -3/+3 |
* | Remove make/custom/default.cfg-rule. | Ralf Corsepius | 2009-10-14 | 1 | -3/+0 |
* | 2009-10-13 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2009-10-14 | 2 | -3/+26 |
| | | | | | | | | | PR 1451/bsps * network/tsec.c: Fix mbuf leak when watchdog expires. The re-initialization algorithm failed to release mbuf chains held in the TX ring. Also, during initialization the initial link status is determined and IFF_OACTIVE set if no active link was detected. | ||||
* | 2009-10-13 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-13 | 1 | -0/+3 |
| | | | | | | * libblock/include/rtems/bdbuf.h: Use size_t for swapout_workers. * libblock/src/bdpart.c: Add __attribute__((unused)) to suppress warnings. | ||||
* | Use size_t for sizes. | Ralf Corsepius | 2009-10-13 | 1 | -2/+2 |
* | Add __attribute__((unused)) to suppress warnings. | Ralf Corsepius | 2009-10-13 | 1 | -3/+3 |
* | Use size_t for swapout_workers. | Ralf Corsepius | 2009-10-13 | 1 | -1/+1 |
* | 2009-10-13 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-13 | 2 | -3/+10 |
| | | | | | * libblock/src/bdbuf.c: Fix broken printf formats. Use size_t for sizes. | ||||
* | Enable interrupts during open to avoid NULL pointer access in interrupt handler. | Thomas Doerfler | 2009-10-13 | 2 | -2/+14 |
* | Update for block device API change. | Thomas Doerfler | 2009-10-13 | 3 | -8/+14 |
* | * libblock/include/rtems/diskdevs.h: Added driver data pointer to IO | Thomas Doerfler | 2009-10-13 | 9 | -79/+159 |
| | | | | | | | | | control function. The IO control handler takes now the disk device as first parameter instead of the physical device number. * cpukit/libblock/include/rtems/blkdev.h, libblock/src/bdbuf.c, libblock/src/blkdev.c, libblock/src/diskdevs.c, libblock/src/nvdisk.c, libblock/src/flashdisk.c, libblock/src/ramdisk.c: Update for block device API change. | ||||
* | 2009-10-09 Sebastian Huber <sebastian.huber@embedded-brains.de> | Joel Sherrill | 2009-10-12 | 2 | -54/+35 |
| | | | | * bootcard: Update for heap API changes. | ||||
* | Reflect having introduced rtems_error_code_t. | Ralf Corsepius | 2009-10-12 | 1 | -2/+2 |
* | Introduce rtems_error_code_t. | Ralf Corsepius | 2009-10-12 | 1 | -2/+6 |
| | | | | Minor portability code-massaging. | ||||
* | 2009-10-12 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-10-12 | 3 | -6/+7 |
| | | | | * cpuuse/init.c, cpuuse/system.h: Use minimum stack size. | ||||
* | 2009-10-12 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-10-12 | 3 | -4/+10 |
| | | | | | * include/bsp.h: BSP has plenty of memory. * startup/cmain.c: Comment out prints. | ||||
* | 2009-10-12 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-12 | 1 | -0/+7 |
| | | | | | | | * score/include/rtems/score/interr.h: Introduce Internal_errors_t. * score/src/interr.c, score/include/rtems/score/userext.h, score/src/userextthreadbegin.c: Reflect having introduced Internal_errors_t. | ||||
* | Reflect having introduced Internal_errors_t. | Ralf Corsepius | 2009-10-12 | 3 | -8/+8 |
* | Introduce Internal_errors_t. | Ralf Corsepius | 2009-10-12 | 1 | -2/+9 |
* | increase size of ROM to 4 Meg | Thomas Doerfler | 2009-10-12 | 2 | -1/+5 |
* | 2009-10-11 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-10-12 | 3 | -0/+14 |
| | | | | * psx05/init.c, psx05/psx05.scn: Add test for bad mutex type. | ||||
* | 2009-10-11 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-10-12 | 9 | -2/+120 |
| | | | | | | | | | * psxcleanup/system.h: Fix typo. * Makefile.am, configure.ac: Add new test for exercising pushing and popping a clean up handler without actually executing it. * psxcleanup01/.cvsignore, psxcleanup01/Makefile.am, psxcleanup01/init.c, psxcleanup01/psxcleanup01.doc, psxcleanup01/psxcleanup01.scn: New files. | ||||
* | 2009-10-11 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-10-11 | 3 | -2/+8 |
| | | | | | * posix/src/alarm.c: If 0 seconds do not insert timer. * rtems/src/regionextend.c: Eliminate warning. Use default else. | ||||
* | 2009-10-11 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-10-11 | 8 | -1/+197 |
| | | | | | | | * Makefile.am, configure.ac: Add new test to ensure that canceling an alarm works as defined. * psxalarm01/.cvsignore, psxalarm01/Makefile.am, psxalarm01/init.c, psxalarm01/psxalarm01.doc, psxalarm01/psxalarm01.scn: New files. |
