* libnetworking/kern/kern_sysctl.c: Change int to int32_t.
* libnetworking/net/if_loop.c: Add cast to long.
These plus a patch to machine/param.h let the h8300 build multilib.
* Makefile.am, preinstall.am, startup/linkcmds, startup/linkcmds.brs5l,
startup/linkcmds.pm520: Add support for missing .rela sections.
Install linkcmds.
fixed bug in mscan
which included commits to RCS files with non-trunk default branches.
Merge bfin patch.
* configure.ac, gcc/build.add, gcc/target-gcc.add: Add bfin target
prior to merge. Add ability to disable libssp and libstdcxx-pch which
apparently are required to build the Blackfin port.
* patches/binutils-2.17-rtems-bfin-20060810.diff,
patches/gcc-4.1.1-bfinrtems-20060810a.diff,
patches/gdb-6.5-bfinrtems-20060810a.diff,
patches/newlib-1.14.0-bfinrtems-20060810a.diff,
rtems4.7/bfin/.cvsignore, rtems4.7/bfin/Makefile.am,
rtems4.7/bfin/binutils-sources.add, rtems4.7/bfin/gcc-sources.add,
rtems4.7/bfin/gdb-sources.add: New files.
'frame' argument to C_dispatch_irq_handler(). It's
really a BSP_Exception_frame*, not a CPU_Interrupt_frame*.
fixed wrong calculation of 1000baseTx autonegotiation
result.
* cpu.c, rtems/score/sh.h: Recognize sh2e variant so multilibs will all
compile.
* nios2gen.c: Added some very basic support for --help and --version
options along with output that is roughly in GNU format. This is
required by help2man. help2man expects this all to be written to
stdout instead of stderr so this was changed as well.
* ChangeLog: New file.
* .cvsignore: New file.
* .cvsignore: Add INSTALL.
* rtems/score/cpu.h: Because gcc implicitly uses floating point turn on
floating point for all threads if there is a hardware FPU.
* startup/linkcmds: Clean up a bit after adding missing .rela sections.
* clock/clock.c: New file.
* rtems/score/cpu.h, rtems/score/cpu_asm.h, rtems/score/nios2.h,
rtems/score/types.h: New files.
* configure.ac: New port to Altera NIOS II.
* nios2/.cvsignore, nios2/Makefile.am, nios2/README, nios2/bridges.c,
nios2/bridges.h, nios2/clocks.c, nios2/clocks.h, nios2/configure.ac,
nios2/devices.c, nios2/devices.h, nios2/nios2gen.c, nios2/output.c,
nios2/output.h, nios2/ptf.c, nios2/ptf.h: New files.
* aclocal/rtems-cpu-subdirs.m4: New port to Altera NIOS II.
* configure.ac, librpc/src/xdr/xdr_float.c, score/cpu/Makefile.am: New
* TOOL_TARGETS: New port to Altera NIOS II.
* config-ml.in: New port to Altera NIOS II.
* nios2/Makefile.am, nios2/configure.ac, nios2/preinstall.am,
nios2/shared/cache/cache.c, nios2/shared/cache/cache_.h,
nios2/shared/misc/memcpy.c: New files.
* Makefile.am: New port to Altera NIOS II.
* custom/nios2_iss.cfg: New file.
* ChangeLog, Makefile.am, cpu.c, cpu_asm.S, irq.c, preinstall.am,
rtems/asm.h: New files.
* ChangeLog, Makefile.am, README, acinclude.m4, configure.ac,
nios2_iss/ChangeLog, nios2_iss/Makefile.am, nios2_iss/bsp_specs,
nios2_iss/configure.ac, nios2_iss/nios2_iss.ptf,
nios2_iss/nios2_iss.sh, nios2_iss/times, nios2_iss/console/console.c,
nios2_iss/include/bsp.h, nios2_iss/include/bspopts.h.in,
nios2_iss/include/coverhd.h, nios2_iss/include/tm27.h,
nios2_iss/shmsupp/addrconv.c, nios2_iss/shmsupp/getcfg.c,
nios2_iss/shmsupp/lock.c, nios2_iss/shmsupp/mpisr.c,
nios2_iss/start/crtnn.s, nios2_iss/start/start.S,
nios2_iss/startup/bspclean.c, nios2_iss/startup/bspstart.c,
nios2_iss/startup/linkcmds, nios2_iss/startup/main.c,
nios2_iss/startup/setvec.c, nios2_iss/timer/timer.c: New files.
read ANER and include partner's autoneg
capability when determining active link parameters.
* build.sh: Log the script command lines.
* build-rpms.sh:
Updated to handle a different build processor to a i686.
* build-exes.sh:
Removed the tool version as Ralf has removed it from the
rpms.
2006-08-05 Chris Johns <chrisj@rtems.org>
* build-exes.sh: Update the release tag.
2006-08-04 Chris Johns <chrisj@rtems.org>
* build-exes.sh: Updated to support the new installer.
* build-rpms.sh:
Updated to use common rather than base. More rpmbuild work
arounds.
* build.sh: Fix the return code when used with tee.
* rtems.ini: Updated hello screen.
* rtems-tools.nsi: Generate the batch files when
installing.
* AUTHORS, README: Convert to DOS format.
2006-07-22 Chris Johns <chrisj@rtems.org>
* COPYING, build.sh, rtems-license.rtf:
Changes to the installer and an extra script to build all.
