* relnotes.texi: Print table of contents in front of manual where it
should be when you print.
* new_chapters.texi: Print table of contents in front of manual where
it should be when you print.
* custom/Linux-posix.cfg: Merge patch from Till Straumann which would
work except gcc core dumps with an ICE when may_alias is used in this
code. I filed a GCC PR and reduced optimization to -O0 and it does
run again.
* cpu.c: Merge patch from Till Straumann which would work except gcc
core dumps with an ICE when may_alias is used in this code. I filed a
GCC PR and reduced optimization to -O0 and it does run again.
* libnetworking/rtems/rtems_syscall.c: Remove RTEMS versions of send()
and recv(). We already had the BSD versions and these conflict
sometimes when linking.
* Templates/Makefile.leaf: At suggestion of Robert Grimes add commented
out make-cxx-exe usage example.
* libnetworking/rtems/mkrootfs.h, libnetworking/rtems/rtems_bsdnet.h,
libnetworking/rtems/rtems_bsdnet_internal.h: Add extern __cplusplus.
* sapi/include/confdefs.h: Do not instantiate initialization
thas/thread pointer tables for an API that is not configured.
* bsppost.c: Split open of the console from the standard BSP code so it
is easier to stub out.
* libcsupport/Makefile.am:
* libcsupport/src/open_dev_console.c: New file.
* optman/Makefile.am, optman/preinstall.am: Add stubs for file system,
console, and libio. This shrinks the memory requirements but Joel has
not figured out how best to present this to application space.
* optman/no-console.c, optman/no-filesystem.c, optman/no-libio.c:
New files.
* ne2000/ne2000.c: Fix spelling error.
* sp20/task1.c, sp34/changepri.c, sp35/priinv.c: Build when using
buffered test IO.
* tztest/init.c: Build when using buffered test IO.
* shared/uboot_dump_bdinfo.c: New file.
Add Embedded Planets EP5200 which is the same as the Freescale
5200Lite (a.k.a. IceCube) evaluation board.
* Makefile.am: Add linkcmds.ep5200.
Add -DMPC5200_BAPI_LIBC_HEADERS to remove some warnings in bestcomm.
* preinstall.am: Add linkcmds.ep5200.
* clock/clock.c: Correct math for prescaler/counter when bus speed
is high enough to require multiple passes of loop.
* console/console.c: Use same math for initial baud rate as when it
is changed via ioctl. When HAS_UBOOT is defined, initialize console
to the same baud as it was with U-Boot.
* include/bsp.h: Add EP5200 and console boot baud support.
* include/mpc5200.h: Spacing.
* startup/bspstart.c: If HAS_UBOOT and SHOW_MORE_INIT_SETTINGS are
both defined, dump the U-Boot BD info structure.
* vectors/vectors.S: ep5200 cannot use vectors segment. When loading
it, U-Boot freezes. Besides, U-Boot can automatically start the BSP
so we do not have to run from board reset.
* startup/linkcmds.ep5200: New file.
* aclocal/bsp-alias.m4, README.configure: Add ep5200, IceCube, 5200Lite.
* custom/gen5200.cfg: Remove junk comment.
* custom/ep5200.cfg: New file.
* score/src/corerwlock.c: Make sure structure is fully initialized.
When reused, some fields will not be zero like at initialization.
* sapi/include/confdefs.h: POSIX threads use twice the minimum stack
size. Account for this.
* shared/abort/simple_abort.c: Shrink the memory requirements. Joel
reformatted for style.
* startup/linkcmds: Shrink the aligment requirements.
* configure.ac: Add NDEBUG as a command line compilation option.
* acinclude.m4: Remove armulator.
* user/io.t: Fix typo.
* README.configure: Removed armulator.
* custom/armulator.cfg: Removed.
* armulator/.cvsignore, armulator/ChangeLog, armulator/Makefile.am,
armulator/bsp_specs, armulator/configure.ac, armulator/preinstall.am,
armulator/clock/clockdrv.c, armulator/console/console-io.c,
armulator/console/mon-syscalls.S, armulator/include/.cvsignore,
armulator/include/bsp.h, armulator/include/tm27.h,
armulator/start/start.S, armulator/startup/bspstart.c,
armulator/startup/libcfunc.c, armulator/startup/linkcmds,
armulator/startup/swi.h, armulator/startup/syscalls.c,
armulator/startup/trap.S: Removed.
* libmd/.cvsignore: New file.
* shttpd/defs.h: Eliminate my_strncasecmp.
* shttpd/string.c: Eliminate my_strncasecmp.
* wrapup/Makefile.am: Pickup ../libmd/libmd.a.
* pppd/Makefile.am: Reflect moving out md*.
* pppd/md4.h, pppd/md4.c, pppd/md5.c, pppd/md5.h: Remove (moved to
libmd).
