Delete _Thread_Evaluate_is_dispatch_needed().
Use _Thread_Dispatch_is_enabled() in rtems_task_mode() instead of the
system state to determine if a thread dispatch is allowed. Signales are
now delivered in rtems_task_mode() even if preemption is disabled. This
is in line with rtems_signal_send().
Delete _Thread_Dispatch_in_critical_section() and
_Thread_Is_dispatching_enabled().
We must obtain the processor ID after interrupts are disabled since a
non-optimizing compiler may store the value on the stack and read it
back.
Add and use _Per_CPU_Lock_release().
This avoids a race condition on SMP configurations.
Returning this state in the return value leads to race conditions on
SMP. The inactive state notification must be inside the critical
section.
Use interrupt disable/enable to protect the complete refill state
change. This avoids race conditions for the task driven configuration
and a later SMP support.
Interrupt locks are low-level lock to protect critical sections accessed
by threads and interrupt service routines.
Add and use _Objects_Put_without_thread_dispatch(). These two functions
pair with the _Objects_Get() function. This helps to introduce object
specific SMP locks to avoid lock contention.
Provide SMP support. The ISR disable/enable is not enough to ensure
mutual exclusion for SMP configurations.
Align ISR disable/enable sequence in _Objects_Get_isr_disable() with
thread dispatch disable/enable sequence in _Objects_Get().
Move thread dispatch declarations and inline functions to new header
<rtems/score/threaddispatch.h> to make it independent of the
Thread_Control structure. This avoids a cyclic dependency in case
thread dispatch functions are used for the object implementation.
The _Thread_Initialize() function has nothing to do with thread
dispatching it simply initializes the thread control.
This prevents a lock order reversal.
Test handling of file names and directory names according to Microsofts
specification for the FAT file system. Tests for compatibility with a
genuine MS Windows FAT file system have been added.
Test handling of file names and directory names according to Microsofts specification
for the FAT file system. Tests for multibyte file names and directory names have been added.
Add optional conversion methods for multibyte strings. With these
conversions which make use of iconv and utf8proc it becomes possible to
use strings from any language (Czech, Chinese, Arabian, Hebrew, Corean,
...) for file names and directory names.
NOTE: Iconv support must be activated during the build of the tool chain
for these conversion methods (options --enable-newlib-iconv
--enable-newlib-iconv-encodings=[ENCODINGS_YOU_WANT]). Alternatively
you can provide your own conversion methods.
utf8proc is a library for processing UTF-8 encoded Unicode strings.
Some features are Unicode normalization, stripping of default ignorable characters, case folding and detection of grapheme cluster boundaries.
For now utf8proc is intended for normalizing and folding strings for comparison purposes within the UTF-8 support of the FAT file system.
This test will call interface methods of library utf8proc in order to make sure they compiled and linked ok.
The library is third party, thus it should be sufficient for us to make sure we can build it correctly.
utf8proc is a small library for processing UTF-8 encoded Unicode strings.
For the time beeing utf8proc is intended to be used for normalizing and folding UTF-8 strings
for comparison purposes when adding UTF-8 support to the FAT file system.
specification for the FAT file system. So far tested only for the
default character set (code page 850).
User interface and backwards compatibility for UTF-8 support in the FAT
file system. Purpose of UTF-8 support is to permit file names and
directory names with characters from all kinds of languages (Czech,
Chinese, Arabian, Hebrew, Korean, ...). This commit does not yet
support multibyte characters. It only contains the user interface and
the backwards compatibility.
