* | 2008-09-09 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-09 | 2 | -41/+37 |
| | | | | * README.configure: Updated list of BSPs. | ||||
* | Spacing. | Joel Sherrill | 2008-09-09 | 1 | -6/+0 |
* | added printk support | Thomas Doerfler | 2008-09-09 | 8 | -1104/+380 |
| | | | | | added port init, added phy support init mmu | ||||
* | minor additions | Thomas Doerfler | 2008-09-09 | 4 | -3/+30 |
| | | | | i2c-driver: wait, 'til stop executed | ||||
* | 2008-09-09 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-09 | 1 | -0/+2 |
| | | | | | * user/chains.t, user/conf.t, user/object.t, user/userext.t: More "bool" cleanup. | ||||
* | More "bool" cleanup. | Ralf Corsepius | 2008-09-09 | 4 | -35/+35 |
* | 2008-09-09 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-09 | 1 | -0/+5 |
| | | | | | * bsp_howto/ata.t, bsp_howto/rtc.t, networking/networkapp.t, user/chains.t, user/stackchk.t: Convert to "bool". | ||||
* | Convert to "bool". | Ralf Corsepius | 2008-09-09 | 5 | -41/+41 |
* | 2008-09-09 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-09 | 1 | -0/+6 |
| | | | | | | * user/datatypes.t: Add deprecation notices to "rtems_boolean", "rtems_single", "rtems_double". * user/intr.t, user/userext.t: Convert to "bool". | ||||
* | Add deprecation notices to "rtems_boolean", "rtems_single", "rtems_double". | Ralf Corsepius | 2008-09-09 | 1 | -0/+6 |
* | Convert to "bool". | Ralf Corsepius | 2008-09-09 | 2 | -2/+2 |
* | 2008-09-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-08 | 3 | -2/+11 |
| | | | | | | | * sapi/include/confdefs.h: Add debug information for per task allocations. * score/src/objectextendinformation.c: Do not allocate memory for name tables because we do not use name tables any longer. | ||||
* | 2008-09-08 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-08 | 1 | -0/+4 |
| | | | | * i2c/i2c.c: Remove rtems_boolean having crept in again. | ||||
* | Remove rtems_boolean having crept in again. | Ralf Corsepius | 2008-09-08 | 1 | -1/+1 |
* | 2008-09-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-08 | 3 | -2/+8 |
| | | | | * tm09/system.h, tm09/task1.c: Account for message buffer memory. | ||||
* | 2008-09-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-08 | 2 | -1/+5 |
| | | | | * runtest.in: Work on .exe and .ralf files. | ||||
| | | | | * runtest-bottom: Work on .exe and .ralf files. | ||||
* | 2008-09-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-08 | 2 | -3/+6 |
| | | | | | * score/src/threadinitialize.c: _Stack_Ensure_minimum was being called here and in _Thread_Stack_Allocate. | ||||
* | 2008-09-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-08 | 2 | -4/+14 |
| | | | | * runtest.in: Update to support .exe or .ralf extension. | ||||
* | 2008-09-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-08 | 4 | -5/+11 |
| | | | | | * mpc8xx/clock/clock.c, mpc8xx/console-generic/console-generic.c, mpc8xx/timer/timer.c: Fix nested extern declaration warnings. | ||||
* | 2008-09-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-08 | 3 | -0/+16 |
| | | | | * .cvsignore, include/.cvsignore: New files. | ||||
* | 2008-09-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-08 | 2 | -0/+6 |
| | | | | * acinclude.m4: Add tqm8xx. | ||||
* | added missing files, fixed some minors | Thomas Doerfler | 2008-09-08 | 6 | -21/+107 |
* | 2008-09-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-08 | 6 | -15/+20 |
| | | | | | * mp09/recvmsg.c, mp09/task1.c, mp10/task1.c, mp13/task1.c, mp14/msgtask1.c: Correct types to eliminate warnings. | ||||
* | 2008-09-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-08 | 17 | -40/+50 |
| | | | | | | | | | | | | * libcsupport/include/rtems/libio_.h, libcsupport/src/libio_sockets.c, libfs/src/dosfs/fat.h, libfs/src/dosfs/msdos.h, libfs/src/imfs/deviceio.c, libmisc/monitor/mon-monitor.c, libmisc/monitor/mon-object.c, libmisc/monitor/mon-symbols.c, libmisc/monitor/monitor.h, libmisc/stackchk/internal.h, rtems/inline/rtems/rtems/part.inl, score/include/rtems/system.h, score/include/rtems/score/bitfield.h, score/src/mpci.c, score/src/objectextendinformation.c, score/src/threadmp.c: Remove extraneous spaces. | ||||
* | 2008-09-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-08 | 10 | -19/+39 |
| | | | | * cpu.c: Remove extraneous spaces. | ||||
* | 2008-09-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-08 | 6 | -3/+15 |
| | | | | * rtems/score/cpu.h: Remove extraneous spaces. | ||||
* | 2008-09-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-08 | 3 | -4/+8 |
| | | | | * cpu.c, rtems/score/cpu.h: Remove extraneous spaces. | ||||
* | 2008-09-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-08 | 2 | -25/+15 |
| | | | | | * bsp_howto/timer.t: Update documentation to reflect Timer Driver renaming. | ||||
* | 2008-09-08 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-09-08 | 1 | -0/+4 |
| | | | | * ChangeLog: New file. | ||||
* | 2008-09-08 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-09-08 | 2 | -1/+5 |
| | | | | * AUTHORS: Convert to UNIX CR/LF style. | ||||
* | 2008-09-08 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-09-08 | 4 | -424/+428 |
| | | | | * AUTHORS, COPYING, README: Convert to UNIX CR/LF style. | ||||
* | 2008-09-08 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-09-08 | 2 | -31/+137 |
| | | | | | * mcf548x/include/Freescale_license.txt: Convert to UNIX CR/LF style, eliminate characters with 8th bit set. | ||||
* | 2008-09-08 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-09-08 | 3 | -83/+87 |
| | | | | * sp34/sp34.scn, sp35/sp35.scn: Convert to UNIX CR/LF style. | ||||
* | Derive time base clicks from bus frequency | Thomas Doerfler | 2008-09-08 | 1 | -1/+1 |
* | Add --enable-newlib-io-c99-formats. | Ralf Corsepius | 2008-09-08 | 1 | -0/+3 |
* | added BSP for tqm8xx based boards | Thomas Doerfler | 2008-09-08 | 3 | -0/+49 |
* | added new BSP for powerpc/tqm8xx boards | Thomas Doerfler | 2008-09-08 | 4 | -1/+12 |
* | added new bsp for tqm8xx | Thomas Doerfler | 2008-09-08 | 1 | -0/+4 |
* | some mpc8xx maintenance | Thomas Doerfler | 2008-09-08 | 1 | -0/+7 |
* | maintenance | Thomas Doerfler | 2008-09-08 | 2 | -2/+1 |
* | added new BSP for TQM8xx boards | Thomas Doerfler | 2008-09-08 | 26 | -0/+7160 |
* | added support for flexible PLL in MPC866 and friends | Thomas Doerfler | 2008-09-08 | 1 | -4/+38 |
* | corrected parameters for done signalling | Thomas Doerfler | 2008-09-08 | 2 | -7/+7 |
* | corrected parameters inside i2c driver for done signalling | Thomas Doerfler | 2008-09-08 | 4 | -17/+28 |
* | corrected parameters in i2c driver for done signalling | Thomas Doerfler | 2008-09-08 | 7 | -30/+59 |
| | | | | updated mscan CAN driver | ||||
| | | | | * mcf548x/include/mcf548x.h: Convert to Unix file format. | ||||
* | Convert to Unix file format. | Ralf Corsepius | 2008-09-08 | 2 | -4109/+4109 |
| | | | | * libchip/ide/ata.h: Convert to Unix file format. | ||||
* | 2008-09-08 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-08 | 1 | -0/+5 |
| | | | | | * pppd/auth.c, pppd/ccp.c, pppd/chap.c, pppd/ipcp.c, pppd/lcp.c, pppd/options.c, pppd/upap.c: Add missing initializers. |
