* | 2008-11-20 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-11-20 | 2 | -0/+24 |
| | | | | * custom/avrtest.cfg: New file. | ||||
* | 2008-11-20 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-11-20 | 2 | -3/+11 |
| | | | | | | PR 1306/cpukit * posix/inline/rtems/posix/priority.inl: Eliminate hard coded numbers in favor of existing macros. | ||||
* | 2008-11-20 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-11-20 | 3 | -1/+29 |
| | | | | | * posix/Makefile.am: Add dummy vfork() implementation. * posix/src/vfork.c: New file. | ||||
* | 2008-11-20 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-11-20 | 2 | -1/+5 |
| | | | | * README: Fix typo. | ||||
* | 2008-11-20 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-11-20 | 4 | -0/+49 |
| | | | | * ChangeLog, Makefile.am, acinclude.m4, configure.ac: New files. | ||||
* | 2008-11-20 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-11-20 | 16 | -0/+908 |
| | | | | | | | * .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac, preinstall.am, console/console-io.c, include/.cvsignore, include/bsp.h, start/start.S, startup/linkcmds, tools/.cvsignore, tools/Makefile.am, tools/configure.ac, tools/runtest.in: New files. | ||||
* | 2008-11-20 Daron Chabot <daronchabot@gmail.com> | Joel Sherrill | 2008-11-20 | 2 | -1/+6 |
| | | | | | | PR 1337/bsps * custom/pc386.cfg: Stripping .rodata section produces unusable executables for the i386-rtems target. | ||||
* | 2008-11-20 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-11-20 | 3 | -7/+218 |
| | | | | | PR 1339/Ada * rtems.adb, rtems.ads: Re-add IO Manager to Ada binding. | ||||
* | 2008-11-20 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-11-20 | 2 | -12/+60 |
| | | | | | PR 1339/Ada * user/io.t: Re-add IO Manager to Ada binding. | ||||
* | Regenerate. | Ralf Corsepius | 2008-11-19 | 12 | -55/+60 |
* | Add NEWLIB_PKGVERS. | Ralf Corsepius | 2008-11-19 | 2 | -0/+2 |
* | Preps for newlib-cvs. | Ralf Corsepius | 2008-11-19 | 12 | -12/+24 |
| | | | | Bump GCC_RPMREL. | ||||
* | Update to gcc-core-4.3.2-rtems4.10-20081119.diff. | Ralf Corsepius | 2008-11-19 | 12 | -43/+36 |
| | | | | Preps for newlib-cvs. | ||||
* | Fix errors having crept in in previous versions. | Ralf Corsepius | 2008-11-19 | 1 | -0/+245 |
* | New. | Ralf Corsepius | 2008-11-19 | 1 | -0/+297 |
| | | | | Rebase newlib-*-rtems4.10 patch against newlib-cvs. | ||||
* | Regenerate. | Ralf Corsepius | 2008-11-19 | 1 | -1/+48 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2008-11-19 | 1 | -2/+2 |
| | | | | Activate c++. | ||||
* | Update. | Ralf Corsepius | 2008-11-19 | 6 | -29/+57 |
* | include/bsp.h, include/hwreg_vals.h, network/network.c: | Thomas Doerfler | 2008-11-18 | 4 | -10/+25 |
| | | | | | correct some init values for HSC_CM01 boards change strategy to determine MAC address | ||||
* | libchip/serial/ns16550.c: Transmit the character in the polled write | Thomas Doerfler | 2008-11-18 | 2 | -34/+34 |
| | | | | function within a critical section for printk() compatibility. | ||||
* | console/console.c: Update for new NS16550 polled write function | Thomas Doerfler | 2008-11-18 | 2 | -5/+4 |
* | 2008-11-13 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-11-13 | 2 | -0/+40 |
| | | | | | | PR 1336/cpukit * sapi/inline/rtems/chain.inl: Add rtems_chain_prepend_unprotected and rtems_chain_append_unprotected. | ||||
* | 2008-11-13 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-11-13 | 3 | -6/+80 |
| | | | | | | PR 1336/cpukit * user/chains.t, user/dirstat.texi: Add rtems_chain_prepend_unprotected and rtems_chain_append_unprotected. | ||||
* | 2008-11-12 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-11-12 | 3 | -1/+57 |
| | | | | | * libcsupport/Makefile.am: Add getrusage(). * libcsupport/src/getrusage.c: New file. | ||||
* | 2008-11-12 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-11-12 | 2 | -2/+6 |
| | | | | * score/src/timespecaddto.c: Fix typo. | ||||
* | 2008-11-12 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-11-12 | 2 | -0/+11 |
| | | | | | * startup/bspstart.c: Add bsp_clicks_per_usec variable which is used by shared code. | ||||
* | Regenerate. | Ralf Corsepius | 2008-11-10 | 12 | -24/+36 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2008-11-10 | 12 | -12/+12 |
* | Upgrade to cygwin-1.5.25-14. | Ralf Corsepius | 2008-11-10 | 1 | -4/+4 |
| | | | | Upgrade to w32api-3.12-1. | ||||
* | Suppress debug_install-post for noarch. | Ralf Corsepius | 2008-11-10 | 1 | -1/+2 |
* | 2008-11-07 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-11-07 | 2 | -2/+6 |
| | | | | * user/concepts.t: Use 32 bit version centered. | ||||
* | 2008-11-07 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-11-07 | 2 | -3/+13 |
| | | | | | * ada_user/Makefile.am: Make Ada manual build again after adding figure. | ||||
* | 2008-11-07 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-11-07 | 2 | -3/+8 |
| | | | | | * libcsupport/src/ttyname.c: Change third parameter of ttyname to be size_t instead of int. | ||||
* | 2008-11-07 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-11-07 | 9 | -75/+19510 |
| | | | | | | | | PR 1334/doc * user/Makefile.am, user/concepts.t, user/init.t, user/overview.t, user/part.t, user/task.t: Correct typos and correctly document 4 parts of 32-bit object id. * user/ObjectId-32Bits.eps, user/ObjectId-32Bits.png: New files. | ||||
* | Regenerate. | Ralf Corsepius | 2008-11-07 | 12 | -12/+60 |
* | Add %{gcclib}/@tool_target@/%{gcc_version}/include-fixed. | Ralf Corsepius | 2008-11-07 | 1 | -0/+4 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2008-11-07 | 12 | -12/+12 |
* | 2008-11-05 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-11-05 | 2 | -1/+9 |
| | | | | * librpc/src/xdr/xdr_float.c: Add M32C, M32R, and Blackfin. | ||||
* | 2008-11-05 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-11-05 | 2 | -2/+12 |
| | | | | * score/src/threadhandler.c: M32R uses different name for init. | ||||
* | 2008-11-05 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-11-05 | 3 | -3/+37 |
| | | | | | | * posix/Makefile.am: Add _execve() so we can use newlib posix support directory and eliminate code in RTEMS. * posix/src/_execve.c: New file. | ||||
* | Update. | Ralf Corsepius | 2008-11-05 | 36 | -84/+540 |
* | Filter find-debuginfo.sh not to mistreat foreign binaries. | Ralf Corsepius | 2008-11-05 | 1 | -0/+23 |
* | Upgrade to binutils-2.19, gcc-4.2.4. | Ralf Corsepius | 2008-11-05 | 2 | -4/+4 |
* | Upgrade to binutils-2.19. | Ralf Corsepius | 2008-11-05 | 2 | -10/+4 |
* | Bump version. | Ralf Corsepius | 2008-11-05 | 1 | -1/+1 |
* | Silence unpackaging objc. | Ralf Corsepius | 2008-11-04 | 1 | -1/+1 |
* | Filter out -std=gnu99 from CFLAGS. | Ralf Corsepius | 2008-11-04 | 1 | -1/+2 |
* | 2008-11-03 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2008-11-03 | 2 | -8/+14 |
| | | | | | PR 1332: call BSP_uart_termios_set()/BSP_uart_intr_ctrl() only from 'firstOpen' and only if this is a serial console. | ||||
* | 2008-11-03 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2008-11-03 | 1 | -9/+16 |
* | 2008-11-03 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2008-11-03 | 1 | -1/+1 |
| | | | | | * shared/startup/linkcmds: increased size of CODE memory area. |
