* | 2009-10-01 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-10-01 | 2 | -0/+10 |
| | | | | | * aclocal/bsp-alias.m4: Add BSP for GDB ARM simulator so we can easily experiment with and debug different ARM architectural variations. | ||||
* | 2009-10-01 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-10-01 | 2 | -0/+7 |
| | | | | | * acinclude.m4: Add BSP for GDB ARM simulator so we can easily experiment with and debug different ARM architectural variations. | ||||
* | 2009-10-01 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-10-01 | 19 | -0/+2059 |
| | | | | | | | | | * .cvsignore, ChangeLog, Makefile.am, bsp_specs, configure.ac, preinstall.am, console/.cvsignore, console/console-io.c, include/.cvsignore, include/bsp.h, include/irq.h, include/swi.h, start/.cvsignore, start/start.S, startup/.cvsignore, startup/bspreset.c, startup/bspstart.c, startup/linkcmds, startup/syscalls.c: New files. | ||||
| | | | | * rtems/score/arm.h: Recognize ARMv7A. | ||||
* | 2009-10-01 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-10-01 | 7 | -0/+114 |
| | | | | | | * Makefile.am: Add new BSP variants for ARM simulator in GDB. * custom/arm1136jfs.cfg, custom/arm1136js.cfg, custom/arm7tdmi.cfg, custom/arm920.cfg, custom/armcortexa9.cfg: New files. | ||||
* | 2009-10-01 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-10-01 | 2 | -19/+12 |
| | | | | | * libchip/ide/ata.c: Use simple vectored CPU macro to select interrupt model. | ||||
| | | | | * rtems/score/arm.h: Recognize ARMv6J as needed by arm1136 variants. | ||||
* | 2009-10-01 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-01 | 2 | -12/+17 |
| | | | | | PR 1445/BSPs * shared/pci/pcibios.c: Rename indirect_pci_* into BSP_pci_*. | ||||
* | 2009-10-01 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-01 | 4 | -36/+48 |
| | | | | | | PR 1445/BSPs * pci/pci.c: Rename pci_[read|write]_config* functions into BSP_pci_[read|write]_config* and make them static. | ||||
* | 2009-10-01 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-01 | 1 | -0/+6 |
| | | | | | | PR 1445/bsps * include/rtems/pci.h: Make pci_[read|write]_config* static inline, again. | ||||
* | Make pci_[read|write]_config* static inline, again. | Ralf Corsepius | 2009-10-01 | 1 | -6/+6 |
* | 2009-10-01 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-01 | 2 | -1/+5 |
| | | | | * include/rtems/pci.h: Add another missing prototype. | ||||
* | 2009-10-01 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-01 | 1 | -0/+5 |
| | | | | | * termios01/init.c, termios01/termios_testdriver.c: Reflect changes to termios. | ||||
* | Reflect changes to termios. | Ralf Corsepius | 2009-10-01 | 2 | -12/+12 |
* | Regenerate. | Ralf Corsepius | 2009-10-01 | 13 | -26/+26 |
* | Fix typo in previous patch. | Ralf Corsepius | 2009-10-01 | 13 | -13/+13 |
* | Regenerate. | Ralf Corsepius | 2009-10-01 | 13 | -52/+52 |
* | GDB_RVERS = 6.8.92. | Ralf Corsepius | 2009-10-01 | 13 | -26/+26 |
* | gdb-6.8.92-rtems4.10-20091001.diff | Ralf Corsepius | 2009-10-01 | 13 | -13/+13 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2009-10-01 | 27 | -105/+279 |
* | Rebase patch against gdb-6.8.92. | Ralf Corsepius | 2009-10-01 | 1 | -0/+666 |
* | 2009-09-30 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-10-01 | 2 | -0/+6 |
| | | | | * include/bsp.h: BSP does not have much memory. Limited to BIOS space. | ||||
* | 2009-09-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-09-30 | 2 | -1/+5 |
| | | | | * include/rtems/pci.h: Add missing prototype. | ||||
* | 2009-09-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-09-30 | 1 | -0/+8 |
| | | | | | | | | * libcsupport/src/fstat.c, libcsupport/src/fcntl.c, libcsupport/src/calloc.c, libcsupport/src/isatty_r.c, libcsupport/src/issetugid.c, libcsupport/src/lseek.c, libcsupport/src/read.c, libcsupport/src/getpid.c: Rework autoconf defines. | ||||
* | Rework autoconf defines. | Ralf Corsepius | 2009-09-30 | 8 | -7/+9 |
* | 2009-09-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-09-30 | 2 | -10/+8 |
| | | | | | * libcsupport/src/_rename_r.c: Rework autoconf defines. Remove unused includes. | ||||
* | 2009-09-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-09-30 | 2 | -14/+12 |
| | | | | | * libcsupport/src/__gettod.c: Rework autoconf defines. Eliminate RTEMS_UNIX. | ||||
* | 2009-09-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-09-30 | 1 | -0/+2 |
| | | | | | * libcsupport/src/_calloc_r.c, libcsupport/src/_realloc_r.c: Rework autoconf defines. | ||||
* | Rework autoconf defines. | Ralf Corsepius | 2009-09-30 | 4 | -4/+4 |
| | | | | | * libcsupport/src/open.c, libcsupport/src/close.c: Rework autoconf defines. | ||||
* | 2009-09-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-09-30 | 1 | -0/+1 |
| | | | | * libcsupport/src/tcflow.c: Remove unused includes. | ||||
* | Remove unused includes. | Ralf Corsepius | 2009-09-30 | 1 | -8/+1 |
| | | | | * libcsupport/src/__sbrk.c: Eliminate RTEMS_UNIX. | ||||
* | Eliminate RTEMS_UNIX. | Ralf Corsepius | 2009-09-30 | 1 | -2/+1 |
| | | | | | * libcsupport/src/_free_r.c, libcsupport/src/_malloc_r.c: Rework autoconf defines. | ||||
* | Rework autoconf defines. | Ralf Corsepius | 2009-09-30 | 2 | -2/+2 |
| | | | | | * libcsupport/src/malloc_boundary.c: Comment out checkMallocArena (unused). | ||||
* | Comment out checkMallocArena (unused). | Ralf Corsepius | 2009-09-30 | 1 | -2/+5 |
* | 2009-09-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-09-30 | 2 | -2/+4 |
| | | | | * libcsupport/src/__assert.c: Rework autoconf defines. | ||||
* | 2009-09-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-09-30 | 2 | -2/+3 |
| | | | | | * libcsupport/src/__brk.c: Eliminate RTEMS_UNIX. Remove unused includes. | ||||
* | Remove unused includes. | Ralf Corsepius | 2009-09-30 | 2 | -13/+2 |
| | | | | * libcsupport/src/getgroups.c: Remove unused includes. | ||||
* | Remove stray whitespace. | Ralf Corsepius | 2009-09-30 | 1 | -1/+0 |
| | | | | * libcsupport/src/setpgid.c: Remove unused includes. | ||||
* | 2009-09-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-09-30 | 1 | -0/+4 |
| | | | | * libcsupport/src/malloc_p.h: Remove #include <inttypes.h>. | ||||
* | Remove #include <inttypes.h>. | Ralf Corsepius | 2009-09-30 | 1 | -1/+0 |
* | 2009-09-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-09-30 | 1 | -0/+5 |
| | | | | | * mongoosev/duart/mg5uart.c: Reflect termios_baud_to_number having been renamed to rtems_termios_baud_to_number. | ||||
* | 2009-09-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-09-30 | 2 | -0/+5 |
| | | | | * console/console.c: Include <rtems/termiostypes.h>. | ||||
* | 2009-09-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-09-30 | 2 | -2/+8 |
| | | | | | * console/console.c: Include <rtems/termiostypes.h>. Add missing prototype. | ||||
* | 2009-09-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-09-30 | 4 | -5/+10 |
| | | | | | | * libchip/serial/z85c30.c, libchip/serial/ns16550.c, libchip/serial/mc68681.c: Reflect termios_baud_to_number having been renamed to rtems_termios_baud_to_number. |
