* common/common.add.in: Remove Vendor:. Remove Distribution:.
* Makefile.am, autotools/Makefile.am, binutils/Makefile.am
cpukit/Makefile.am, gccnewlib/Makefile.am, gdb/Makefile.am
rtems/Makefile.am: Rename *.spec into @rpmprefix@*.spec.
* binutils/base-binutils.add, binutils/binutils.add,
binutils/target-binutils.add, common/common.add.in,
cpukit/rtems-cpukit.add, cpukit/target-cpukit.add,
gccnewlib/base-g77.add, gccnewlib/base-gcc.add,
gccnewlib/base-gcj.add, gccnewlib/base-gfortran.add,
gccnewlib/base-gnat.add, gccnewlib/gccnewlib.add,
gccnewlib/target-c++.add, gccnewlib/target-g77.add,
gccnewlib/target-gcc.add, gccnewlib/target-gcj.add,
gccnewlib/target-gfortran.add, gccnewlib/target-gnat.add,
gccnewlib/target-libc.add, gccnewlib/target-objc.add,
gdb/base-gdb.add, gdb/gdb.add, gdb/target-gdb.add,
rtemsdoc/rtemsdoc.add, rtemsdoc/supplement.add.in,
rtemsdoc/templ.add.in, rtems/rtems-source.add:
Replace %{rpmprefix} with @rpmprefix@.
* cpukit/mkspec.in, rtems/mkspec.in: Propagate @rpmprefi@.
* gccnewlib/Makefile.am: Use target-libc.add
* gccnewlib/gccnewlib.add, gccnewlib/target-gcc.add,
gccnewlib/target-libc.add: Misc. fixes.
PR 820/rtems
* score/inline/rtems/score/coremsg.inl,
score/macros/rtems/score/coremsg.inl, score/src/coremsginsert.c:
Increment of pending message count should be atomic with insertion on
the pending message chain. Determination of the need to call the
notification handler should also be in this atomic section of code.
PR 628/rtems
* psx04/init.c, psx04/psx04.scn: Update tests to reflect a signal of 0
being an error.
PR 796/rtems
* posix/src/semtimedwait.c: sem_timedwait is supposed to use absolute
time for timeout specification. This patch is a modified version of
the one suggested by Peter Dufault.
PR 804
* sapi/include/confdefs.h: Memory for POSIX timers not accounted for.
Patch adapted from edit comment in PR filed.
* gdb/gdb.add: Remove Packager:.
* gccnewlib/base-g77.add, gccnewlib/base-gcc.add,
gccnewlib/base-gcj.add, gccnewlib/target-c++.add,
gccnewlib/target-g77.add, gccnewlib/target-gcc.add,
gccnewlib/target-gcj.add, gccnewlib/target-gfortran.add,
gccnewlib/target-gnat.add, gccnewlib/target-objc.add:
Switch to using %gcc_version.
* binutils/binutils.add: Remove Packager:.
* binutils/target-binutils.add: Further adaptations to /usr.
* gccnewlib/target-c++.add, gccnewlib/target-g77.add,
Fix directory ownerships.
* timer/timer.c: Enhance to use either interupt-based timer
functions on older CPUs or to use TSC-based timer functions on
more recent (Pentium and above) CPUs. The decision is made in
Timer_initialize function when it is called for the first time
based on a result obtained from cpuid instruction during the BSP
initialization phase. During the first call, there are also late
bindings to the implementation functions initialized to
appropriate values.
* gccnewlib/target-libc.add: New.
PR 819/filesystem
* libcsupport/src/ttyname_r.c: Remove.
* libcsupport/src/ttyname.c: Partial update from FreeBSD.
* libcsupport/Makefile.am: Reflect changes above.
* gccnewlib/target-gcc.add: Add Requires/Provides *-newlib/*-libc.
* gccnewlib/gccnewlib.add: Add Requires/Provides *-newlib/*-libc.
gccnewlib/gccnewlib.add, gccnewlib/target-c++.add,
gccnewlib/target-g77.add, gccnewlib/target-gcj.add,
gccnewlib/target-objc.add: Use gccnewlib_version.
Cosmetics. Minor cleanups.
* gccnewlib/base-gcc.add: Remove %_includedir.
* gccnewlib/base-g77.add: Remove %_mandir.
Remove %{gcc_target}-g77.1.
* gccnewlib/base-gfortran.add: Remove %_mandir.
Remove %{gcc_target}-gfortran.1.
* gccnewlib/gccnewlib.add: Remove Packager:.
Add %gccnewlib_version.
* gccnewlib/target-c++.add: Remove %_bindir.
* gccnewlib/target-g77.add: Add %{gcc_target}-g77.1.
* gccnewlib/target-gcj.add: Remove %_bindir.
Remove %_mandir.
* gccnewlib/target-gfortran.add: Remove %_bindir.
Add %{gcc_target}-gfortran.1.
* gccnewlib/target-gnat.add: Remove %_bindir.
Remove %_mandir.
* setup.def, gdb/gdb.add: Use DESTDIR as override with gdb 6.3.
* gccnewlib/gccnewlib.add: Remove vxaddr2line.
Further minor cleanup.
* libchip/network/if_fxp.c, libchip/network/if_dc.c,
libchip/network/dec21140.c: Remove initialization of PCI bus.
