* networking/decdriver.t: Make PCI initialize function part of the
unified PCI API as pci_initialize().
* libchip/network/dec21140.c, libchip/network/if_fxp.c: Make PCI
initialize function part of the unified PCI API as pci_initialize().
* vmeUniverse/README.porting, vmeUniverse/vmeUniverse.c: Make PCI
* pci/pci.c, pci/pcifinddevice.c, startup/bspstart.c: Make PCI
* include/bsp.h, pci/pci.c, startup/bspstart.c: Make PCI initialize
* pci/pci.c, pci/pci.h, startup/bspstart.c: Make PCI initialize
* shared/pci/pcibios.c, shared/pci/pcibios.h: Make PCI initialize
* include/rtems/pci.h: Clean up and reformatting. Make PCI initialize
function part of the unified PCI API.
* configure.ac: Check for newlib with stdint.h/inttypes.h.
* Makefile.am: Conditionally use external stdint.h/inttypes.h for
newlib.
* custom/mpc8260ads.cfg : Remove PPC_ASM, PPC_ABI.
* custom/mvme5500.cfg: Remove CFLAGS_PROFILE_V.
Remove -Wa,-m7450.
* acinclude.m4: Remove arm_bare_bsp.
PR bsps/771
* configure.ac: Remove reference to arm_bare_bsp in
AC_CONFIG_SRCDIR. Use ../arm instead.
PR bsps/771
* custom/jmr3904.cfg: arm_bare_bsp obsoleted.
* custom/arm_bare_bsp.cfg: Removed.
* arm_bare_bsp/.cvsignore, arm_bare_bsp/ChangeLog,
arm_bare_bsp/Makefile.am, arm_bare_bsp/bsp_specs,
arm_bare_bsp/configure.ac, arm_bare_bsp/clock/clockdrv.c,
arm_bare_bsp/include/.cvsignore, arm_bare_bsp/include/bsp.h,
arm_bare_bsp/include/registers.h, arm_bare_bsp/include/tm27.h,
arm_bare_bsp/irq/bsp_irq_asm.S, arm_bare_bsp/irq/bsp_irq_init.c,
arm_bare_bsp/irq/irq.c, arm_bare_bsp/irq/irq.h,
arm_bare_bsp/start/start.S, arm_bare_bsp/startup/bspstart.c,
arm_bare_bsp/startup/exit.c, arm_bare_bsp/startup/linkcmds: Removed.
* au1x00/include/au1x00.h: Converted types to C99 types.
PR 751/bsps
* startup/linkcmds: Cleanup.
* network/network.c: Added hardware initialization
code.
* at91rm9200/include/at91rm9200_emac.h: Cleanup.
* Makefile.am, configure.ac: New CPU.
* shared/interrupts/installisrentries.c,
shared/interrupts/isr_entries.S: Added CPU32 support.
* au1x00/Makefile.am, au1x00/include/au1x00.h,
au1x00/vectorisrs/maxvectors.c, au1x00/vectorisrs/vectorisrs.c: New CPU.
* acinclude.m4: Added csb350 to list of BSPs.
* csb350/Makefile.am, csb350/README, csb350/bsp_specs,
csb350/configure.ac, csb350/times, csb350/clock/clockdrv.c,
csb350/console/console-io.c, csb350/include/bsp.h,
csb350/include/tm27.h, csb350/network/network.c, csb350/start/regs.S,
csb350/start/start.S, csb350/startup/bspclean.c,
csb350/startup/bspstart.c, csb350/startup/linkcmds,
csb350/timer/timer.c: New BSP.
* custom/csb337.cfg: Cleanup.
* custom/csb350.cfg: New BSP.
* gcc3newlib/gccnewlib.add, gcc3newlib/mkspec.in, setup.def:
Add gcc_suffix. Add newlib_suffix.
* aclocal/rtems-top.m4: Rework rtems_updir handling to work around
ash cd'ing to '/' for 'cd .//'.
* rtems/score/powerpc.h: Add "defined(mpc7400) || defined(mpc7450)
|| defined(mpc7455)" to altivec (gcc-3.2.x compatibility).
PR 764/networking
* libnetworking/sys/sysctl.h: include <rtems/stdint.h>.
* score/inline/rtems/score/address.inl,
score/inline/rtems/score/chain.inl,
score/inline/rtems/score/coremsg.inl,
score/inline/rtems/score/coremutex.inl,
score/inline/rtems/score/coresem.inl,
score/inline/rtems/score/heap.inl,
score/inline/rtems/score/isr.inl,
score/inline/rtems/score/mppkt.inl,
score/inline/rtems/score/object.inl,
score/inline/rtems/score/objectmp.inl,
score/inline/rtems/score/priority.inl,
score/inline/rtems/score/stack.inl,
score/inline/rtems/score/states.inl,
score/inline/rtems/score/sysstate.inl,
score/inline/rtems/score/thread.inl,
score/inline/rtems/score/threadmp.inl,
score/inline/rtems/score/tod.inl,
score/inline/rtems/score/tqdata.inl,
score/inline/rtems/score/userext.inl,
score/inline/rtems/score/watchdog.inl,
score/inline/rtems/score/wkspace.inl,
score/macros/rtems/score/address.inl,
score/macros/rtems/score/chain.inl,
score/macros/rtems/score/coremsg.inl,
score/macros/rtems/score/coremutex.inl,
score/macros/rtems/score/coresem.inl,
score/macros/rtems/score/heap.inl,
score/macros/rtems/score/isr.inl,
score/macros/rtems/score/mppkt.inl,
score/macros/rtems/score/object.inl,
score/macros/rtems/score/objectmp.inl,
score/macros/rtems/score/priority.inl,
score/macros/rtems/score/stack.inl,
score/macros/rtems/score/states.inl,
score/macros/rtems/score/sysstate.inl,
score/macros/rtems/score/thread.inl,
score/macros/rtems/score/threadmp.inl,
score/macros/rtems/score/tod.inl,
score/macros/rtems/score/tqdata.inl,
score/macros/rtems/score/userext.inl,
score/macros/rtems/score/watchdog.inl,
score/macros/rtems/score/wkspace.inl: New header guards.
* rtems/inline/rtems/rtems/asr.inl,
rtems/inline/rtems/rtems/attr.inl,
rtems/inline/rtems/rtems/dpmem.inl,
rtems/inline/rtems/rtems/event.inl,
rtems/inline/rtems/rtems/eventset.inl,
rtems/inline/rtems/rtems/message.inl,
rtems/inline/rtems/rtems/modes.inl,
rtems/inline/rtems/rtems/options.inl,
rtems/inline/rtems/rtems/part.inl,
rtems/inline/rtems/rtems/ratemon.inl,
rtems/inline/rtems/rtems/region.inl,
rtems/inline/rtems/rtems/sem.inl,
rtems/inline/rtems/rtems/status.inl,
rtems/inline/rtems/rtems/support.inl,
rtems/inline/rtems/rtems/tasks.inl,
rtems/inline/rtems/rtems/timer.inl,
rtems/macros/rtems/rtems/asr.inl,
rtems/macros/rtems/rtems/attr.inl,
rtems/macros/rtems/rtems/dpmem.inl,
rtems/macros/rtems/rtems/event.inl,
rtems/macros/rtems/rtems/eventset.inl,
rtems/macros/rtems/rtems/message.inl,
rtems/macros/rtems/rtems/modes.inl,
rtems/macros/rtems/rtems/options.inl,
rtems/macros/rtems/rtems/part.inl,
rtems/macros/rtems/rtems/ratemon.inl,
rtems/macros/rtems/rtems/region.inl,
rtems/macros/rtems/rtems/sem.inl,
rtems/macros/rtems/rtems/status.inl,
rtems/macros/rtems/rtems/support.inl,
rtems/macros/rtems/rtems/tasks.inl,
rtems/macros/rtems/rtems/timer.inl: New header guards.
* itron/inline/rtems/itron/eventflags.inl,
itron/inline/rtems/itron/fmempool.inl,
itron/inline/rtems/itron/intr.inl,
itron/inline/rtems/itron/mbox.inl,
itron/inline/rtems/itron/msgbuffer.inl,
itron/inline/rtems/itron/network.inl,
itron/inline/rtems/itron/port.inl,
itron/inline/rtems/itron/semaphore.inl,
itron/inline/rtems/itron/sysmgmt.inl,
itron/inline/rtems/itron/task.inl,
itron/inline/rtems/itron/time.inl,
itron/inline/rtems/itron/vmempool.inl,
itron/macros/rtems/itron/eventflags.inl,
itron/macros/rtems/itron/fmempool.inl,
itron/macros/rtems/itron/intr.inl,
itron/macros/rtems/itron/mbox.inl,
itron/macros/rtems/itron/msgbuffer.inl,
itron/macros/rtems/itron/network.inl,
itron/macros/rtems/itron/port.inl,
itron/macros/rtems/itron/semaphore.inl,
itron/macros/rtems/itron/sysmgmt.inl,
itron/macros/rtems/itron/task.inl,
itron/macros/rtems/itron/time.inl,
itron/macros/rtems/itron/vmempool.inl: New header guards.
* posix/inline/rtems/posix/cond.inl,
posix/inline/rtems/posix/intr.inl,
posix/inline/rtems/posix/key.inl,
posix/inline/rtems/posix/timer.inl,
posix/macros/rtems/posix/cond.inl,
posix/macros/rtems/posix/intr.inl,
posix/macros/rtems/posix/key.inl,
posix/macros/rtems/posix/mqueue.inl,
posix/macros/rtems/posix/mutex.inl,
posix/macros/rtems/posix/priority.inl,
posix/macros/rtems/posix/pthread.inl,
posix/macros/rtems/posix/semaphore.inl,
posix/macros/rtems/posix/timer.inl: New header guards.
* posix/include/aio.h, posix/include/devctl.h,
posix/include/intr.h, posix/include/mqueue.h,
posix/include/sched.h, posix/include/semaphore.h,
posix/include/rtems/posix/cancel.h,
posix/include/rtems/posix/cond.h,
posix/include/rtems/posix/condmp.h,
posix/include/rtems/posix/config.h,
posix/include/rtems/posix/intr.h,
posix/include/rtems/posix/key.h,
posix/include/rtems/posix/mqueue.h,
posix/include/rtems/posix/mqueuemp.h,
posix/include/rtems/posix/mutex.h,
posix/include/rtems/posix/mutexmp.h,
posix/include/rtems/posix/posixapi.h,
posix/include/rtems/posix/pthreadmp.h,
posix/include/rtems/posix/ptimer.h,
posix/include/rtems/posix/semaphoremp.h,
posix/include/rtems/posix/time.h,
posix/include/rtems/posix/timer.h: New header guards.
* backward/asm.h, backward/chain.h, backward/clockdrv.h,
backward/confdefs.h, backward/console.h, backward/dosfs.h,
backward/ftpd.h, backward/imfs.h, backward/iosupp.h,
backward/itron.h, backward/ringbuf.h, backward/rtc.h,
backward/spurious.h, backward/timerdrv.h, backward/vmeintr.h,
backward/motorola/mc68230.h, backward/motorola/mc68681.h,
backward/zilog/z8030.h, backward/zilog/z8036.h,
backward/zilog/z8536.h:
New header guards.
PR doc/763
* score/Doxyfile: Fixed path to no_cpu.
* configure.ac: Check for external ampolish3.
* rtems/score/cpu.h: Remove traces from NO_CPU.
* console/keyboard.h: Add include file and cleanup file header.
CPU_IDLE_TASK_IS_FP, CPU_SOFTWARE_FP): New.
CPU_IDLE_TASK_IS_FP): Remove.
