* | bsp/atsam: Reserve one region for applications. | Christian Mauderer | 2018-05-25 | 1 | -0/+4 | |
| | | | | | | This allows a user to overwrite some MPU settings. That can for example be usefull for devices with special requirements that are connected to the external bus interface. | |||||
* | dltests-broken-on-this-bsp.tcfg: Add dl06 | Joel Sherrill | 2018-05-21 | 1 | -0/+1 | |
* | virtex5: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 2 | -1/+3 | |
| | | | | Updates #3425. | |||||
* | virtex4: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 2 | -1/+3 | |
* | virtex: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 2 | -1/+3 | |
* | tqm8xx: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 2 | -2/+2 | |
* | t32mppc: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 2 | -3/+2 | |
* | ss555: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 2 | -2/+3 | |
* | qoriq: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 4 | -7/+4 | |
* | qemuppc: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 2 | -1/+2 | |
* | psim: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 2 | -1/+3 | |
* | mvme5500: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 2 | -1/+3 | |
* | mvme3100: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 2 | -1/+3 | |
* | mpc8260ads: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 2 | -2/+2 | |
* | mpc55xxevb: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 2 | -1/+3 | |
* | motorola_powerpc: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 6 | -7/+21 | |
* | haleakala: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 2 | -1/+3 | |
* | beatnik: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 2 | -1/+3 | |
* | bsp/powerpc: Remove wildcards in linkcmds.base | Sebastian Huber | 2018-05-18 | 1 | -3/+3 | |
| | | | | | | | | | | | | This reverts commit 40c623a883da5dd80e4599cf4cd14097834706bd. The use of postfix wildcards, e.g. of the form "*.x" is dangerous since it circumvents the standard matching rules for sections. Unknown input sections should be added explicitly to the desired output section via "x.*" wildcards. Update #3307. | |||||
* | libtests/block05: Use rtems_blkdev_create() | Sebastian Huber | 2018-05-18 | 1 | -22/+25 | |
| | | | | Update #3358. | |||||
* | libchip: Use rtems_blkdev_create() | Sebastian Huber | 2018-05-18 | 1 | -43/+15 | |
* | libblock: Init deps in rtems_blkdev_create() | Sebastian Huber | 2018-05-18 | 3 | -6/+19 | |
* | sparc64 BSPs: Hard define configuration required settings | Joel Sherrill | 2018-05-15 | 2 | -13/+3 | |
* | rtems-bsps: Change 4.12 to 5 | Joel Sherrill | 2018-05-14 | 1 | -1/+1 | |
* | Drop executable permissions on .[S] files | Joel Sherrill | 2018-05-14 | 1 | -0/+0 | |
* | spcpucounter01: Enable floating-point output | Sebastian Huber | 2018-05-14 | 1 | -0/+1 | |
* | build: Fix RTEMS_ENABLE_RTEMSBSP() | Sebastian Huber | 2018-05-14 | 1 | -3/+7 | |
| | | | | | | The riscv32 and riscv64 targets share a riscv source directory. The potential future powerpcspe and powerpc targets need this change as well. | |||||
* | no_cpu/no_bsp: Fix Makefile | Amaan Cheval | 2018-05-14 | 1 | -1/+1 | |
* | dev/sc16is752: Add ioctl calls for modem controll. | Christian Mauderer | 2018-05-14 | 2 | -1/+96 | |
| | | | | | | | | This add ths following ioctl calls to the sc16is752 driver: - TIOCMGET - TIOCMSET - TIOCMBIS - TIOCMBIC | |||||
* | sparc64 niagara, usiii: Remove -D options from cfg file and move to bspopts.h | Joel Sherrill | 2018-05-09 | 9 | -3/+34 | |
* | smdk2410: Move define of CPU_S3C2410 to bspopts.h | Joel Sherrill | 2018-05-09 | 4 | -3/+12 | |
* | rtl22xx_t.cfg: Remove comment with -D __THUMB_INTERWORK__ | Joel Sherrill | 2018-05-08 | 1 | -4/+0 | |
* | ftpd: Fix infinite recursion in yield() | Sebastian Huber | 2018-05-08 | 1 | -1/+1 | |
| | | | | Update #3419. | |||||
* | telnetd: Use syslog() instead of printk() | Sebastian Huber | 2018-05-02 | 1 | -2/+8 | |
* | telnetd: Always build telnet daemon | Sebastian Huber | 2018-05-02 | 4 | -31/+76 | |
| | | | | | | Add support for libbsd initialization. Update #3419. | |||||
* | ftpd: Always build FTP daemon | Sebastian Huber | 2018-05-02 | 4 | -36/+66 | |
* | ftpd: Use floating-point tasks due to syslog() | Sebastian Huber | 2018-05-02 | 1 | -1/+1 | |
* | ftpd: Fairplay with libbsd | Sebastian Huber | 2018-05-02 | 1 | -0/+18 | |
* | network: Import latest <arpa/ftp.h> from FreeBSD | Sebastian Huber | 2018-05-02 | 3 | -7/+10 | |
* | ftpfs: Always build FTP client | Sebastian Huber | 2018-05-02 | 5 | -3/+9 | |
| | | | | | | Move FTP client filesystem to separate library libftpfs.a. Update #3419. | |||||
* | tftpfs: Always build TFTP client | Sebastian Huber | 2018-05-02 | 5 | -6/+24 | |
| | | | | | | | Move TFTP client filesystem to separate library libtftpfs.a. Conditionally use legacy network stack features, e.g. BOOTP support. Update #3419. | |||||
* | libdebugger: Move to separate library | Sebastian Huber | 2018-05-02 | 6 | -14/+11 | |
| | | | | | | | | | | Always build remote TCP support since it depends only on the POSIX socket API. It works with the legacy network stack and libbsd. Move it to a separate libdebugger.a library to allow an easy use with libbsd via "-ldebugger -lbsd" otherwise we would have a cyclic dependency between libbsd.a and librtemscpu.a. Update #3419. | |||||
* | tests: Move rtems-test-check.py | Sebastian Huber | 2018-05-02 | 3 | -204/+1 | |
| | | | | Remove shell script variant. | |||||
* | tests: Remove difftest and sorttimes tools | Sebastian Huber | 2018-05-02 | 7 | -364/+0 | |
| | | | | Close #3418. | |||||
* | tests: Remove configure feature checks | Sebastian Huber | 2018-05-02 | 23 | -334/+11 | |
| | | | | Update #3409. | |||||
* | Drop executable permissions on .[ch] files | Joel Sherrill | 2018-04-30 | 22 | -0/+0 | |
* | jffs2: Do not use command line defines | Sebastian Huber | 2018-04-30 | 21 | -2/+40 | |
| | | | | Update #3375. | |||||
* | config: Fix -Wint-in-bool-context warnings | Sebastian Huber | 2018-04-30 | 1 | -1/+1 | |
* | smptests/smpschededf02: Add test case | Sebastian Huber | 2018-04-27 | 1 | -3/+8 | |
* | bsp/pc386: Remove bin2boot support | Sebastian Huber | 2018-04-27 | 7 | -857/+0 | |
| | | | | | Update #3408. Close #3410. |
