* Makefile.am, README, startup/init5235.c, startup/linkcmds,
startup/linkcmdsflash, startup/linkcmdsram: Modify to the mcf5235
eval boards to either load and run from ram using the dBug moniter as
the boot deviced (Board setup as shipped from the factory), or it
allows the user to Boot his code from flash he loads onto the eval
board. The code changes between the two are based on the selected
linker script using a variable in the script. The options to the
linker are used to override the default linker script and select
which options to configure at boot either from flash, or from ram:
-qnolinkcmds -T linkcmdsflash
If no options are given the standard linker sript assumes dBug was
used to set up the board and the user is going to load his program
to RAM.
* libcsupport/include/rtems/cdefs.h: Partial update from freebsd.
* libcsupport/src/base_fs.c: Remove extra endif.
PR 1101/rtems
* libcsupport/src/base_fs.c, rtems/src/taskcreate.c, rtems/src/tasks.c,
score/src/coremutex.c: Remove dead code.
PR 1100/bsps
* console/debugputs.c: Remove redundant return.
* cpu_asm.S: Reduce mask from 0xffc to 0x3fc so only the vector
bits are used when calculating the exception vector.
on-board memory from VME.
the caches against the book and updated 'dssall', 'sync'
and 'isync's accordingly.
the normal scheme of vector = exception # << 8. So we picked
an unused vector number (currently 0xa) where we map the special
vector 0xf20 (altivec).
define BSP_PCI_VME_DRIVER_DOES_EOI and BSP_PIC_DO_EOI.
assigned vector number alias.
constants to pointers). Enable L1 cache on mvme2100.
FPU available (ISR, int-only task) - switch FPU on
for the switch and restore MSR_FP after it's done.
(new gcc may use FP regs implicitely).
* README:
* libcsupport/include/rtems/libio.h: Add extern "C" {}.
* posix/src/mqueue.c: Remove duplicate #include <limits.h>.
PR 1088/rtems
* posix/src/ptimer.c: Add missing #include <limits.h>.
Add freebsd6.1
* cpu.c: Added __mips==32 to fix build problems on those targets
caused by the Bruce Robinson.
B.Robinson patch
* posix/Makefile.am, posix/preinstall.am,
posix/include/rtems/posix/timer.h, posix/src/ptimer.c,
posix/src/ptimer1.c, sapi/src/posixapi.c,
score/include/rtems/score/object.h:
* shared/irq/irq_init.c: Changed interrupt handling
to use shared rtems_irq_connect_data struct.
* startup/linkcmds: Removed unnecessary global definition of
bsp_vector_table.
* times: Reran timing tests and updated 'times' file.
* startup/bspstart.c: Fixed PLL calculations.
* Makefile.am, console/uart.c, startup/exit.c: Changed UART
driver to be interrupt driven, added support for both UARTs.
* mc9328mxl/include/mc9328mxl.h: Added UART register definitions.
* at91rm9200/irq/bsp_irq_init.c, mc9328mxl/clock/clockdrv.c,
mc9328mxl/irq/bsp_irq_asm.S, mc9328mxl/irq/bsp_irq_init.c,
mc9328mxl/irq/irq.c, mc9328mxl/irq/irq.h,
s3c2400/irq/bsp_irq_init.c: Changed interrupt handling
* irq/bsp_irq_init.c: Changed interrupt handling
* network/network.c: Changed interrupt handling
