* gccnewlib/mkspec.in: Split patches.
* gccnewlib/gccnewlib.add: Dynamically create brp-*.
Use split source tar balls.
* binutils/binutils.add: Dynamically create brp-*.
Misc. update.
* rtems/score/cpu.h: Increase default stack size on i386 from 1K to 4K.
Most i386 targets are not memory strapped so making this a bit large
is not a burden. It lets more tests run. ticker and psxtimer will not
even run with 1K of stack.
* configure.ac, console/console.c: Add USE_COM1_AS_CONSOLE BSP option.
This makes it easy to build the pc386 BSP in a configuration that
corresponds to qemu with COM1 redirected to stdio.
PR 855/tests
* support/include/tmacros.h: Fix typo.
* posix/inline/rtems/posix/cond.inl, posix/macros/rtems/posix/cond.inl,
posix/src/conddestroy.c: Remove warnings.
* rtems/src/tasks.c, rtems/src/taskvariableadd.c,
rtems/src/taskvariabledelete.c, rtems/src/taskvariableget.c: Remove
warnings.
* gnatinstallhandler.c: Rename since old name is now used
by GNAT source.
by GNAT source.
PR 882/make_build
* bootstrap: Only remove bspopts.h.in instead of bspopts.h*.
* shgen.c: include <stdlib.h>.
* vmeUniverse/vmeTsi148.c, vmeUniverse/vmeUniverse.c,
vmeUniverse/vmeUniverse.h, vmeUniverse/vme_amd_defs.h:
Added 2F address modifier for VME64 CSR access.
* runtest: Add pvr setting.
* mpc6xx/mmu/pte121.c: consistency check now warns instead
of reporting an error when coming across a non 1:1 VSID;
fix: triv121IsRangeMapped() needs to convert segment offset
into a page index if the vsid argument is non-special.
* psim: Enhance to add limit on how long a single test is allowed to
execute. This can be used to significantly enhance the reliability of
long batch test runs.
* texi2www: Add provisory support for @image.
* user/rtemsarc.gif, user/states.gif, user/rtemspie.gif:
Remove (Unused).
* user/rtemsarc.txt, user/rtemspie.txt, user/states.txt:
New (Extracted from other docs).
* user/Makefile.am: Reflect changes above.
* base.t: Remove.
* Makefile.am: Remove base.t.
* index.html.in: Remove OR32.
* eventlog.t: Remove.
* new_chapters.texi: Remove eventlog.
* Makefile.am: Remove eventlog.
* dumpcontrol.t: Remove.
* new_chapters.texi: Remove dumpcontrol.
* Makefile.am: Remove dumpcontrol.
* confspace.t: Remove.
* new_chapters.texi: Remove confspace.
* Makefile.am: Remove confspace.
* adminiface.t: Remove.
* new_chapters.texi: Remove adminiface.
* Makefile.am: Remove adminiface.
* posix/include/intr.h, posix/include/rtems/posix/intr.h
posix/inline/rtems/posix/intr.inl.
posix/macros/rtems/posix/intr.inl, posix/src/intr.c:
Remove (Unused, dead).
* posix/Makefile.am: Reflect changes above. Rework.
* posix/Makefile.am: Build devctl.
* rtems/Makefile.am: Rework.
* score/Makefile.am: Rework.
Large patch to improve Doxygen output. As a side-effect, grammar and
spelling errors were corrected, spacing errors were address, and some
variable names were improved.
* libmisc/monitor/mon-object.c, libmisc/monitor/monitor.h:
Account for changing OBJECTS_NO_CLASS to OBJECTS_CLASSIC_NO_CLASS.
* score/Doxyfile: Set output directory. Predefine some macro values.
Turn on graphical output.
* score/include/rtems/debug.h, score/include/rtems/seterr.h,
score/include/rtems/system.h, score/include/rtems/score/address.h,
score/include/rtems/score/apiext.h,
score/include/rtems/score/apimutex.h,
score/include/rtems/score/bitfield.h,
score/include/rtems/score/chain.h,
score/include/rtems/score/context.h,
score/include/rtems/score/coresem.h,
score/include/rtems/score/heap.h, score/include/rtems/score/interr.h,
score/include/rtems/score/isr.h, score/include/rtems/score/mpci.h,
score/include/rtems/score/mppkt.h,
score/include/rtems/score/objectmp.h,
score/include/rtems/score/stack.h,
score/include/rtems/score/states.h,
score/include/rtems/score/sysstate.h,
score/include/rtems/score/threadmp.h,
score/include/rtems/score/threadq.h, score/include/rtems/score/tod.h,
score/include/rtems/score/tqdata.h,
score/include/rtems/score/userext.h,
score/include/rtems/score/watchdog.h,
score/include/rtems/score/wkspace.h,
score/inline/rtems/score/address.inl,
score/inline/rtems/score/chain.inl,
score/inline/rtems/score/coremutex.inl,
score/inline/rtems/score/coresem.inl,
score/inline/rtems/score/heap.inl,
score/inline/rtems/score/object.inl,
score/inline/rtems/score/stack.inl,
score/inline/rtems/score/thread.inl,
score/inline/rtems/score/tqdata.inl, score/macros/README,
score/src/heap.c, score/src/threadmp.c, score/src/threadready.c,
score/src/threadstartmultitasking.c: Improve generated Doxygen
output. Fix spelling and grammar errors in comments. Correct names of
some variables and propagate changes.
* rtems/score/cpu.h: Part of a large patch to improve Doxygen output.
As a side-effect, grammar and spelling errors were corrected, spacing
errors were address, and some variable names were improved.
* rtems/new-exceptions/cpu.h, rtems/old-exceptions/cpu.h,
* rtems/asm.h, rtems/score/cpu.h, rtems/score/types.h: Part of a large
